Century Series #4 - Hasegawa F-104C Starfighter 1/48
    January 2015
Posted by Aggieman on Friday, April 17, 2020 9:07 PM
Continuing my Century Series build lineup, here is my F-104C Starfighter.  The kit is by Hasegawa, and by my calculation, this kit was the oldest remaining in my stash until it made its way to my bench; I bought it when it was released back in the year 2000.
I've always found the Starfighter to be an interesting aircraft.  I believe it was nicknamed the "human missile" or something akin to that.  Certainly, the Starfighter does look like a manned missile.  Plus, those stubby little wings appear to be an after-thought.  I first built a Starfighter back in the '70s when Monogram released its kit, and then I really loved the portions of the movie The Right Stuff that focused on the F-104 (I'm uncertain as to which variant was depicted in the movie but will venture a guess that it was an "A" given that Yeager's character said it was the one they'd been waiting for).
This Hasegawa kit was mostly a joy to build. She went together stress-free until I reached the finicky landing gear, and I actually had some trouble getting the refueling probe attached.  (Photos bear out that last part; I'll have to get back after that in the morning). One other thing that led to a bit of consternation was in the instruction manual.  Following the instructions, you are to install the instrument panel after you have closed up the fuselage.  Eh, whoever wrote that manual should be forced to build it him(her) self based on those instructions, as the IP is far too large to wiggle into the fuselage once the fuselage is assembled.  Luckily, I had not allowed enough time to pass to allow for the Tamiya thin cement to fully cure, and I was able to pry the upper half apart just enough to get the IP into position.
This one was built entirely out of the box, including using Hasegawa's incredibly busy decal sheet.  In an aside, is it just me, or do Hasegawa decals kinda suck?  It seemed I had to soak each of those in water for way too long, and even then they fought me releasing them from their paper backing.  In any event, I really liked both decal options, but when I found this photo
I decided that was my build.  I found the markings to be whimsically colorful even though I knew that many of those decals were going to be patience-trying efforts to get into place.  And, as it turns out, I mis-placed the forward colorful striping band and did not realize my mistake until it was too late to lift that decal up and place at the trailing edge of the nose cone.  This mistake meant that everything else was mis-positioned as well right up to the air intakes.
Painting included Tamiya and Model Master Acryl (gunship gray, NATO green, khaki, semi-gloss black) for the cockpit, Model Master Metalizer Aluminum for the wheel wells, and Vallejo red for the tail.  The primary metallic paint came from AK Interaction Xtreme Metal - polished aluminum, with the stabilizers white aluminum and a few other areas in dark aluminum.  I used Mission Models burnt iron for the exhaust pipe and applied some Tamiya clear yellow and clear orange to replicate a slightly burned metal appearance.
I had intended to weather this one just a bit, but altered my plan to no weathering at all when I noticed that, in handling the painted fuselage while applying decals (I left the wings off until the very last step), I was rubbing off some of the polished aluminum paint.  I did not seal the paint job with anything as I wanted to maintain that awesome shiny metal appearance, so now I need to research what sealant I should use with XTreme Metal paints.  Since I clearly did not know enough about these paints, the last thing I needed to do (after doing all those decals) was to do my normal wash with either Flory dark dirt or Mig washes and then see the paint wipe away when I went to remove most of the wash.
Anyway, on to the build photos:
I found the idea of the white-walled tires to be fitting for this aircraft.
Next up in the Century Series is, of course, the F-105 Thunderchief.  I will be building two of them, one Monogram's ancient 1/72 kit that came pre-painted, and the other of more recent vintage, Hobby Boss's 1/48 kit.  Both are "D" variants.
    July 2004
Posted by stikpusher on Friday, April 17, 2020 9:35 PM
Lord that is one gaudy F-104. Right down to the red rims and white wall tires! Very nice build!
I cant wait to see your F-105!
btw, the F-104 flown by Yeager as shown in The Right Stuff was the NF-104A, a modified aircraft equipped with a rocket motor in the tail, enlarged flight surfaces, and reaction control thrusters for use when the air was to thin at high altitude for the flight control surfaces to work. It was used to train for the X-15 program among other things.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by keavdog on Friday, April 17, 2020 10:11 PM
Nice job.  Really like this theme build.
Thanks,
John
Posted by jeaton01 on Saturday, April 18, 2020 12:43 AM
Very nice Stephen.  I don't think I'll ever be able to build any of George Lavin's airplanes, just too outlandish for me and besides I have this phobia about whitewall tires on airplanes.
The 104 was called "The Missile with the Man in it".
John
    January 2015
Posted by Aggieman on Saturday, April 18, 2020 8:13 AM
stikpusher
Thanks Stik!
That explanation makes sense for the movie, as I recall Yeagar took that bird straight up to the edge of space before he lost control and we see him coming out of the desert with the burning wreckage in the background (all to the rousing musical score by Bill Conti).  I'm guessing scenes involving pilots walking away from wrecked aircraft with rousing scores in a desert works, as Independence Day emulated that scene very well also.
