Revell 1/32 F4E WIP (COMPLETED)
    November 2008
Posted by plasticjunkie on Monday, November 22, 2021 12:34 PM
I have been working on this HUGE monster for a while and have not been photographing each step. Was not planning this commission as a detailed WIP so here is some of the progress.
The markings will be from the 469th TFS, 388th TFW AFB in 1973. This aircraft had 2 kills scored in Vietnam Nam. This particular example is of the earlier type of E but having the newer gun muzzle door. The earlier E was non slotted at the outer wings and the kit has the later type of tips that have to be retrofitted to the older style. More on that later.
A resin pit was used to replace the Revell one so lots of fiddling was done to get things to fit, pictures to come.
The parts fit is generally ok till I came across the side air intakes that had gaps and had to be wrestled into shape.
Plst I Weld does a great job at melting the plastic and creating a solid join without the use of any putty. The bottom came out looking great too. The discoloration along the join line is just that, a lighter grey shade created from the pooling of the Plas I Weld used To even out the area which is sanded smooth when fully cured leaving a smooth invisible join.
Here I used some plastic sheet stock cut into thin strips to fill in this part that will be sanded smooth once cured.
 GIFMaker.org_jy_Ayj_O
    May 2009
Posted by Pawel on Monday, November 22, 2021 5:51 PM
Hello!
That's really a BIG hunk o' plastic! Lookin' good sofar - I'll be watching this one!
I have a paper model of the Phantom - it's in 1:33, so it's almost exactly as big, maybe I'll get to building it one day...
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    November 2008
Posted by plasticjunkie on Monday, November 22, 2021 6:31 PM
Pawel
Hello!
Paweł
Yes it’s quite large and hope I have enough paint in hand to cover this beast.
    November 2008
Posted by plasticjunkie on Monday, November 22, 2021 6:49 PM
The kit has the later outer wing  style so some sanding, cutting and scribing was done to bring them back to the earlier style.
after surgery
outer wings attached
    November 2008
Posted by plasticjunkie on Tuesday, November 23, 2021 12:14 PM
I found a couple of more pictures that didn't get deleted earlier.
The forward fuselage section has a great fit to the main rear fuselage. I added a huge hunk of lead up front to make certain it does not become a tail sitter. Here I was fitting the beautiful resin pit.
the IPs and pit sides were painted using enamels. Drops of Testors clear parts cement were used for the instrument glass.
Posted by keavdog on Tuesday, November 23, 2021 12:35 PM
Nice job on the wing work.  I opted to trade my late wing for an early wing (1/48 Hasegawa) to avoid all that work.  I fortunate to find someone who was looking for the swap.
The IP looks great - at first glance I thought they were those new Quinta Studio sets.
Thanks,
John
    November 2008
Posted by plasticjunkie on Tuesday, November 23, 2021 3:08 PM
Thanks kd
The resin set is from Legend. Very well made and detailed. I'm presently working on the ejection seats now.
    July 2014
Posted by modelcrazy on Tuesday, November 23, 2021 3:21 PM
Looking good PJ. I've aquired a 1/23 F-14 so I'm intrested on watching your seam repair. I like the outer wing work.
Steve
    November 2008
Posted by plasticjunkie on Tuesday, November 23, 2021 5:20 PM
modelcrazy
Holy frijoles Steve, 1/23?? That is the mother of all monsters lol!
Here are some shots of the joins with no putty used just Plast I Weld and a Touch N Flow applicator and big clamps.
Side intake joins after plastic welding, clamps and sanding
The Plas I Weld discolored the plastic where I pooled it to blend things in but sands out great
 Thanks for looking and commenting!Yes
    April 2015
Posted by Mopar Madness on Tuesday, November 23, 2021 9:40 PM
No matter what kind of aftermarket instrument panels I see, they'll never impress me as much as a hand painted one.  Top notch work PJ.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    November 2008
Posted by plasticjunkie on Tuesday, November 23, 2021 10:53 PM
Mopar Madness
Thanks Chad!
    March 2013
Posted by patrick206 on Wednesday, November 24, 2021 12:05 PM
Wallabaloo, THIS is a major project that is really progressing well Ernie. The pit details are super realistic, any F-4 drivers out there will love seeing this one. I will be following this closely, thanks for the post and photos.
Patrick
    November 2008
Posted by plasticjunkie on Wednesday, November 24, 2021 10:23 PM
patrick206
Patrick
Thanks Patrick!  Yes
    November 2008
Posted by plasticjunkie on Saturday, December 4, 2021 3:26 PM
Hope everyone had a great Thanksgiving and spent time with family.
Got some spare time and started painting the missiles, gears and other white colored parts.
The gear wells got a coat of Tamiya white gloss
The marble coat went on. Next will be layering the SEA colors to let some of the marbling peek out giving the paint tonal changes.
The underside was also marbled to help get a worn and dirty finish.
    November 2008
Posted by plasticjunkie on Sunday, December 5, 2021 12:52 AM
I almost forgot to remove the elevator reinforcement plates found on the later and upgraded Phantoms. This one being an early E did not have them but did have the upgraded gun muzzle that prevented gas ingestion into the side air intakes causing the engines to flame out.
