Flying vs gear down-What is your preference?
    February 2021
Posted by MJY65 on Tuesday, March 9, 2021 9:46 AM
I've built the majority of my airplanes on stands, gear up and nose high.   I think planes look alive displayed that way.  OTOH:  A lot of the detail in great modeling takes place in the cockpit and gear wells.   What's your preferred build and display for modern jets?
Posted by Tojo72 on Tuesday, March 9, 2021 10:00 AM
Always wheels down for me
    January 2017
Posted by mawright20 on Tuesday, March 9, 2021 10:19 AM
Always gear down to show off details
    June 2018
Posted by DRUMS01 on Tuesday, March 9, 2021 10:24 AM
It depends on the aircraft, level of detail on the model, size of the kit, and space to display it. Another important consideration is the intended vision of the end result, specifically if the cockpit is hyper detailed with no pilot and access panels are open to show additional detail, then gear down is a must. However, if it is a classic kit of a sleek aircraft but lacking detail then seeing her in flight might be the better option.
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    June 2017
Posted by fotofrank on Tuesday, March 9, 2021 10:57 AM
For me it depends on the airplane. Generally, propeller airplanes I pose sitting on their landing gear. As for jets, I generally pose them in flight. Jets just look better posed in flight. I do have a Bandai Star Wars A-Wing and an X-Wing on the shelf and they are definitely posed in flight.
OK. In the stash: Way too much to build in one lifetime...
    May 2011
Posted by Real G on Tuesday, March 9, 2021 11:16 AM
Wheels down.  Otherwise, my arms get tired.  Stick out tongue
That being said, I was mulling this very subject when I was looking at my unbuilt sci-fi and Japanese anime aircraft.  Some of them have dumb looking landing gear that detracts from the sleek flying form.  I had built a police helo from the anime "Bubblegum Crisis", and it's landing gear design was really impractical, both in terms of visual aesthetics as well as actual strength.  So I finished it gear up and stuck it on a pole.
For me, a stand should be simple and not distract attention away from the model.  But again, sci-fi/anime subjects can be enhanced by stands with some relevant detail (like the Bandai Star Wars kits with the Death Star tiles).  I used a dressed up Fine Molds Y-Wing stand for the anime helo, the "AIC" being a homage to Artmic, the outfit that did the animation for Bubblegum Crisis.
“Ya ya ya, unicorn papoi!”
    July 2014
Posted by modelcrazy on Tuesday, March 9, 2021 11:40 AM
It depends what I'm trying to show. An Ospray for example looks better in flight, or say a P-40 in the process of retracting it's gear. Otherwise it's gear down. Ships and seaplanes on the other hand, almost always on the water and not on a stand or gear.
Steve
    May 2013
Posted by hogfanfs on Tuesday, March 9, 2021 12:00 PM
I prefer gear down, cockpit open. But, as many have already stated, it depends on the subject.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    January 2015
Posted by Aggieman on Tuesday, March 9, 2021 12:18 PM
There are a few factors in play for me:  1) Subject matter, 2) Size of kit, 3) Available space for display, and 4) My mood.  Generally, 1/48 4-engine heavies are automatically wheels up since those are going to hang from the ceiling of my work room.  Most builds will be wheels down, but for #4, my recent XF5U-1 Flying Flapjack is a good example of how my mood came into play.  The kit definitely fits for wheels down per #s2-3, but I just didn't feel like dealing with the gear (adding detail to the bays, stuff like that, because there weren't a lot of photos that I could find that showed off those areas on the very few of those airplanes that were actually built) - so now that small disc-airplane hangs along side a couple of 1/48 medium bombers (A-20 and B-25).
Posted by keavdog on Tuesday, March 9, 2021 12:34 PM
Sometimes both Stick out tongue
I like airliners in flight, but still do 1/2 of them on the ground.
Thanks,
John
    April 2020
Posted by Eaglecash867 on Tuesday, March 9, 2021 1:10 PM
Gear down and opened up to show all of the internal details.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    May 2006
Posted by Shipwreck on Tuesday, March 9, 2021 1:13 PM
Good question! Most of my aircraft are wheels up on stands, except my B-29 which is suspended. You miss a lot of detail with the wheels up; so I have been considering wheels down in flight. I have seen several modelers who have there models hanging form the ceiling with their landing gear down! How do you all feel about That idea?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
Posted by Bish on Tuesday, March 9, 2021 2:54 PM
As all my aircraft are on bases, and usually in diorama's, its always wheels down.
    February 2021
  • From: Northern Ireland near where they sell Guinness
Posted by Kitwrecker on Tuesday, March 9, 2021 3:21 PM
I personally like both some jets look better than others with the gear down in my opinion I don't have a preference so I intend to do another Tornado but on a stand and the other Tomact I have on wheels. If it's a cheap kit without much detail like my Italeri Tomcat then wheels up canopy down and still looks good I think.
These are the only model aircraft I have and so I'm almost 50/50 stand to wheels. I'm doing an F-16 at the moment which will be gear down.
fox
    January 2007
Posted by fox on Tuesday, March 9, 2021 9:18 PM
Always wheels down unless the landing gear is broken.
Jim Captain
Stay Safe.
 Main WIP:
    July 2004
Posted by stikpusher on Tuesday, March 9, 2021 9:58 PM
Once upon a time, I did nearly all of my aircraft builds wheels up and in some sort of inflight mode. Nowadays I prefer the wheels down, open cockpit look, armed up, and ready for the pilot. On carrier based aircraft, if the kit offers the option for folded wings, I like that look. But I've seen some great in flight stuff with jets, especially on some sort of clear rod coming from the exhaust as a support stand, that are quite tempting to try.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Wednesday, March 10, 2021 12:02 AM
Kind of like, "Ginger or Maryanne?".
Whats not to like either way?
Bill
Posted by Don Stauffer on Wednesday, March 10, 2021 7:56 AM
I do both, though 90% gear down.  If I do go gear up, I find a likely geographic spot, and use Google Earth to download an image of the scenery.  I make a decal of that, apply it to the top of the base, and mount the model on a clear plastic rod.
For prop planes I have found a way to scan the kit prop, run the image through a rotational blur filter, and print it as a decal.  I then apply the decal to a disk of clear plastic and mount that to the kit hub or spinner.
    July 2014
Posted by modelcrazy on Wednesday, March 10, 2021 9:54 AM
I like that idea of the scenery Don. I really don't care for the PE prop blur but don't mind too much making my own. I'm still working a realistig way og making it look like the prop is spinning. Using nothing at all like on the P 40 above actually looks prety convencing to my eyes.
Steve
    August 2016
Posted by Keyda81 on Wednesday, March 10, 2021 9:50 PM
Out of all my currently done builds on display, which I think is around 50, only one has the gear doors closed.  I suppose it depends how I plan to display it.  Most of my builds are either hung from the wall by their tail, or they are on a shelf, or in a cabinet.  Which requires wheels down.  I try if I can to display them in "static" mode.  Wheel chocks, remove before flight tags, or the like.  I do have the plan of doing an flight C-47 Skytrain one of these days.  It will be gear up with LED's and spinning props.
Posted by Don Stauffer on Friday, March 12, 2021 7:18 AM
modelcrazy
Do you have a decent graphics program on your computer?  If so, check whether it has a rotational blur filter.
    August 2014
Posted by Timdude on Saturday, March 20, 2021 11:00 AM
I love the P-40, that looks great
