Eglins flight line
    May 2003
Eglins flight line
Posted by Awood23 on Tuesday, May 13, 2003 8:18 PM
Im looking to build a 1/48 scale collection of the squadron based at Eglin and running into a brick wall in the research area. The F-15's are easy but I need info on the F-4's and F-16's specificaly tail codes and versions. Im pretty sure there were F-111's and A-10's stationed there too and would appreciate any info on these. Pictures would be great if any body has em you can email them to Awood23@yahoo.com. If anyone know if there are decal sets out there for these aircraft Id be grateful for info on that too.... Thank
[img]http://img.photobucket.com/albums/v515/Awood23/DarkSideBadge.jpg "your' not trying if your not cheating" "no one ever won a war by dying for his country, he won it by making the other poor bugger die for his" 'never before have so many owed so much to so few" 1/48 Spitfire %80
Posted by berny13 on Wednesday, May 14, 2003 10:03 AM
Which Squadron are you looking for?
The 3246 Test Wing, 3247 Test Squadron, operated the F-4C, F-4D, and F-4E aircraft. The C was painted overall ADC gray. They did not carry any tail code markings. Their D's started off as ADC gray and later carried the SEA, Wraparound, and European 1 camouflage schemes. They had the tail code AD. Depending on the time frame the AD could be found painted white or black. The E's were painted in the SEA scheme and later went to the wraparound and European 1 scheme. They also had the tail code AD, again in white or black.
The 33 TFW operated only the F-4E, starting off with tail code ED in white. They became operational with 66 & 67 model acft. In 1970-71 they started receiving new 69 models direct from the factory (My acft was 69-260). On their deplayment for Linebacker, they had 66, 67 & 69 models. In 1978 their tail code changed to EG, and were painted white. Their acft wore the SEA paint scheme and none were painted in the wraparound as by then they had gone to the F-15.
Hope this will help you a little.
Berny
 Phormer Phantom Phixer
On the bench
    May 2003
Posted by Awood23 on Wednesday, May 14, 2003 11:14 AM
Thanks Berny,
I wish I could be more specifc about what Im trying accomplish. I grew up a USAF Brat (later joined the Army to******the old man off [:) ) Im trying to buld a 1/48 model of all the aircraft from bases I lived at while my father was stationed there. We were at Eglin from 1990 to 94 and I remember driving around the perimeter track and seeing F-15's, F-16's F-4E's and I think WC-130's parked on the tarmack infront of the McKinnely (sp) Hanger. I cant remember if the F-4's had tail codes but they were decked out in the low visibility grey scheme (possibly 2tone) These are the aircraft Im intrested in
Posted by berny13 on Wednesday, May 14, 2003 1:29 PM
During that time frame the only two squadrons operating the F-4E at Eglin AFB would be the 3247 TS and the 4485 TS (TAWC). The 4485 TS (TAWC) had the tail code OT. They were used to test weapons. Both the 3247 TS and 4485 TS (TAWC) were one of the last active units to retire their F-4 acft. The paint job you mentioned was called the "Hill Gray" scheme. You were at Eglin AFB long after I retired from the Air Force.
If you need any more information, I will try to help out.
Berny
On the bench
Posted by Anonymous on Tuesday, May 27, 2003 3:55 PM
I was stationed at Eglin during part of the time frame you listed. There were in fact A-10's and F-111's (They might have been gone by 1990?, but they had them just a few years earlier) They used tail desg. EG (33rd TFW F-15C/D) ET Mixed aircraft as you mentioned and AD (Armament Division). The F4's were I believe E's, The F-16's were A, C, and D's. There were also C-130 assigned there both standard and MC-130. There were also AC-130's down the raod at Hurbert and Duke fields. Hope this helps. I have some pictures that are burried deep in a closet that I can try to dig up if intrested? Smile [:)]
    May 2003
Posted by Awood23 on Tuesday, May 27, 2003 8:07 PM
Any pics would be greatly appreciated. If you can scan em, you can email em to Awood23@yahoo.com
