Well, this has been a long journey. I started this build in March 2018. The next month I put the kit on The Shelf Of Doom because I became feed up with the poor engineering of the model. In June, 2019, I decided to finish the kit. It took three months, and a number of sheets of Bare Metal Foil, to finish the kit. The WIP is here: cs.finescale.com/fsm/modeling_subjects/f/2/t/178237.aspx?page=1
Following are some photos of the finished build.
You are a patient man! Very nice job -looks fantastic.
Thanks,
John
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5-2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
Yep, looks as good if not better than the real thing!
Chris Christenson
That looks great.
How did you achieve the various shades and finishes? (I've never worked with BMF)
Very nicely done Sir! The best build of that kit I've seen!
gif creators
Your persitance paid off, it looks fantastic! Great job, glad you pulled it off the shelf of doom!
Keyda81 Your persitance paid off, it looks fantastic! Great job, glad you pulled it off the shelf of doom!
Greg That looks great. How did you achieve the various shades and finishes? (I've never worked with BMF)
This is the wing of a B-24. The majority of the panels are Matt Aluminum. I noted the panels that are foiled in Chrome. Also, it is easy to make rivets using a rivet wheel.
It would be difficult to achieve this subtle varity of colors using paint.
That’s one to brag about!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
This is my secret tool for appling foil. Just a little does the trick.
Stunning metal finish! Great job! That's one thing I will not be able to do. I'm so clumsy working on my models and I'm sure I will not be be able to apply those foils without folds or wrinkles.
great work!
On the Bench: Too Much
You should give foiling a try. I would suggest that your first attempt should be on a P-47. It has very simple shapes.
Thank's everyone!
My website: http://waihobbies.wkhc.net