Reinforcement plates removed and details re scribed
Completed early style elevator ready to be repainted black.
    May 2004
Posted by cbaltrin on Sunday, December 5, 2021 4:51 AM
Wow,  lot's of work you've done there PJ. I really like the cockpit!
On the Bench: Too Much
    February 2011
Posted by knox on Sunday, December 5, 2021 12:42 PM
This is going to be so awesome.
Posted by Tojo72 on Sunday, December 5, 2021 12:47 PM
Some great plastic surgery going on here
    November 2008
Posted by plasticjunkie on Monday, December 6, 2021 3:29 PM
cbaltrin
Thanks cb. The Legend resin pit is quite nice. I had taken several pictures of the painting process but got accidentally deleted. I was able to find this one showing the nice molded side panel details.
This is a commission build and the customer is not interested in the extra cost of super detailing the pit so the back of the rear panels got some free minor scratch work. Once painted black it will blend right in and will make it look busy enough. That area is screaming for tons of wiring.
    November 2008
Posted by plasticjunkie on Monday, December 6, 2021 3:57 PM
Knox and Tojo thanks. Slowly making progress.
    May 2004
Posted by cbaltrin on Monday, December 6, 2021 4:27 PM
Can't wait to see it finished PJ. Keep up the good work!
    November 2008
Posted by plasticjunkie on Monday, December 6, 2021 7:01 PM
cbaltrin
Thanks cb. Been working on Aim 9 missiles today. The SEA uniform will be on soon. I have the AK lacquers on deck and ready for spraying.
    November 2008
Posted by plasticjunkie on Wednesday, December 8, 2021 8:12 AM
Got the Aim9s painted white and ready for destailing.
the Alq jammer got masked and painted
masking removed and ready for decals
took a while but the belly, tanks and pylons got a coat of Mr. Color lacquer FS 36622
Posted by oortiz10 on Wednesday, December 8, 2021 9:02 AM
Greetings plasticjunkie, I'm diggin' your progress. The beast is looking good.
Hey, I have a questions about the AK paints. Now that MM has gone bye-bye, I'm looking for a paint line to switch too. I don't like using acrylics and was looking for other enamels or laquers. I have a few projects that I want to start that I'll need to buy some paints for. I've heard good things about AK's Real Color line and am curious to know what you think.
Thanks in advance and keep up the great work!
-O
-It's Omar, but they call me "O".
    November 2008
Posted by plasticjunkie on Wednesday, December 8, 2021 1:51 PM
oortiz10
-O
Thanks Ortiz.
Like you I'm not too exited about acrylics like Vallejo. My favorite paint is Model Master enamels but the stash is shrinking, had to throw away two new bottles cuz they turned into rubber. I will miss them dearly once I'm out of them.
I'm actually using Mr. Color lacquers so apologies for the mistake but I have AK acrylic lacquers in the stash and will eventually use them. Have heard great things about them and should spray as well as the Tamiya paints.
Mr. Color lacquers spray very well thinned with Mr. Color Leveling Thinner. Great coverage with no clogging . I like how these paints perform.
    November 2008
Posted by plasticjunkie on Friday, December 10, 2021 11:35 AM
The colors are on. I used my Neo for the rough outlining and the Sotar to sharpen up the feather edges. The Neo does a fine job but the Sotar delivers a super tight feather line.
I totally forgot about a small drawer in my man cave having several Model Master enamels that I grabbed before being discontinued. I'm using a combo of MM enamels and MR. Color Lacquers. They both spray out the same and are a joy to work with.
 Alclad will be next for the nmf parts.
    November 2008
Posted by plasticjunkie on Tuesday, December 14, 2021 7:48 AM
Shot multiple coats of Future to prepare the surface for decals and washes. Need to mask to spray Alclad on the NMF areas first.
Finished striping the Sparrows last night.
Posted by oortiz10 on Tuesday, December 14, 2021 9:30 AM
plasticjunkie,
That's looking sharp! Love the camo and the demarcation lines. Interesting that you posted some info about your airbrushes. I had been in the market for a new "detail" airbrush, and the Sotar 20/20 was on my research list. Turns out, I pulled the trigger on one (no pun intended) over the weekend, and it should be landing in my mailbox today. Nice to read (and see) that it gives nice tight lines. Any other info or thoughts you'd like to share on your Sotar?
Thanks and keep up the great work!
-O
    November 2008
Posted by plasticjunkie on Tuesday, December 14, 2021 9:54 AM
Thanks O.
I love how well the Sotar performs with lacquers and enamels. I thin the paint a good 50/50, lower the air down to 10-8 psi and set the trigger control to get a SUPER tight feather line. It takes a little practice but man it is just an awesome airbrush, super easy to clean too.
Can’t comment on using it with acrylics like Vallejo yet.
Posted by oortiz10 on Wednesday, December 15, 2021 11:10 AM
Thanks for the 411. I mostly spray enamels and lacquers, very rarely acrylics, so I'm excited to give the Sotar a try. Now, I just gotta build something...
OK, sorry to hijack your build thread with my airbrush detour. Looking forward to seeing more of your progress!
Thanks!
-O
