1/48 Tamiya Spitfire Mk I 610 Sqn. FINISHED
    July 2019
Posted by Hoss WA on Friday, August 9, 2019 7:27 PM
My first venture (this century) beyond the Luftwaffe. i couldn't resist the new Tamiya BoB Spitfire after building Josef Priller's BoB 109.
This kit is really fun to build so far. The cockpit and instrument panel were particularly rewarding.  The fit is flawless with plenty of eye-catching detail.
The overall build was fairly drama free. A little fill and sanding were required on the cowling along with the spine and underside of the fuselage. The fit of the wing to the fuselage is perfect -- no issues.
The one-piece stabilizer ensures that the port and starboard stabilizers are co-planar, but not necessarily properly level with the wings after gluing to the tail! Minor surgery made for an easy fix after my flawed assumption.
I also had to trim the flash suppressors on the outboard (3rd and 4th) machine guns after installing the guns when building the wings. My understanding is that these were removed after the start of the war and therefore are only needed for the pre-war marking option.
I'm still developing/refining my painting sequence and technique. I'm using Mission Models paints again and decided to preshade. I plan to do most of the weathering after decals and gloss coat since it's a little easier to recover from mistakes.  I still have a tendency to "overweather then fix" rather than get it right the first time. I also plan to use either Mission Models gloss (the usual) or potentially Alclad Klear Kote gloss prior to decals. I'll decide after some testing. I'm going to break new ground with Model Master Flat Clear Lacquer for the final matte coat. I have not been happy with the Mission Models Flat Clear as the finish is particularly rough and often has frosty white areas.
    April 2015
Posted by Mopar Madness on Friday, August 9, 2019 7:31 PM
That front office looks beautiful! I would like to get this one myself.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by keavdog on Friday, August 9, 2019 8:07 PM
That's looking really nice.  I finished my tamiya spit last year but it was the older kit.  So much more detail here.  Awesome job so far
Thanks,
John
    August 2019
Posted by Josh_the_painter on Saturday, August 10, 2019 7:14 AM
Thats looking superb! Nicely detailed.
What your mentioning about your issues with the flat clear suggest its drying too quick and needs a slow reducer/ retarder. Slowing it down will give it more time to flow and smoot out, could possibly still be a touch thick. And the silicas being forced to the surface too quickly and drying inconsistently. The whiteness is due to a higher concentration of silica in those areas.
Cheers, Josh
    August 2009
Posted by TREYZX10R on Saturday, August 10, 2019 8:43 AM
Office looks outstanding!
    February 2016
Posted by lowfly on Saturday, August 10, 2019 8:48 AM
This one looks fantastic! Love the cockpit! I think you will be happy with the Model Master Flat Clear. I use the acrylic version and i love it. Sprays good out of the AB and is a great Matte finish
    July 2019
Posted by Hoss WA on Sunday, August 11, 2019 10:34 PM
Thanks for the comments everyone!
Josh - thanks also for the tip on the flat clear.
Here's the latest progress after this weekend. Base coat, masking and gloss coat complete and ready for decals. I had to clean up a bit of overspray but nothing major.
I used the full scale template supplied with the kit for the masking. Using mini masking tape rolls about 1/8" from the edge and pressing the mask down firmly after applying resulted in a "semi-hard" edge demarcation, my desired effect.
I've tried using the blu-tac worms, which definitely save time, but I find I'm working long after to pull up little globs of blue tac hiding in the panel lines and rivets on the fresh paint. Sometimes I've marred the paint surface trying the grab the small blu tac blobs with big blu tac blobs. The tiny masking tape rolls come up cleanly. I'm wondering if anyone else has experienced this issue or if there's a better solution for the "worm" strategy.
    August 2019
Posted by Josh_the_painter on Monday, August 12, 2019 7:04 AM
Looks perfect! You created a nice soft edge masking with the templates as you did, well done.
Josh
    November 2008
Posted by Justinryan215 on Monday, August 12, 2019 9:07 AM
THST'S 1/48th SCALE?!  that cockpit looks amazing!
Beautiful build thus far!
