Recommended starter fighters for 1/72 hasegawa?
    June 2019
Posted by RX79-G on Monday, December 16, 2019 4:37 PM
before i start, i live in japan so hasegawa rule most of the hobby shops here please so dont suggest other foreign brands like airfix or revell because theyre expensive......
so here are my questions:
-which best era should i start? ww2, cold war or modern?
-propeller or jet? im looking for a kit that is easy to brush paint and ease of assembly
- aside fighters, are bombers easy to build and to brush paint? Ive been eyeing on hasegawa b25 for some time...
Posted by jeaton01 on Monday, December 16, 2019 4:40 PM
If you are just starting out look at Tamiya 1/72 prop fighters, or the same from Hasegawa, less expensive than the bombers and less complicated to build.  Don't try to get the first one perfect, just try to learn a new skill on each one you do and move on to the next.  Practice, practice, practice.
John
    June 2019
Posted by RX79-G on Monday, December 16, 2019 5:04 PM
Thanks for the reply..... yup i’ll take note of that
    June 2017
Posted by UnwaryPaladin on Monday, December 16, 2019 5:20 PM
As far as subject and era, build what catches your interest. Doing the research on the subject and it's history is half the fun!
Just my opinion....
-An aircraft without camo or metal finish. You can do camo and metal with a brush, but it takes practice. Learning on a solid olive drab and grey is much easier to start.
- Jet or single prop. Prop bombers usually have more than one engine and more complex landing gear.
- Less complex over more complex. Learning the basics like prep work, gluing, masking, painting, and decaling is easier when the part count is not excessive and/or microscopic.
Hasegawa has quite a few older kits that still go together very nicely. The cockpits may be basic and they may have raised panel lines, but they still look great when you get them together. I'm not sure what they have in 1/48, but they have a lot of 1/72 aircraft that you can get for $10-15.
Find one you like, do a quick search on any reviews of that kit so you know what you're getting into.
    May 2004
Posted by cbaltrin on Monday, December 16, 2019 7:51 PM
Single engine WW2 fighters would probably be your best bet. As a rule, the more engines the more complicated :-).
The hasegawa Fw-190A-8 in 1/72 is a beautiful and simple kit as is there F4F wildcat. I would stay away from their P-47's in this scale if you want ez builds. I am afaid that is the limit of my knowlege regarding their WW2 offerings in 1/72 scale though...
On the Bench: Too Much
    June 2019
Posted by RX79-G on Monday, December 16, 2019 7:55 PM
Aside that, i found that f16 is a single engine fighter and from the looks of it, it looks simple and easy to build but i might be wrong tough....
    November 2003
Posted by tempestjohnny on Tuesday, December 17, 2019 5:47 AM
The F-16 is a great little kit. Will have more parts then the WWII stuff but is a fun build.
    January 2007
Posted by PaulBoyer on Tuesday, December 17, 2019 8:39 AM
You might want to look for the Hasegawa 1/72 scale P-40 series. Reasonably detailed and easily assembled, I used them in a starter class for youngsters. Most of the small WWII fighters from Hasegawa are good builds.
    July 2014
Posted by modelcrazy on Tuesday, December 17, 2019 9:32 AM
tempestjohnny
Ditto
I've built a few and they are simple and fun. You can get the weapons sets to add a little extra as well.
I'd say most of their 1/72 modern line are simple and fun kits.
Steve
    May 2011
Posted by Real G on Tuesday, December 17, 2019 11:26 AM
I echo what others have said - single engine prop or jet, simple color scheme.  Like US Army or Navy aircraft.  Avoid complex camouflage like Kobayashi's spotted Ki-61, that dreaded IJAF "snake weave" or Luftwaffe "mirror wave" schemes.
BTW, I noticed your handle is RX79-G - are you an 08th MS Team fan?
“Ya ya ya, unicorn papoi!”
    September 2006
Posted by the Baron on Tuesday, December 17, 2019 11:31 AM
I'll second Paladin's advice to consider your own interests first, and then look for a kit that fits them.
Having said that, I'll add that in my own experience, I like Hasegawa's 1/72 F4F and P-40 kits.  I like WW II American aircraft subjects, myself.
    June 2019
Posted by RX79-G on Tuesday, December 17, 2019 3:31 PM
Real G
yes i am hehehe....
    September 2012
Posted by GMorrison on Tuesday, December 17, 2019 4:45 PM
Hasegawa has some really nice Phantom IIs.
Curiously, I've found some of their multi engine kits to be hard to build with a lot of fit issues.
I'm currently putting together an F8E which is a good clean kit.
There's not much easier color schemes than the USN Gull Gray over White. Looks sharp too.
Hasegawa decals are often thick and hard to work with.
Any Tamiya kit from WW2 that you can find is worth it.
Nice to hear from you, welcome!
    June 2019
Posted by RX79-G on Tuesday, December 17, 2019 9:35 PM
[quote user="GMorrison"]
quote]
can you please specify which ones should i avoid?
    August 2005
Posted by Phil_H on Tuesday, December 17, 2019 9:37 PM
Hasegawa's early Navy jet Grumman birds (Panther, Cougar, Tiger) are nice starter kits. Nice elegant flowing lines and simple colour schemes.
    August 2005
Posted by Phil_H on Tuesday, December 17, 2019 11:08 PM
RX79-G
GMorrison
Maybe not on your radar right at the moment, but the late 80's tooled F-14 Tomcat kits even give experienced modellers fits. It's quite a challenge, but when done well, it's gorgeous.
The earlier tooling is largely still available and is much more user friendly.
Posted by Gamera on Thursday, December 19, 2019 11:48 AM
Years ago I built their Bf-109 and Fw-190. A bit more complex paint schemes but not too hard to brush paint. Use a cotton bud to make the ink blot paint scheme.
And the P-47 and P-51 are pretty easy to build. Just brush paint or use a spray can for the aluminum/silver finish.
A lot of the Fujimi kits are pretty good too- I'd think you can get them easy in Japan.
    May 2011
Posted by Real G on Friday, December 20, 2019 11:28 AM
A friend built a 1/72 Tamiya Bf-109E as his first "scale" model (he started off doing Gunpla).  He handled assembly well, as Tamiya kits are nigh foolproof.  He was a little nervous about the ink spots so prevalent on German WW II aircraft, but in the end he used thin paint applied with a sponge to get the effect.  I think it turned out rather well, considering this was his first airplane model.
He had more problems with getting the yellow paint to cover.  The one thing he DID have at his disposal (well actually two "things") to help him was myself and another friend at the table.  Both of us are seasoned Luftwaffe modelers, so we helped guide him through assembly and painting.  We also provided innumerable nuggets of trivia about the Bf-109 along the way.  He had a good time and bought more 1/72 WW II aircraft as a result.
Hope your journey is fun, successful, and filled with innumerable nuggets of trivia!
    June 2017
Posted by UnwaryPaladin on Friday, December 20, 2019 1:33 PM
That looks great. So, how DID he do the yellow? Asking for a friend. Embarrassed
    May 2011
Posted by Real G on Friday, December 20, 2019 1:39 PM
Lots and lots of coats of yellow!  But he started on a grey primer; white would have been better.
    June 2008
Posted by lewbud on Friday, December 20, 2019 6:42 PM
I was going to suggest giving the HobbyBoss EZ kits a try. Fairly simple kits with a low parts count and are relatively cheap here in the States. I checked with HLJ and they don't even carry them so I don't know how available they would be in Japan.
Buddy- Those who say there are no stupid questions have never worked in customer service.
