1/48 Tamiya Dewoitine D.520 GC II/7 2nd Esc (Finished)
    February 2012
Posted by lawdog114 on Thursday, September 24, 2020 2:07 AM
This is a subject I would probably never build on my own.  I'm just not into French aircraft I suppose nor do I know much bout their Air Force during the war.  From what I read, the D.520 was somewhat capable against the Bf109, but it was never made in sufficient numbers to be effective.  I've been tasked with building it none-the-less.  The good news is the kit is Tamiya and it sports a pretty sweet looking paint scheme. Anyways, I figured I'd share it.
Again, I don't know much about French aircraft, so I used Tamiya's paint recommendations throughout.  I used Tamiya XF-24 Dark Grey for the pit. I threw in a set of PE belts from the stash.
I used the kit IP decal and with some supporting detail painting, I was happy with it.
I got here pretty quick.  What an ugly plane.
I'll be doing the middle subject, the black panther #4.  I will unfortunately have to use these decals which are 25 years old.
I started by preshading the panel lines then sprayed the rudder the tri-color of red white and blue.  I taped that off then sprayed the Tamiya recommended XF-25 Light Sea Grey and XF-2 White for the lower.  With all the colors, I used the light/dark reverse basing technique.  I find it effective for weathering.
I used Blue Tac for the demarcation lines then sprayed the first of three colors, 2 parts XF-23 Light Blue and one part XF-25 Light Sea Grey.
I used more blue Tac as masking then fired down the green by using XF-5 Green and a few drops of XF-49 Khaki.
I use cheap painters tape for fill in.  Tamiya tape is too expensive.
Next I added the brown, about half XF-52 Flat Earth and XF-64 Red Brown.
It's fairly neat scheme but I was happy when it was over. The rudder painting turned out ok I think.  Much better than trying to use the decal.
I did some postshade weathering, added some exhaust staining, then glossed it with X-22/MLT for decals.  The decals were quite thick and required a half a bottle of Micro Sol to get them to behave. I chalked it up to their age as I normal don't have issues with Aeromaster.  I gave the panelines a Mig wash and that's where I left off.
    August 2015
Posted by crown r n7 on Thursday, September 24, 2020 2:54 AM
very smart paint job..Yes
 Nick.
    February 2012
Posted by lawdog114 on Thursday, September 24, 2020 3:44 AM
crown r n7
Thanks...
    November 2003
Posted by tempestjohnny on Thursday, September 24, 2020 5:48 AM
The Aeromaster sheet I used for Daddy's Girl was an earlier number then this one and was great.  Might be something to do with the colors for how thick they were
    June 2013
Posted by bvallot on Thursday, September 24, 2020 7:11 AM
Ugly plane or not, when she's dressed up and shiny she still looks ready to dance.
I see you bouncing back and forth between the Tamiya paints and HK Real Colors. What's your take on how they work...coverage (opacity), lay down, Thinning required, color accuracy, etc?
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2012
Posted by lawdog114 on Thursday, September 24, 2020 9:10 PM
tempestjohnny
I have the same Daddy's Girl Sheet, so that's good news.  I had to put the fuselage roundels on top of the white arrow, so that may have contributed to my issues.  I should have just painted these on.
    February 2012
Posted by lawdog114 on Thursday, September 24, 2020 9:41 PM
bvallot
I suppose ugly people can dance.  I'm 0 for 2 there though.....lol.
Yeah, after trying several brands over the years (Model Masters, MRP, Mission), Tamiya and AK have become my two primary paints, at least for my needs.  lets see....
1. Tamiya covers great with a touch of alcohol to thin. I use their lacquer thinner as well.  With alcohol it dries very quick, which is great when your concerned with bleed under (such as painting on insignias).  I find these easy to weather due to the dead flat finish of the XF line. I get the 23ml jars so they last a long time.
2. AK Real Colors are my new favorite for scheme specific colors, ie OD over Neutral Grey, RLM colors, etc.  I slightly thin it with their own thinner and adjust accordingly.  It sort of smells like Aqua Net hairspray to me (which I like...I know I'm weird).  It goes down silky smooth....zero pebbling.  I can add Tamiya paint to it for weathering as well, such as Tamiya buff or white as they are completely compatible.  As opposed to Tamiya XF, it dries to a semi matte with a sight sheen. I just got their dark sea blue and intermediate blue for an upcoming Hell Diver.
Hope this was helpful....
