1/48 Monogram P-51D "Detroit Miss"
    January 2015
Posted by M. Brindos on Wednesday, February 17, 2021 11:57 PM
I first built and fell in love with this kit when I was 11(?) -ish. I loved the paint scheme, the sliding canopy, and the open panels. I did my absolute best with the small bottles of Testors enamels and it was IMHO at the time one of my best. My current memory reveals how awful that paint job really was lol. I didnt know 1/10th of the tricks I know now and you can imagine just how rough that was lol!
I've been dreaming of doing this kit justice ever since and I found an unopened copy in a hobby shop in Portland I visited about three years ago. I pulled it out quite some time ago and built up the pit right out of the box with no scratch build greeblies except for the gun sight. I glued the fuse together and put it back in the box for another time.
As I pulled it back out of the box the week before last I was only going to build it without modifications but changed my mind. Mustangs always had the flaps lowered when the engine was turned off and the hydraulics lost pressure so I started carefully cutting the flaps off of the wings with my saw. The operation went well but at the time I hadn't thought out how I was going to add the flaps back on in the lowered position. I ended up carefully measuring the gaps while holding the flaps where I wanted them and cutting some Evergreen stock to fit. I dry fit those dang things until I had a perfect fit, over and over again. Everything lined up I made sure of it. Yet, as I went to glue them on I couldn't get them to fit right no matter how well I lined them up. After an hour or so of frustration I gave up and shimmed the gaps to line the flaps up.
That's the only major modification I'm making. The wing root gaps were shimmed with card stock and then I used PPP to fill in the rest. The windscreen was easy enough to blend in with a touch of sprue glue. Its not perfect but I will probably adress it more later. Ive got the nose cone painted because I just had to see if the colors I chose were going to give me the right tone for the finish I'm going for on the nose. Vallejo Game Air Sun Yellow and my own custom mix of Chrome Yellow for highlights. Once again I'm going for subtle modulation.
I spent this evening scribing the engine panels in and sanding things down on the nose. To get the lower engine cover blended in I'll be using the Bondo Spot Glazing putty. It has a pretty good step almost all the way around and I used the sprue glue to build up the edges so I could scribe them before I get to the putty to make it flush. The sprue glue has been really saving me a lot of trouble lately.
Once I get these panel lines cleaned up and the putty plastered on I have to adress the MG ports and the shell casing ejection slots under the wings. I'm in the home stretch after that with just wheels, stuts, and gear bay doors. I'm surprised at how fast I've made progress with this old kit. I have the Revell re-pop in the stash and there's a lot more flash to deal with. But those markings are gorgeous and I'll have to build that one later.
Have a wonderful evening, morning, afternoon, etc. Thanks for checking this out.
- Mike Brindos "Lost Boy"
    May 2004
Posted by cbaltrin on Thursday, February 18, 2021 6:00 AM
Hi Mike, Your Monogram Mustang is looking good.  I did this kit in box markings 4 or 5  years ago... I have to dig up the pictures somewhere... It was the first time I re-scribed an entire model. I filled all the open panels, lengthened the spinner, replaced he guns, you name it.  Just could not bring myself to use the main canopy though.. Had to get a Vac replacement. Did use the windscreen though as I try to keep as many of the original parts that i can when I build these old kits.  Keep us updated. Will be following this build closely !
On the Bench: Too Much
    November 2008
Posted by plasticjunkie on Thursday, February 18, 2021 7:25 AM
Great work Mike on that old mold, all the work will pay off once the paint goes on.
Will you be deleting the panel lines on the wings?
 GIFMaker.org_jy_Ayj_O
    January 2015
Posted by M. Brindos on Thursday, February 18, 2021 11:46 AM
cbaltrin
If you dig up those picture you're more than welcome to post them in this thread. I'll admit the kit canopy is a bit sloppy but I'm also big on using as much of the kit as possible and the kit piece is acceptable. I did get a bit of glue on it, but I've got the other kit for a second try if I can't clean it up.
    January 2015
Posted by M. Brindos on Thursday, February 18, 2021 11:48 AM
plasticjunkie
No, I'm not deleting the wing panel. It's kind of part of my attraction lol.
