HAPPY NEW YEAR! Work continues on the Stuka. The nose cowl panels have been separated, painted and weathered. The two lower panels that will be on the aircraft fit well once thinned. The panel that goes forward of the sight window did need to be corrected. It did not have the slot for the lower cooler hose.
I will be mounting this on a base that will be accessorized to like an airfield. I already have the base. I ordered ICM’s German Luftwaffe Pilots and Ground Personnel set which has 7 figures (it arrived a couple of days ago) and I also ordered the Tamiya 1/48 German Kettenkraftrad which has a power cart, a maintenance tractor, and two figures. (This is scheduled to be delivered tomorrow.)
With the panels completed I added the landing gear and flaps. The scheme I am doing has the aircraft with RLM 70 SCHWARZGRÜN on top and RLM 65 HELLBLAU on the underside with yellow cowl and yellow rudder. I base coated the aircraft and the bombs. I need to make the decals for this specific scheme then apply them. There are also quite a few photo etch parts to detail the canopy that need to added.
