Hot summer, cool fighter. 1:72 Bf-110C4
    June 2010
Posted by rocker286 on Wednesday, July 15, 2020 9:05 PM
The weather last week was brutal here in my neck of the woods. And as an HVAC tech, when the temps soar or plummet, I'm busy! As a result I haven't had much workshop time. But, this week has been more mild and I've found some time to sit down at my bench and work. A few weeks ago, I started on a Bf-110 kit from Airfix. And since we're due for some more heat at the end of this week, I've decided to give this plane a winter camo scheme. Heck, I may even try out that hairspray technique that everyone's always talking about! The build has been pretty straightforward, except for some fit issues regarding the fuselage and cockpit. The cockpit is just a bit too wide for the fuselage it seems, and even a bit of sanding didn't seem to solve the problem. As a result, there is a small gap just forward of where the windscreen will sit. Nothing a little filler won't fix, however. More progress pictures to come!
20200511_222649
2020-07-14_04-32-47
2020-07-14_04-35-28
4badges
    April 2015
Posted by Mopar Madness on Wednesday, July 15, 2020 10:19 PM
It got up to 102 here in Dallas last weekend. Plenty HVAC trucks running about these days!  I'm a sucker for a nice 110.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    June 2008
Posted by lewbud on Thursday, July 16, 2020 1:14 AM
Rocker,
I recently finished mine for the Shelf of Doom group build.  It's a fairly easy build, but here are a couple of tips for you.  One, get the Eduard canopy mask if you haven't got it already.  It will make your life so much easier.  Two, don't think you can assemble the exhausts after everything is painted.  There is a sizeable gap between the exhausts and the nacelles which will have to filled with strip styrene.  Plus you run the risk of losing a set inside the nacelle, not that I'd know anything about that Whistling.  Be careful installing the nose guns.  They're a very tight fit and you may bend or break them.  Finally, the decals are pretty much crap. They are thick and mine silvered even though I shot a smooth gloss coat for them to lie on, and Micro solled and set the heck out of them.  They did look better once I applied a coat of flat over them though.  It's also missing the towel rack antenna underneath, but in the end it looks like a Me-110.  I look forward to seeing your build.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    June 2010
Posted by rocker286 on Tuesday, December 1, 2020 8:53 PM
Lewbud,
First off, my apologies for getting back to you MONTHS after you first commented. I did indeed get the Eduard mask set and saved myself the agony of trying to mask that canopy using just yellow tape! Those guns were a bear to install as well. But, the good news is my 110 is (structurally) finished, and I'll be painting it tomorrow! I would have started tonight...but right after I got finished masking off the bird for it's first coat of RLM 65...the day caught up with me. And heck, I even got outta work early tonight! Guess I need more sleep. Here is a progress picture of the 110!
2020-12-01_09-38-23
4badges
    November 2003
Posted by tempestjohnny on Wednesday, December 2, 2020 7:21 PM
I've got this in the stash. Built the E at the end of last year and really liked it
    June 2010
Posted by rocker286 on Tuesday, January 25, 2022 6:54 PM
Johnny, is that the one with North African campagin markings?
Also, holy smokes, I seemed to have straight up forgotten about this forum! My apologies. I have long since finished my Bf-110. It turned out fantastic! I added a PE gunsight from my spare parts stash to the rear MG. The wasp decals were a bit tricky, and I had to position them a bit aft of the gun muzzles in the nose (which is not the historically-accurate placement of the decals), but I was still super pleased with the outcome. I took two straight pieces of poster putty - straight from the box- carved sandbang seams into them and turned them into an AA gun position. The AA gun and crew were from a Zvezda kit that I built darn near ten years ago, but put back into my toolbox to await the perfect diorama. The same goes for the kettenkrad, which came from an Academy Bf-109 kit. I lightly misted both the AA gun and the ground vehicle with white paint to give them some form of winter camoflauge. The snow is woodland scenics, as is the evergreen tree. I cut out pieces of construction paper and tailored some winter coats for the gun crew. The Bf-110 is definitely right at home in this scene, at an airfield somewhere on the Russian front. Thanks to all of you for your kind words- as always!
2021-08-13_10-14-12
20210503_225846
20210411_213709
20210503_225904
20210709_172621
20210709_172757
20210709_172704
20210709_172652
20210709_172621
4badges
