Hobby Boss 1/48 F4F-4 Wildcat Completed...
    June 2017
Posted by fotofrank on Tuesday, April 21, 2020 1:22 PM
I'm finishing up a Hobby Boss 1/48 F4F-4 Wildcat. I'm also attempting a new technique: painting insignia. A friend who has a stencil cutting machine scanned the kit decals and made stencils for me. The finished model will depict a Wildcat that flew off Guadalcanal in late 1942, early 1943. I was more than a little intimidated attempting this but I did meet with success. The insignia aren't perfect but the insignia painted on these airplanes 70+ years ago weren't perfect then either so I'm not going to couch them up. have a look, tell me what you think. Thanks.
OK. In the stash: Way too much to build in one lifetime...
    November 2003
Posted by mississippivol on Tuesday, April 21, 2020 3:41 PM
From what I can tell, they look good. I'll never attempt it, but it's a better look than decals.
    April 2015
Posted by Mopar Madness on Tuesday, April 21, 2020 4:32 PM
Great idea Frank. My wife has a stencil cutting machine, I never thought about doing something like this.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by jeaton01 on Tuesday, April 21, 2020 5:47 PM
Looks pretty good, Frank.  I use my stencil cutter all the time.  I've found that a doing star in a blue field with no surround is one of the harder ones to do becuase the tips of the stars run right to the edge of the circle.
I do think the blue is a little light for insignia blue, but it could be just the exposure of the photos.
John
    June 2017
Posted by fotofrank on Tuesday, April 21, 2020 6:50 PM
Jeaton, after applying the stencil I sprayed the circle Tamiya flat white then laid the star cutout over the circle and sprayed Model Master Insignia Blue thinned 2/1 thinner to paint so the blue might be a little light.
Mopar, as I understand it, the stencil cutter has scanning software, so if you have a scanner/printer, you should be able to scan a kit's decals and then import the data into the cutter and make stencils.
mississippivol, the process is easier than I thought at the outset. Applying the stencil can be tedious though, but the results are worth the effort.
I have an Airfix P-40B and a Hasegawa Bell P-400 I'll be painting instead of decals.
Thanks, y'all for looking in.
    June 2017
Posted by fotofrank on Wednesday, April 22, 2020 11:40 AM
I painted the topside insignia this morning. This time around the process was a little easier. I still need more practice though.
Posted by jeaton01 on Wednesday, April 22, 2020 12:19 PM
Frank, a scan generates a bitmap, which is all dots.  Cutters need vector files, which are lines and arcs, so there is an intermediate step done in a drawing program where the lines are drawn over the scanned bitmap file, and then that vector drawing goes to the cutter.  There are some programs that claim to do this automatically but the rub is that I almost never scan anything that I like well enough to use without adjustments.
John
    July 2018
Posted by Tickmagnet on Wednesday, April 22, 2020 12:49 PM
Looks fantastic. Painting them on is the only way to go, and once you've done it you will never go back. I made the mistake of trying some decals after I was well practiced at painting, just to keep that skill fresh. Big mistake bad decals and it looks like crap. Never again. Keep on painting them it's much more rewarding.
    June 2017
Posted by fotofrank on Wednesday, April 22, 2020 4:47 PM
jeaton01
John, what software application do you use to make your vector files for the cutter? Do you scan in Photoshop and import the file into Illustrator to make your vector file and that's what goes to the cutter?
Posted by jeaton01 on Thursday, April 23, 2020 12:09 AM
Frank, I'm a long time AutoCad user so that's what I use.  An older version of Corel Draw would be a good and fairly inexpensive vector program, it comes with Photopaint which is an image editor.
My Cameo likes dxf files, any vector program that will output those should work, and the Cameo has a vector drawing ability in its software.  It can work with bitmaps for the purpose of tracing over them.  My scanner software can be called from the Cameo software so it is simple to scan in directly, or you can open a saved scan image from your computer.
