This one has been on the bench for a while between other projects. I have another large plane project coming up, so I figured I'd better wrap this one up to make room.
This is Tamiya's kit 60309 and second time I build this. This one definitely turned out better. The kit itself is awesome with lots of details. No aftermarket details were added except for a set of Montex paint masks for all the main markings. The landing gear is retractable, and the cowlings can be removed.
I tried to use the blackbasing technique on this one. I'm still on the fence using the technique over the traditional preshading.
Thanks for looking!
Well done!
Nick.
Ole, great job with your Zero
What did you use for the antenna wire? Noticed it curves slightly near the tail fin.
Fantastic! You did am awesome job.
Your friend, Toshi
Reside in Streetsboro, Ohio
Edwin Ole, great job with your Zero What did you use for the antenna wire? Noticed it curves slightly near the tail fin.
Thanks all,
It's a piece of metal wire that came with the kit. I should be able to straighten it out a bit.
My website: http://waihobbies.wkhc.net
waikongvery VERY nice finish on this one!
Thanks a lot!
Oh krap, thought I'd already commented here.
Superb job, the chipping and weathering looks incredible!!!
Great job on this build, Ole! I just started the same kit for the Japanese Group Build, and I hope that mine turns out half as good as your's did!
Gary Mason
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
Devil Dawg Great job on this build, Ole! I just started the same kit for the Japanese Group Build, and I hope that mine turns out half as good as your's did! Gary Mason
Thanks, it's a great kit and I'll definitely get another one.
Looks great!
