I'm calling this one complete. This is my favorite Fw 190A-8 marking scheme and I'm really happy with the outcome.
Lt Dortenmann started in this plane when he was assigned as CO of 2./JG 54 in mid June 1944. His unit had just been transferred from the Russian front to support the defense of France after the Normandy invasion. He shot down a P-51 and a P-47 in this plane a few days before being shot down himself and successfully baling out. He later went on to pilot one of the very first production Fw 190D-9s and ended the war with 38 victories.
This is the first Hasegawa kit I've built. Even though it's a 2004 vintage with a few accuracy issues, it ended up looking pretty good and was straightforward to build.
The only drama in the entire build was self-induced. I accidentally spilled most of the contents of my airbrush fully loaded with black-brown mix all over the port cowling and wing during final weathering. ...many things thrown and much noise... I needed to completely repaint a few panels and touch up a few more. The bottom line is that I need more space for 1/32 planes vs. my usual, compact 1/48s. More space is on my XMAS list.
The build was completely out of the box except the machine guns (Master) and decals (EagleCals). I was going to use the Master cannon barrels but I managed to hollow out the ends OK and will save the master barrels for a future build. I used EZ line for the antenna.
I'm really happy with the AK Real Colors paints - really exceptional mid-war Luftwaffe camo colors. I used Flory washes for the panel lines, a black-brown mix (unspilled :)) and some pastels for the exhaust.
The original photos showed heavily spilled fuel stains all over the drop tank so I replicated this by placing several heavily thinned black-brown drops on top of the tank and blowing the fluid down the sides. The photos also showed an almost dead flat finish so I gave it 2x coats of Alclad Flat, which did the trick nicely.
I also adjusted my photo approach -- a shorter focal length lens combined with focus stacking -- to create a larger depth field for the 1/32 sized plane. I managed to get the entire model in crisp focus for the majority of photos.
Enjoy the photos and thanks for following along.
