1/32 Revell Bf 109G-6(14), Maj. Erich Hartmann, JG 53 (Complete)
    July 2019
Posted by Hoss WA on Monday, December 16, 2019 9:17 PM
The next project is Erich Hartmann's white Gustav from his time leading I./JG 53 in February 1945.  Since it's that time of year, I wanted to do a winter scheme and this one caught my eye. Of course the pilot needs no introduction.
Although Maj. Hartmann listed the plane as a G-6 in his flight log, online sources suggest that the plane could be a G-14.  In any event, the Revell 1/32 G-6 kit has all the necessary ingredients for the configuration seen in the photos. I found a relatively new AIMS decal set ("Tulip Bf 109s") and will be adding QB intake and bulges along with Eduard exhausts and Barracuda spinner and prop. I'll use my usual AK Real Colors for paint.
I've been pondering the best way to create the particular camo scheme called out by the AIMS decal set. Most of the on-line builds and decal schemes show a relatively solid white camo. However, the AIMS set and a couple of others show a series of gray lines over the white. These lines are clearly in the photos.
The decal profile suggests that these are grey streaks painted over white, but I'm wondering if the white was applied in patches and these gray areas are hints of the underlying camo between patches. It appears that the camo was sprayed on due to the overspray on the prop. I'm curious as to how this scheme was likely applied (white patches vs. grey streaks over solid white). I couldn't find anything in my references or online. Any thoughts?
As to progress, the office is complete and I'm getting ready to button up the fuselage.
    June 2014
Posted by BrandonK on Tuesday, December 17, 2019 11:52 AM
It's always truly difficult to really tell what the paint is up to in those old low res pics. I am no expert, but my brain says they didn't start with a pure white 109 and added grey stripes. What my eye, for what it's worth, sees in the pic is a normal 109 scheme over painted with large bloches of white paint leaving the underlying camo showing through in those greyish areas. It does not appear to me to be grey over white, it looks like white over camo with no grey. Just my 2 cents.
Your work looks great so far.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2019
Posted by Hoss WA on Friday, December 20, 2019 3:00 PM
BrandonK
BK
Thanks Brandon - I tend to agree with you. Patches of white makes more sense than solid white with grey lines.  Thanks!
    March 2009
Posted by the Wall on Saturday, December 21, 2019 6:48 AM
What color do you use for the interior paint? Do you use the same for the wheel struts?
    July 2019
Posted by Hoss WA on Saturday, December 21, 2019 10:53 AM
the Wall
For Luftwaffe cockpit interiors after 1941, I use RLM 66 dark grey. For other interior areas (wheel wells, landing gear, flaps, engine covers, etc.), RLM 02 is usually called for. I've had good results with AK real colors paints.
    November 2008
Posted by plasticjunkie on Sunday, December 22, 2019 5:02 PM
BrandonK
BK
With you BK 110% on this. It makes sense that the whitebash was painted over  and removed after the winter time back to the operational regular colors.
 GIFMaker.org_jy_Ayj_O
    February 2012
Posted by lawdog114 on Wednesday, December 25, 2019 11:43 PM
Still in awe of your instrument panels. Brilliant work. If I may, they had standard camo which was then white washed. I surmise the gray you see is some peeking through.
    July 2019
Posted by Hoss WA on Friday, December 27, 2019 10:57 PM
lawdog114
Thanks Lawdog! I agree on the camo approach. I plan to paint a standard 74/75/76 scheme and will then apply the white wash in patches. Thx.
    August 2009
Posted by TREYZX10R on Sunday, December 29, 2019 8:56 PM
Excellent looking so far! For sure it was a white wash over standard splinter cammo. Looking forward to seeing Bubi's whip finished out!
    July 2019
Posted by Hoss WA on Sunday, December 29, 2019 10:00 PM
TREYZX10R
Thanks TREYZX10R!
    July 2019
Posted by Hoss WA on Sunday, December 29, 2019 10:08 PM
The build is wrapped up and the standard summer camo applied with the usual approach using AK Real Colors RLM 04, 74, 75 and 76. I preshaded for the benefit of the underside since it will be mostly lost under the winter white on the upper surfaces. I used Eduard's scheme for Hartmann's G-14 as a guide for the camo.
The winter camo is next!
    July 2019
Posted by Hoss WA on Sunday, January 5, 2020 12:30 PM
I made some more progress on Hartmann's winter Gustav.
First, the standard camo was cleaned up a bit. I wanted some scalloping on the leading edges of wings to show through the winter camo, so I added the effect to the standard scheme before the white.  I also masked and painted the wing walk boundaries and trim tabs in red since I thought having these show through in places under the white camo would add some interest.