John
    June 2017
Posted by fotofrank on Wednesday, April 29, 2020 12:04 PM
OK, here it is -- finally completed. Hobby Boss F4F-4 Wildcat. This build is strictly Out-of-the-Box. No added ingredients. The model depicts the a Wildcat of VMF-223 Guadalcanal, 1942, flown by Capt. Marian Carl. I did try to broaden my skills with this build. A friend made stencils for me for the national insignia. The insignia on the upper and lower sides of the wings are painted, something I am going to try continue to do with future builds. The insignia on the fuselage sides are decals though. I was unsure the stencils would adhere to the compound curves of the fuselage. Solvaset did the job with the decals, every rivet and panel line shows through nicely. The underside is Model Master Neutral Grey enamel and the topside is Model Master Medium Blue enamel. The propeller and tires are painted with Tamiya Rubber Black acrylic. Everything was sealed with Testors Dullcote. Before the Dullcote I experimented with oils to age the paint and dirty up the airplane. Actually a pretty tedious job but I think the overall effect shows an airplane that was heavily used. Next up is another Cactus Air Force airplane: a Bell P-400 Airacobra. Thanks for looking in. As always, your comments and critique are welcome.
Posted by keavdog on Wednesday, April 29, 2020 12:09 PM
Nice job Frank.  The stencils came out really nice - I have yet to try that.  Got to love the undercarriage of the wildcat!
Thanks,
John
    July 2014
Posted by modelcrazy on Wednesday, April 29, 2020 12:37 PM
Supper job Frank. Well used cat.
Steve
    July 2019
Posted by Hoss WA on Wednesday, April 29, 2020 1:02 PM
Congrats. Looks great. The painted on markings are very nicely done.
    May 2013
Posted by Greg on Wednesday, April 29, 2020 1:10 PM
Turned out nice, Frank. Sorry I'm late to the party.
I like this model of Hellcat, with the unusual landing gear configuration.
Thanks for sharing your build of the Hobbyboss kit.
    June 2017
Posted by fotofrank on Wednesday, April 29, 2020 1:47 PM
keavdog
Yeah, keavdog, you hafta wonder how the landing gear could withstood the abuse of a carrier landing. The landing gear is operated manually by the pilot. Twenty-nine turns of the crank to get the gear up and 29 turns to get the gear down.
    June 2017
Posted by fotofrank on Wednesday, April 29, 2020 1:51 PM
modelcrazy
Building the kit was no big deal but the weathering was tough. I had to touch up quite a few spots because I rubbed paint off handling the model during the process.
    October 2004
Posted by Allen109 on Wednesday, April 29, 2020 4:16 PM
Looks great, Frank! Little jealous. Been wanting to do stencils and paint for national markings for years. My problem is being intimidated by German balkenkruez! 3/4 of my aircraft are ww2 German
    April 2015
Posted by Mopar Madness on Wednesday, April 29, 2020 5:05 PM
That looks awesome Frank!
Chad
On deck: Who knows!
    July 2018
Posted by Tickmagnet on Wednesday, April 29, 2020 5:30 PM
Looks great.
    June 2017
Posted by fotofrank on Wednesday, April 29, 2020 8:16 PM
Allen109
Thanks, y'all. I was pretty nervous about using the stencils mostly because it's something new for me but I like the result. My friend made stencils for the Bell P-400 of the 67 Fighter Squadron, 347 Fighter Group on Guadalcanal and for a P-40B of the Flying Tigers. I also have stencils for the camouflage patterns as well. I sure hope this all works well.
Allen, it's like jumping into a cold swimming pool -- ya just gotta do it.
    December 2018
Posted by Tosh on Wednesday, April 29, 2020 9:02 PM
What a fantastic build, I love the weathering!
Be safe, Stay healthy, Toshi
Reside in Streetsboro, Ohio
    June 2013
Posted by bvallot on Wednesday, April 29, 2020 9:24 PM
Very cool Frank. I love the Wildcat. One of my favorite subjects. HobbyBoss did a much better job with the landing gear bay compared to Tamiya. Your painted insignias came out great. That's the only way I do insignias now. It makes all the difference. I hope you stick with it. ;)
On the bench:
Tamiya F4U-1  Kenneth Walsh
Posted by jeaton01 on Wednesday, April 29, 2020 10:34 PM
Came out great, Frank.
John
