Airfix B17G to B17F 1/72 update. memphis belle
Hi everyone,
As I have had a hiccup with the Hasegawa Zero I ordered and have had to reorder, I decided to start this project I had sitting here. Long story short I have a grandfather ill with cancer and thought he would get a kick out of being gifted a Memphis Belle. I had read reviews on the quality of the current Airfix kit and bought this:
When it arrived I thought Damn, The Belle was a B17F! I could have done a separate build on this kit and purchased another B17F, however for myself I would like to build a much larger scale B17 so after some encouragement from Lawdog I decided Im going the surgery route and adapting this kit.
Ive started with the cockpit as per instructions. Reference photos are terrible, every plane seems to be a different colour or shade inside, flooring is either wood finish or painted black, some interior areas are either bare or painted green or a combination.
I have decided Im going for a mostly green interior, considering you are not really going to see any of it anyway.
On to the bits you can see I couldn't quite work out some of the colour suggestions, especially the cockpit sides being a tan and not green as I was seeing in reference photos. Then I worked it out, it's the colour of the insulation that is on the sides. I started by painting and detailing the sides, theyre pretty sparse.
Then I added some masking tape insulation, cut around the instruments and painted that tan.
So onto the seats. I need to go back and look at seatbelts and oxygen tanks behind the seats. however I did the basic assembly and to add a bit more depth I made seat cushions from multi layered masking tape, painted yellow and cut out the cushions. The flight controls are joined in the center mould so a blade through those made the 2 separate banks of levers. I also decided on a wood finish floor.
From here cockpit going together. Not award winning modelling but I think a better result than simply following the set instructions.
and lastly I had the decal set arrive.
Thanks for looking
Josh