I'll be getting my hands on one of those new Airfix P-51's soon. That'll be the one I go for the gold standard with lol.
    November 2008
Posted by plasticjunkie on Thursday, February 18, 2021 11:56 AM
M. Brindos
plasticjunkie
Ok cool. I sanded mine off when I built it and used Floquil Old Silver enamel. Why not leave the canopy open since it has a fairly decant pit oob?
I have the 1/32 Revell new tooled Mustang in the stash and the work was done for me by having smooth wing surfaces.
Posted by keavdog on Thursday, February 18, 2021 12:02 PM
Spinner/prop look great!  I can never get yellow to lay down that nice
Thanks,
John
    January 2015
Posted by M. Brindos on Thursday, February 18, 2021 12:42 PM
plasticjunkie
M. Brindos
plasticjunkie
I have the 1/32 Revell new tooled Mustang in the stash and the work was done for me having smooth wing surfaces.
Lol. Half of my Monogram and Revell builds either had the function or I made the canopies functional. Both my Spitfire and my P-40 have sliding canopies. The Zero and the Corsair do not. But I've also painted over the clear parts on those lol.
    January 2015
Posted by M. Brindos on Thursday, February 18, 2021 12:48 PM
keavdog
My trick is to spray desert yellow or tan first so I don't have to build up a thick layer of yellow to get the color saturated. Try that trick, it makes yellow much easier to use. Also, spraying a light grey does the same for white which can sometimes be just as difficult.
It may mean an extra color change for the AB, but it saves you time and frustration later.
    April 2015
Posted by Mopar Madness on Thursday, February 18, 2021 1:47 PM
I really love to see these old classics come together!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    January 2015
Posted by M. Brindos on Thursday, February 18, 2021 9:09 PM
So do I!
I had a Mighty Ducks marathon with my wife today before taking a nap and I didn't get anything done on the kit today except letting sprue glue dry.
I had to fill in one of my scribes because it wandered noticibly in the middle. It wasn't easy keeping those lines straight, but I found that my sanding sticks are flexible enough to use as a guide. I wish I'd thought of it before I got half of the panel lines rescribed.
Only a minor setback. I mean, who wants wobbly panel lines? I'm not putting that kind of work into keeping those panel lines if they're not going to be straight. I'm glad it was just one lol.
    May 2004
Posted by cbaltrin on Friday, February 19, 2021 6:59 AM
Mike,  I posted pictures of my Detroit Miss on  the old  Show us Your Revell Monogram Builds Thread. You can check it out over there.  There seems to be an issue with that thread though as it always gives you an ERROR message at first, but if you Click on the Order by Decending Tab, it seems to fix the issue.
http://cs.finescale.com/fsm/modeling_subjects/f/2/p/134679/2152733.aspx#2152733
Also,  Wobly panel lines are definatley not copacetic! Yes
    September 2006
Posted by the Baron on Friday, February 19, 2021 7:32 AM
Great project, Mike!  I think this kit still holds up well today.  This was from Monogram's golden age.
Yeah, the canopy.  It's like the canopy on their P-47D bubbletop, too.  I use the kit canopies but I pose them open.  Then the fit isn't really that noticable.
Speaking of undercoating yellows, I use white, myself.  I do that for reds, too.  Whatever we use, it really does help to base first.  I've never had a red or yellow paint that didn't benefit from an undercoat.
    November 2008
Posted by plasticjunkie on Friday, February 19, 2021 8:10 AM
the Baron
I also undercoat yellows and reds. White will brighten both while tan will deepen the shade specially yellow.
    March 2012
Posted by mustang1989 on Friday, February 19, 2021 9:37 AM
My hat goes off to you for tackling these older kits Mike. Great work so far. Yes
 Forum | Modelers Social Club Forum (proboards.com)
    August 2015
Posted by crown r n7 on Friday, February 19, 2021 9:51 AM
That does bring back youtful days lol
 Nick.
    June 2017
Posted by Chemteacher on Friday, February 19, 2021 9:51 AM
She’s looking great. That was one of my favorite kits when I built as a teen. Great tip on the undercoating with tan for the yellow. Never thought of that. Thanks so much.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2015
Posted by M. Brindos on Friday, February 19, 2021 2:21 PM
cbaltrin
Gawd, now thats a beautiful build! I keep forgetting about that thread lol. Thank you for sharing that!