    January 2015
Posted by Aggieman on Saturday, April 18, 2020 8:17 AM
keavdog
Thanks John.  The Century Series lends itself to this kind of build sequence.  I am actually longing for some props again, but I'm sticking to my plan here.  But even when I complete the F-106, I'm sticking with the jets for one more build, as I have an F-111A Aardvark ready to go.  Then back to the props.
    January 2015
Posted by Aggieman on Saturday, April 18, 2020 8:20 AM
jeaton01
Thanks John!  I've always liked the colorful stripes the early jets often wore, but yeah, this one is a bit much. It's gaudy, as Stik said.  And those tires are one-of-a-kind for an aircraft.  The -105's I'm getting ready to build will be in SEA camouflage.
    August 2013
Posted by Jay Jay on Saturday, April 18, 2020 8:37 AM
This looks to be a subject every modeler aspires to...a flawless build. WOW that looks great !
    January 2015
Posted by Aggieman on Saturday, April 18, 2020 9:01 AM
Jay Jay
Thanks Jay!  (But trust me, she is not flawless)
    October 2019
Posted by Tanker-Builder on Saturday, April 18, 2020 9:11 AM
AHA ! The Missile with a Man in it !
     Always did like the 104. I even took some Snark missile kits afterward and created fighters out of them!
Posted by rangerj on Saturday, April 18, 2020 10:04 AM
Great job on a great airplane. The F-104 had red leading edge protectors on the leading edge of the wings when it was on the ground to protect the ground crew from getting cut.  The early models had an ejection DOWNWARD due to the high stabulator. Later seats were able to eject upward. The F104 was the first to have the 20MM vulcan cannon (Gattling Gun) and it caused flame-out due to the exaust gases from the gun when it was fired. That problem was fixed and once the U. S. decided that guns on fighter aircraft were necessary, as missles were not getting the job done, we now see modern U.S. military fighter aircraft armed with said cannon. Most, if not all, NATO countries flew the F-104 and loved it. I think it was the first to be able to do mach 2, anyone?
Again you did a great job on the build and a very nice tribute.
    April 2015
Posted by Mopar Madness on Saturday, April 18, 2020 11:30 AM
Oh wow, I really like the metallic finish!!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    June 2014
Posted by BrandonK on Saturday, April 18, 2020 11:58 AM
Spectacular work. It is amazing how good this bird looks.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Saturday, April 18, 2020 12:09 PM
Aggie you nailed it man. I love the 104's look, looks fast sitting there. I wanted a 1/48 to go with my other Century Series ones but wound up with two 1/72 ones.
Beautiful build! Beer
 GIFMaker.org_jy_Ayj_O
    January 2015
Posted by Aggieman on Monday, April 20, 2020 8:48 AM
rangerj
Thank you for your kind words Ranger!
Quick research on the first aircraft to do Mach 2 reveals it was the Douglas D-558-2 Skyrocket on 20 November 1953, piloted by test pilot Scott Crossfield.  Crossfield's flight was not level-flight, however, so there is that possible asterisk.  Just a few weeks later, Chuck Yeager crossed Mach 2 in level flight in the X1-A.
    January 2015
Posted by Aggieman on Monday, April 20, 2020 8:49 AM
Mopar Madness
Thanks Chad!
    January 2015
Posted by Aggieman on Monday, April 20, 2020 8:50 AM
BrandonK
BK
Thank you for your kind words Brandon!
    January 2015
Posted by Aggieman on Monday, April 20, 2020 8:51 AM
plasticjunkie
Aggie you nsiled it man. I love the 104's look, looks fast sitting there. I wanted a 1/48 to go with my other Century Series ones but wound up with two 1/72 ones.
Thank you for your kind words, plasticjunkie!  I agree, the -104 looks fast sitting still.
    February 2011
Posted by knox on Monday, April 20, 2020 10:46 AM
  Wow!  You did a great job on your plane. I actually like the flamboyance once in a while.
    July 2014
Posted by modelcrazy on Monday, April 20, 2020 10:58 AM
Agreed, I like a little whimsy on occasion.
Steve
Posted by CapnMac82 on Monday, April 20, 2020 6:03 PM
Superb build, especially for the whitewalls.
The Manned Missile had a reputation as a bit of a widow-maker for young, new, pilots.  Apparently, for the position of the wings, aft to get them out of the mach shock cone, meant that, in certain conditions whhile low and slow, you'd get a "single wing" stall.
Or, that's what I reemember reading from long ago.
    January 2015
Posted by Aggieman on Monday, April 20, 2020 6:20 PM
knox
Thanks Knox!  I'm typically pretty conservative and drawn to more "normal" subjects, so it will likely be quite a long while before I'd do another flamboyant scheme like this one again.
    January 2015
Posted by Aggieman on Monday, April 20, 2020 6:21 PM
CapnMac82
Thank you for your kind words, Captain!
    November 2003
Posted by tempestjohnny on Tuesday, April 21, 2020 5:30 AM
Wow. You nailed it. Col. Laven was known for his gaudy schemes. I have the decals for his F-84. I think it's more flamboyant then the 104.
    January 2015
Posted by Aggieman on Tuesday, April 21, 2020 2:23 PM
tempestjohnny
Thanks for your kind words, Johnny!  I just took a look at his F-84 and his F-100. Both do look more ostentatious than his -104.
