Revell 1/48 P-47N Thunderbolt
    January 2015
Posted by Aggieman on Monday, April 26, 2021 5:19 PM
I'm not sure what prompted me to pick this kit up given that I still had two unbuilt Tamiya 'Bolts in my stash at the time.  Perhaps it was the N variant, which I'd never built previously.
The kit began life as a Monogram Pro-Modeler offering back in the late '90s, but I got the Revell re-box circa 2012.
I opted for the box-art markings. Interesting story on this 'Bolt - "Li'l Meatie's Meat Chopper" was piloted by Lt. Oscar Perdomo, who was WWII's last "ace-in-a-day" after downing 5 aircraft over Seoul, Korea on 13-August-1945.
Despite an unusual molding choice with the main landing gear, this is a good kit.  Went together with a minimal amount of fuss, and just a smidge of filler in the usual places. The unusual molding is that the struts are a part of the rear gear well wall.  One would have to do some plastisurgery to display wheels up; wouldn't be a big deal, but that was not on my radar for this build.  The kit comes with two wing-mounted drop tanks, 8 rockets, and 2 bombs.  All of the rockets had major dimples, and they didn't really look that good despite the dimples.  The bombs looked okay, and the drop tanks include a simple decal but no molded detail for the fueling receptacles.  Wasn't too bothered by that.
Paints are Vallejo for the chrome yellow tail and stripes, and prop tips, aluminum for  the struts and wheels, and tire black for the 3 tires; Mission Models black for the prop blades, and AK Interactive XTreme metallics for the drop tanks and aircraft surfaces. Cockpit is AK Interactive real colors dull dark green, and the wheel wells are Model Master acrylics yellow zinc chromate.  The blue rudder stripe is Model Master French blue.  I encountered some weather-related issues with the NMF finish, in that I put down a coat of Alclad black primer and allowed to set over night.  I put down the base coat of AK dark aluminum, and after that had dried over night, I noticed a tacky feeling to the paint.  Best I can figure is the humidity we've seen here in SE Texas the last several days impacted proper curing of the paint.  I got some good advice on how to handle the issue, but patience is not always something I have enough of, and opted to spray the build with Gauzy Intermediate, a gloss coat. After that dried over night, the tacky feeling went away.
I sprayed a few panels and the ailerons white aluminum, picked out exhaust areas and the turbo-charger vent with stainless steel, all AK metallics.
Decals performed perfectly, and weathering is a custom mix of brown/black/grey for the exhaust stains and gun stains, ground beige pastels for the tires, and Flory black wash across the entire airframe.  Sealed everything with a coat of Vallejo's flat clear.
Had a couple of other issues, neither show in the photos but both are crystal clear when looked at just right:  (1) managed to get Tamiya liquid cement under the canopy masking, which marred the top of the canopy; and (2) the Vallejo yellow was fully masked when I sprayed the metallics, yet somehow aluminum found its way onto the yellow surfaces nevertheless, and proved impossible to fully obscure with additional yellow paint.  I tried airbrushing another coat of yellow, and the aluminum literally laughed at that effort.  Then I dabbed yellow over the offending aluminum overspray not once, but twice, to mostly make the aluminum appear as a shadow in the photos - two are right under the leading edges of the stabilizers on the fuselage.
Next up is a candy bomber - Revell's big C-54 Skymaster.  I'll be doing that one in the markings that appear in a famous photo of a C-54 coming in for a landing while people on the ground watch and wave.  And a bit unsual for me is the number of NMF builds I've been doing lately.  Relatively speaking, I don't do a bunch of those.  The C-54 will be my 4th NMF bird this year, and that is after completing 4 NMF aircraft last year and still having 3 more in the to-build pile for this year.
    November 2003
Posted by tempestjohnny on Monday, April 26, 2021 6:02 PM
Looks great always wondered about this kit
Posted by jeaton01 on Monday, April 26, 2021 7:59 PM
Nice one, Stephen, the overall effect is great.  I don't understand that gear thing either. Mine has always been a little wobbly and if I build another I'm going to have to think about pinning the gear or something.  I remember fighting with the gun inserts some.
John
Posted by keavdog on Monday, April 26, 2021 9:02 PM
That's a beauty.  Really nice finish.  Looking forward to your C-54 build.  I picked up a used one and the guy had sprayed some aluminum/chrome on a few surfaces. Nothing I can't fix, but it was cheap.
Again - nice job on the N
Thanks,
John
    November 2020
Posted by Buckeye2 on Tuesday, April 27, 2021 10:05 AM
Beautiful build and I love your weathering.
    January 2015
Posted by Aggieman on Thursday, April 29, 2021 4:00 PM
tempestjohnny
Thanks for your kind words.  It's a good kit (not Tamiya awesome but good nonetheless).