    January 2015
Posted by M. Brindos on Friday, February 19, 2021 2:31 PM
the Baron
I always make sure my canopies line up and I've developed techniques that help make that possible. For example, I'm finding that when I modified the canopy on the Banshee that I now have a very large area to cover over the pilot. Ive got some clear acetate that will do the job, but its a much larger opening than the orriginal piece I cut out. I may have to compensate somewhere else to get the dimensions corrected. These are puzzles I enjoy lol.
Now, see, I have issues with getting white to cover properly and thats why I prefer to lay down a light grey first. We all have our little tricks lol.
And youre right, this kit can still hold its own if you give it the effort. I can hardly wait to see how the Airfix kit builds up. Im looking forward to that! lol
    January 2015
Posted by M. Brindos on Friday, February 19, 2021 2:33 PM
mustang1989
They're perfect for skill advancement. Such kits make us all better at building the newer and easier kits that have been released in recent years. I enjoy them a lot.
    January 2015
Posted by M. Brindos on Friday, February 19, 2021 3:05 PM
crown r n7
Oh, very much so, yes.
    January 2015
Posted by M. Brindos on Friday, February 19, 2021 3:08 PM
Chemteacher
My top favorite is still the P-40, but this kit in peticular is a close second. I've got the Stuka and the Confederate Airforce release of the Airacobra too.
And when I get my butt over to Dad's this weekend I'll have the old light blue box release of the Me 109 and the white box release of the 190 to enjoy as well.
You're more than welcome for the painting tip. Anything I do and share is up for grabs lol.
    January 2015
Posted by M. Brindos on Saturday, February 20, 2021 3:10 PM
Well I've made a right, proper mess of things. lol!
 Monogram P-51D by Mike Brindos, on Flickr
Commence hours of sanding...
    May 2004
Posted by cbaltrin on Monday, February 22, 2021 5:13 AM
Next time I would modify those exhaust stacks so they can be inserted after fuselage buttoned up. I think they're going to take a beating Confused
    January 2015
Posted by M. Brindos on Monday, February 22, 2021 9:02 AM
I'd like to find a clever way to handle exactly that, but they designed the exhaust stacks the same way they did for the P-40 where they get inserted early in the build because the tip of the nose goes on after the fuse halves are closed up.
That wouldn't be a problem if the nose tip fit without sanding.
    May 2004
Posted by cbaltrin on Wednesday, February 24, 2021 6:45 AM
I found a way. You have to first create some sort of jig/bracing inside the nose  to hold the exhaust in their proper position.  Then you trim away all the excess backing on the exhaust so it can be inserted from the outside.
BTW, Do you feel a Monogram P-51D group build coming in 2022?  Confused
    January 2015
Posted by M. Brindos on Wednesday, February 24, 2021 2:17 PM
I suppose I should have thought of that. It's the easiest solution and kind of a "duh" answer. I will remember that for the next one.
I wouldn't mind getting into a Monogram Mustang build group. That sounds pretty cool.
    September 2006
Posted by the Baron on Wednesday, February 24, 2021 3:30 PM
That is an excellent idea, regarding the exhausts, both for this kit and for the P-40.  I never thought of it, but that simplifies things.  And that's the best kind of solution-simple.
    March 2012
Posted by mustang1989 on Wednesday, February 24, 2021 8:25 PM
Looking forward to watching you smooth all that out Mike.
    January 2015
Posted by M. Brindos on Friday, February 26, 2021 9:37 AM
mustang1989
I think I've got it almost ready. One more shot of primer should do. I did get stuck playing with one of the kits I got for my birthday, a Monogram Me 109E in the old light blue "quarter scale" box. I'm finding the kit is a joy to build and I'm mostly done and almost ready for primer.
I also received an old "quarter scale" Hawk P-51D coated in an Aluminum finish that is only missing the nose tip, but came with extra decals and an Aires resin cockpit. I'm not so sure the kit needs the Aires upgrade, but it's beautiful and I may just build it for display along side my mustangs.
I will be uploading pictures later.
