first of 2 i have starte on in the new year. This is the upgrade option and so comes with resin parts. One problem i have is that i don't have the instructions and none are posted online. But i've built enough 72nd 109's to know where the basics are.
The pit is resin with some PE parts, all painte and weathered before going together.
The fuselage had alredy been put together before i bought it, but the pit went in easy enough after a touch of sanding. The wings are one piece and fitted rather well compared to other MPM aircraft i've built.
The rear instrument panel was higher, triangle in shape. But i did think it odd as it would abscure the instructors view. I found a 48th build on line useing a conversion set and that showed the IP well, and seeme dto better match what little i could make out on photo's. So i cut the top portion off.
So far not a bad kit, typical short run with no inserion tabs, but generally fits nice.
I've since primed and painted the RLM 02 areas underneath.
On the bench: Italeri 1/72nd Bell 212/MPM 1/72nd Bf 109G-12