    January 2015
Posted by Aggieman on Thursday, April 29, 2021 4:02 PM
jeaton01
Thank you for your kind words, John.
Yeah, I also had some trouble with the gun inserts.  Another oddity about the kit, I suppose.  I had to do some sanding to get them in, and even then, I needed some filler to fair them in.  Didn't really get it as smooth as they should have been.
    January 2015
Posted by Aggieman on Thursday, April 29, 2021 4:03 PM
keavdog
Thanks for your kind words, John.  I opened up that C-54 last night and did my usual prep work on larger parts-count kits like that one (I used a black sharpie to highlight the parts numbers on the various trees to make them easier to locate when I need them).  Looks to be a good kit, but the devil will be in the muck of actually building it.
    January 2015
Posted by Aggieman on Thursday, April 29, 2021 4:04 PM
Buckeye2
Mike, thank you for your kind words.
    November 2008
Posted by Justinryan215 on Saturday, May 1, 2021 8:42 AM
Despite your 'troubles' she is a gorgeous bird!
You know...I either need to stop coming here, or need to build Faster!  I have the Promodeller version in the stash, and now I want to build it!
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    June 2017
Posted by Chemteacher on Saturday, May 1, 2021 8:35 PM
Hey, that came out first class. I always enjoy your builds.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    May 2006
Posted by ggatt_2 on Saturday, May 1, 2021 10:02 PM
That's a really nice looking finish. What do you think about the AK metallics?
-Greg
    February 2010
Posted by 68GT on Sunday, May 2, 2021 12:04 PM
Nice job! I did ones of these a while ago and was surprised on how different it was from their P-47D.
On Ed's bench, ???
    January 2015
Posted by Aggieman on Sunday, May 2, 2021 12:42 PM
Justinryan215
Thank you for your kind words, Justin.
I had been out of work for a number of years, which left me a lot of time to build.  Now that I'm back to work, I expect my build productivity will decline a good bit.  But definitely pull that ProModeler kit out of your stash and get to it if you remain so inclined!
    January 2015
Posted by Aggieman on Sunday, May 2, 2021 12:43 PM
Chemteacher
Thank you for your kind words, Chemteacher!
    January 2015
ggatt_2
Greg, thank you for your kind words.  The AK Metallics are every bit as good as the Alclads IMO.
    January 2015
Posted by Aggieman on Sunday, May 2, 2021 12:44 PM
68GT
That's a nice looking 'Bolt!
    May 2021
Posted by Sprue2 on Sunday, May 2, 2021 2:27 PM
Wow! That metal finish is great. Thx for the inspiration.
Posted by IBuild148 on Sunday, May 2, 2021 10:42 PM
My number 1 WWII fighter. Well done!
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    January 2015
Posted by M. Brindos on Monday, May 3, 2021 2:48 AM
That's a really sweet looking Thunderbolt!
I have this same kit in my stash and I've built the "D" a few months ago, but if I didn't have so many dang open projects I'd now be all over it lol!
I love the way you've finished it.
- Mike Brindos "Lost Boy"
    April 2015
Posted by Mopar Madness on Monday, May 3, 2021 9:03 PM
Another vintage classic done right!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2019
Posted by Hoss WA on Wednesday, May 5, 2021 5:13 AM
Love the scheme, paintwork and weathering. Looks fantastic. Congrats.
    January 2015
Posted by Aggieman on Wednesday, May 5, 2021 7:55 PM
Sprue2
Thank you for your kind words Sprue2.
    January 2015
Posted by Aggieman on Wednesday, May 5, 2021 7:56 PM
IBuild148
Thank you for your kind words!  Not quite my favorite, but even so, I've always liked the look of the Jug.
    January 2015
Posted by Aggieman on Wednesday, May 5, 2021 7:59 PM
M. Brindos
Mike, thanks for your kind words!  This build has really gotten me to start eye-balling the old Revell Thunderbolt in 1/32 that I have in the stash.  I'll likely need to replace the kit decals (given that they are > 50 years old) and I'll try to add some stuff to her, but yeah, I'm thinking that will be the next Revell 1/32 kit I do.  Not sure when ....
    January 2015
Mopar Madness
Chad, thank you for your kind words!
    January 2015
Posted by Aggieman on Wednesday, May 5, 2021 8:01 PM
Hoss WA
Hoss, thanks for your kind words on this build.  While I still like my Tamiya 'Bolts more, when I walk my display cabinet and see this build, I'm happy with what I did with this one.
    March 2012
Posted by mustang1989 on Wednesday, May 5, 2021 9:43 PM
That's some fancy footed modeling on that kit and she turned out a complete beaut. Glad you were able to get the landing gear to cooperate on this one.
 Forum | Modelers Social Club Forum (proboards.com)
