WIP 1/48 Pro Modeler Do 217E-5 *UPDATE #2*
    April 2015
Posted by Mopar Madness on Saturday, November 9, 2019 12:21 PM
Hello friends. Next up on the work bench is the Dornier Do 217E-5 in 1/48 scale from Monogram. Looks to be a nice kit with fine recessed panel lines and crisp molding. The clear parts are also very clear and well molded. Pretty typical of what they were releasing around this time.  The decals are showing signs of age so I bought a set of MonTex painting masks for all the numerals, letters, and insignias.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by Bish on Saturday, November 9, 2019 1:10 PM
Look forward to seeing what you do with this.
    July 2019
Posted by Hoss WA on Saturday, November 9, 2019 1:14 PM
Looks good. Following along.
    June 2014
Posted by BrandonK on Saturday, November 9, 2019 4:30 PM
I've always had good luck with the PM kits. I haven't seen this one, so I'll be watching.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2003
Posted by tempestjohnny on Saturday, November 9, 2019 6:37 PM
I've got this in the stash. I'll be watching
    February 2012
Posted by lawdog114 on Saturday, November 9, 2019 11:21 PM
This should be good. Good choice on the Montex.
    April 2015
Posted by Mopar Madness on Sunday, November 17, 2019 7:38 PM
Glad to have you aboard guys!
Chad
On deck: Who knows!
    April 2015
Posted by Mopar Madness on Sunday, November 17, 2019 7:40 PM
Hello friends.  The front office is done.  Each instrument bezel is hand painted while the actual gauges are from the 1/48 Dials and Gauges set from Mike Grant Decals.  After the decals were set, a drop of clear gloss wash dabbed to imitate glass covers. Time to close up the fuselage and attach the wings. So far, no real complaints.  The fuselage walls and instrument panel are very detailed and show just how well molded these kits were aside from one or two injector pin marks that needed cleaning.
Chad
On deck: Who knows!
Posted by jeaton01 on Sunday, November 17, 2019 10:27 PM
Quite nice.  i really like the look of the belts.
John
    November 2003
Posted by tempestjohnny on Monday, November 18, 2019 5:59 AM
I was looking at the gauges expecting them to move. Wow
    April 2015
Posted by Mopar Madness on Monday, November 18, 2019 8:59 AM
jeaton01
Thank you John.  I'm a big fan of Eduard steel belts.
Chad
On deck: Who knows!
    April 2015
Posted by Mopar Madness on Monday, November 18, 2019 9:00 AM
tempestjohnny
Thanks Johnny.  I really appreciate it!
Chad
On deck: Who knows!
    August 2009
Posted by TREYZX10R on Thursday, November 21, 2019 8:22 PM
Wow that office is stunning! I've done 2 of these they go together ok, if memory serves I had a small fit issue with the wierd wing mounting. I did a Koster 217N1 solid nose night fighter conversion that was a nightmare. Have you decided on a scheme yet?
    July 2019
Posted by Hoss WA on Friday, November 22, 2019 3:18 AM
The office looks fantastic. Really really well done. I like the shading and how you created the wear, chips and scratches. Great work.
    April 2015
Posted by Mopar Madness on Friday, November 22, 2019 3:45 PM
TREYZX10R
I think I've experienced that same issue with the wing. There were also quite a few areas along the three connecting points of the fusalage that required some filler. But nothing a little patience and sanding couldn't overcome. Nothing decided as of yet.
Chad
On deck: Who knows!
    April 2015
Posted by Mopar Madness on Friday, November 22, 2019 3:46 PM
Hoss WA
Thank you Hoss!
Chad
On deck: Who knows!
Posted by Bish on Friday, November 22, 2019 3:52 PM
Thats some stunning work on that pit Chad, those belts look very nice.
    April 2015
Posted by Mopar Madness on Friday, November 22, 2019 5:35 PM
Bish
Thank you Bish.
Chad
On deck: Who knows!
    April 2015
Posted by Mopar Madness on Sunday, December 15, 2019 12:47 PM
A quick update. Fuselage is complete and wings are on. Up till now the engineering has been quite nice but there were a couple of what I consider to be minor flaws in the kits design. The fuselage is not your typical two piece affair. It was actually three longitudinal prices. This resulted in some gaps that required filling and re-scribing. The wings were also done in three pieces each with the third piece being the top outer half of the wing. This caused some strange gaps that require CA filler. Engines and landing gear come next.
Chad
On deck: Who knows!
    June 2014
Posted by BrandonK on Sunday, December 15, 2019 3:04 PM
This is looking good, Chad. I find myself using CA glue more and more. Espesially on small seams. You can add baking soda to make a filler also. Haven't tried that yet though.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    August 2009
Posted by TREYZX10R on Monday, December 16, 2019 9:52 PM
Coming together nicely Chad! Ca to the rescue, luv that stuff
    April 2015
Posted by Mopar Madness on Tuesday, December 17, 2019 9:25 PM
Thanks guys!  The CA really reinforced the whole joint better than I expected.
Chad
On deck: Who knows!