    December 2018
Posted by Tosh on Friday, September 25, 2020 9:28 AM
As always sir, congratulations on another fantastic finish!
Your friend's, Toshi & Ezra
Reside in Streetsboro, Ohio
    February 2017
Posted by Tubosteve on Friday, September 25, 2020 10:13 AM
Sure looks pretty to me (and no, I'm not wearing beer goggles.....yet!). Very nice job on the paintwork as usual.
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
    January 2015
Posted by Aggieman on Friday, September 25, 2020 10:44 AM
Wow, you're doing some great work on a little-seen subject.  I agree, French subjects just are not that interesting, but this one bears a little interest in that it did hold its own against the Bf-109s that it encountered in the Battle of France in 1940.  I actually have this kit in my stash, and have long planned to do the one with the yellow-and-red striping on the nose and rudder.
    February 2012
Posted by lawdog114 on Sunday, September 27, 2020 1:48 AM
Tosh
Thanks Toshi. I hope you and the family are well.
    February 2012
Posted by lawdog114 on Sunday, September 27, 2020 1:49 AM
Tubosteve
Thanks Steve
    February 2012
Posted by lawdog114 on Sunday, September 27, 2020 1:50 AM
Aggieman
Thanks Aggie. Great kit, just not really my cup of tea.
    July 2019
Posted by Hoss WA on Sunday, September 27, 2020 8:13 PM
You don't see this subject too often. Excellent progress as usual. Interesting colors.
    December 2018
Posted by Tosh on Monday, September 28, 2020 2:30 AM
lawdog114
Tosh
Thank you sir for asking, we are doing just find.  Each day we are proggresing forward.  I can't ask for more.
    February 2012
Posted by lawdog114 on Monday, September 28, 2020 10:11 PM
Hoss WA
Thanks Hoss.  Truthfully, I never new it even existed until I was asked to build one.
    February 2012
Posted by lawdog114 on Monday, September 28, 2020 10:13 PM
Tosh
lawdog114
Tosh
Glad to here.  Nice to see you back in the forum.
    February 2012
Posted by lawdog114 on Monday, September 28, 2020 10:37 PM
I believe I'm done. Although not really my cup o' tea, it was an easy build, typical Tamiya all the way around.  The toughest part was the camo.  The Aeromaster decals were circa 1994 and I had trouble getting them to settle in. In hindsight, I should have painted on everything except the black panther.  Other than PE seatbelts, brass tube MG barrels and pitot tube, it's out of the box.  Paints were Tamiya mixed and it was weathered with Mig and AK oil washes.  (I got a few MIG washes to compare them to AK, they essentially perform the same way).
I can highly recomend this kit for those interested in this subject.
Posted by jeaton01 on Monday, September 28, 2020 11:39 PM
Nice job, Joe.  I have the same bias against French WW II airplanes, but this one and the Dewoitine 500/510 series seem to possess some elegance.  Unlike all those airplanes designed by Bloch before and during the war.  No wonder he changed his name to Dassault after the war!
Nice job here, once again.
John
Posted by jeaton01 on Tuesday, September 29, 2020 12:03 AM
Duplicate post
John
    May 2006
Posted by Shipwreck on Tuesday, September 29, 2020 11:11 AM
Lawdog114, that is a really neat build, and educational. If someone had asked me what a Dewoitine  is; I would have guessed that it is some kind of paint thinner!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    January 2015
Posted by Aggieman on Tuesday, September 29, 2020 1:59 PM
jeaton01
Right there with you, John.  The D.520 is a good-looking warbird.
Joe, great job on a little-seen build.
    April 2015
Posted by Mopar Madness on Tuesday, September 29, 2020 2:10 PM
another excellent build LD. This is one of those old birds that you just don't see very often. I have one in the stash and I really want to give it a go. I think you really did an amazing job on this one.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    November 2003
Posted by tempestjohnny on Tuesday, September 29, 2020 3:45 PM
And another beauty. One of the few decent looking French WWII aircraft
    February 2012
Posted by lawdog114 on Tuesday, September 29, 2020 10:03 PM
jeaton01
Thanks John
    February 2012
Posted by lawdog114 on Tuesday, September 29, 2020 10:06 PM
Shipwreck
Thanks.  I was thinking a cheap wine or maybe a topical antiseptic.  Oh that's Bactine.
    February 2012
Mopar Madness
Thanks Chad
    February 2012
Posted by lawdog114 on Tuesday, September 29, 2020 10:07 PM
tempestjohnny
Thanks Johnny