Next, I added the white in uneven streaks, mottles and patches, with the underlying camo showing between the patches. I used AK real colors flat white thinned (1:2, paint:thinner) with AK thinner. It sprays very thin so it was very easy to control the opaqueness of the white areas.
After 2X coats of Tamiya X-22 clear gloss thinned 1:1 with Mr. Color Leveling Thinner, I sprayed a coat of 100% MCLT, which resulted in a nice surface for the decals. The AIMS "Tulip 109s" decals went on without a hitch.
Next I'll spray on another thin coat of gloss over the decals, clean up the camo and tulip markings, and start panel lines and more weathering.
Thanks for following along.
    August 2009
Posted by TREYZX10R on Sunday, January 5, 2020 1:42 PM
Wow thats looking amazing!!!
    July 2019
Posted by Hoss WA on Sunday, January 5, 2020 7:23 PM
TREYZX10R
Thanks Trey! Much appreciated.
    February 2012
Posted by lawdog114 on Tuesday, January 7, 2020 1:54 AM
Nailed it!...........love the stand too.
    July 2019
Posted by Hoss WA on Tuesday, January 7, 2020 9:41 PM
lawdog114
Thanks Lawdog!
    June 2014
Posted by BrandonK on Wednesday, January 8, 2020 10:12 AM
I agree with Joe. You nailed it. This is exactly the look the pics have and most likely the way the bird was painted IRL. Super nice work there.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2019
Posted by Hoss WA on Friday, January 10, 2020 6:43 AM
BrandonK
BK
Thanks BK!
    November 2008
Posted by plasticjunkie on Friday, January 10, 2020 8:13 AM
Mr. Color thinner is fantastic mixed with the Tamiya paints. That is one gorgeous looking 109. Beer
    November 2003
Posted by tempestjohnny on Friday, January 10, 2020 10:45 AM
I agree with everybody. Perfect rendition if the scheme
    July 2019
Posted by Hoss WA on Sunday, January 12, 2020 12:31 AM
plasticjunkie
Thanks plasticjunkie! I've only tried MC with the gloss - I'll have to try with the colors as well. Thx
    July 2019
Posted by Hoss WA on Sunday, January 12, 2020 12:32 AM
tempestjohnny
Thanks tempestjohnny. Much appreciated.
    July 2019
Posted by Hoss WA on Tuesday, January 14, 2020 7:01 PM
Erich Hartmann's JG 53 Gustav is finally complete! The Revell 1/32 G-6 is a really nice kit and I'm happy with the way it turned out.
After the decals, I kept the weathering light with a medium gray panel line wash and then some brown/black on control surfaces and exhaust. I also added some oil streaks, fuel drips and some minor chipping and wear. Using the reference photos I also recreated the overpainted "7" that was starting to show above the << on the port side.
I decided to have the canopy closed since I really like the lines of the Erla Haube on the Gustav. I also thought a decent base was in order so I created a section of tarmac and added some light micro balloon "snow" with hairspray.
Enjoy the photos!
Posted by Wingman_kz on Wednesday, January 15, 2020 7:04 AM
That's nice! Great pictures. Gonna order that kit today. Tony
    January 2015
Posted by Aggieman on Wednesday, January 15, 2020 8:16 AM
That is hands down one of the best 109s I have ever seen.  And the photos make it difficult to tell I'm actually looking at a scale model rather than the real thing.
    June 2014
Posted by BrandonK on Wednesday, January 15, 2020 10:19 AM
You killed this one. You nailed the paint, as we said before and it shows in the finished pics. Excellent work.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2019
Posted by Hoss WA on Wednesday, January 15, 2020 7:30 PM
Wingman_kz
Thanks Wingman, much appreciated. I recommend the quickboost gun bulges. I used some of the other aftermarket items also, but I think these are the most noticable improvement. Good luck.
    July 2019
Posted by Hoss WA on Wednesday, January 15, 2020 7:37 PM
Aggieman
Thanks Aggieman! I really appreciate your encouraging comments. I really enjoy the photo process and am glad you like them. In fact, I found that photographing the white camo was actually more challenging than usual. Getting the white balance right and matching the lighting intensity with the backdrop took some trial and error. It's easy to both over- and under-expose the shots. Thanks again for the comments.
    July 2019
Posted by Hoss WA on Wednesday, January 15, 2020 7:38 PM
BrandonK
BK
Thanks BK!  And thanks again for your thoughts when I was contemplating the camo scheme. I like the way it turned out. Thanks.
    November 2003
Posted by tempestjohnny on Thursday, January 16, 2020 3:46 AM
BK said it right. You nailed it. Everything looks real