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    February 2016
Posted by lowfly on Monday, August 12, 2019 2:44 PM
Hoss WA
Instead of the Blu Tac....Try using Silly Putty or MIG makes a putty mask that is really good as well.  The MIG version tends to be expensive but well worth it for what it does.  I experianced the same thing with the Blu Tac put the silly putty comes off clean, is not as aggressive with its tackiness and provides the same results. Great looking build!
    August 2009
Posted by TREYZX10R on Monday, August 12, 2019 8:00 PM
Great looking cammo! I also have used silly putty with good results.
    July 2019
Posted by Hoss WA on Tuesday, August 13, 2019 8:03 PM
Lowfly- thanks for the comments and the tip on the masking putty. I’ll check out mig for the next build.
    February 2012
Posted by lawdog114 on Thursday, August 15, 2019 2:27 AM
Very nice indeed.
    July 2019
Posted by Hoss WA on Saturday, August 17, 2019 10:56 PM
Thanks all for the comments. Just finished this. Final photos soon.
Here are some catchup photos from the decal debacle. I wasn't happy at all with the Tamiya kit decals. Very thick and uncooperative with MicroSol and Solvaset. I'm sure my technique was a contributor, but other decals I've recently used have been much more forgiving (and look better). I think I'll make an attempt at masks or aftermarket decals with my next Tamiya kit.
On the good news front, I used Mission Models gloss prior to and after decals and was very happy with the gloss coat results. I've experienced orange peel and general rough finishes with gloss in the past and think I've finally learned how to get repeatable smooth glossy surface results by using low pressure and controlling distance and speed.
    July 2019
Posted by Hoss WA on Saturday, August 17, 2019 11:25 PM
Here are the final photos.
Overall this is a wonderful kit to build. The fit is excellent, instructions clear, engineering and assembly approach very well done. The huge downside were the decals. I was really surprised by how thick they were and how different colors of the same decal were of different thicknesses. This is very noticable even after gloss and matt coats and after weathering, etc. I attempted to break up this effect with stronger panel lines than usual. Next time I build a Tamiya kit I'll definitely try aftermarket decals or perhaps masks.
Another huge positive for me was the Eureka moment with my final flat coat. I've been using Mission Models and have been unhappy with the results. For this build I tested both Model Master Flat Clear Laquer as well as Alclad Klear Kote Flat. Both infinitely better than the Mission Models Flat Clear. I ended up using the Model Master Flat Clear Laquer and really couldn't be happier with the outcome.  Nice smooth flat surface, no white frost or powder and no rough sandpaper surface. Looks great and was very easy to apply.
Enjoy the photos.
Tags: 1/48 , Tamiya , Spitfire
cnq
    March 2013
Posted by cnq on Sunday, August 18, 2019 8:24 AM
Beautiful work. I love it.
    January 2019
Posted by The Drifter on Sunday, August 18, 2019 9:00 AM
Outstanding work there sir....wonderful detail in the pit, and paint scheme.
Jeff
On The Bench: Coming Soon
fox
    January 2007
Posted by fox on Sunday, August 18, 2019 12:01 PM
V - E - R - Y    N - I - C - E  build. ToastToastToast
Jim  Captain
 Main WIP:
    January 2015
Posted by M. Brindos on Sunday, August 18, 2019 9:01 PM
You do amazing work, Hoss. Just flat out gorgeous.
- Mike Brindos "Lost Boy"
    August 2019
Posted by HighDesertmodeler on Sunday, August 18, 2019 9:46 PM
Beautiful Spitfire, amazing building, painting and weathering. Thank you for sharing!
    August 2009
Posted by TREYZX10R on Monday, August 19, 2019 7:22 PM
Very nicely done Sir!
    July 2019
Posted by Hoss WA on Monday, August 19, 2019 9:58 PM
Thanks all for the really nice comments. They're very very much appreciated. Thanks again to the community here for tips and techniques. So much to learn.
    February 2012
Posted by lawdog114 on Wednesday, August 21, 2019 3:15 AM
Turned out great. Thanks for sharing your work.
