P-61 Black Widow
P-61 Black Widow
Posted by Anonymous on Friday, May 16, 2003 11:51 AM
I just got a P-61 Black widow in 1/48. Anyone out there that has built one, and do you have any suggestions. Looks like a pretty detailed model, but i am disappointed...only pix in the instructions, and now written text. And sometimes a thousand pix does NOT equal one word. It is a Revell kit, and all the parts are black...dont know why they do that. Any ideas or suggestions will be appreciated
Posted by upnorth on Friday, May 16, 2003 2:02 PM
Thats a re-issue of a classic Monogram kit of I think late 1970s, Early 1980s vintage.
I'm sure you'll find a ton of write ups one way and another about it on the net.
    January 2003
Posted by therriman on Friday, May 16, 2003 2:17 PM
That kit is from the mid-70's. I bought one right after first issue when I was a teenager. They originally came with a Shep Paine diorama pamplet (do they still?). I'm sorry I don't remember much about its quality or fit, I was just a kid, and I was more worried with putting kits together as fast as possible and not about accuracy or finished results.
Tim H. "If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942 Real Trucks have 18 wheels. Anything less is just a Toy! I am in shape. Hey, Round is a shape! Reality is a concept not yet proven.
Posted by John P on Friday, May 16, 2003 3:00 PM
It's a typical classic Monogram kit - all the parts fit. The instructions are perfectly explicit and easy enough to follow. The airplane is black, that's why they molded it in black :D.
As an interesting side note - my dad once got into a spin the one time he flew a P-61 and pulled out so hard he vibrated all the paint off both tail booms. I have a photo to prove it.
Posted by Ray Marotta on Friday, May 16, 2003 3:05 PM
I've built the kit twice in the last 20 years or so and the only major problem I ran into was aligning the booms. Other than that, fit was above average and the
possibility for extra detail is excellent. It's also a "tail-sitter" and will require weight to sit properly on it's gear. I put the weight where the weight is on the real
thing---in the engine nacelles. It will take a little more weight there but the main
gear can handle it better than the nose gear can.
BTW---The Mid America Air Museum recovered a crashed P-61 from New Guinea
some years back and is restoring it to flying condition. I don't have the exact URL
to the museum here at work but any good search engine will find it under
"The Widow's Web"
Ray
Posted by Anonymous on Friday, May 16, 2003 5:44 PM
Ray, i am glad you mentioned "weighting it"...what did you use in the engine nacelles? I have some lead fishing weights in various weights. How much do you need?
Really appreciate all the info on the "Widow" i am going to air brush a model for the first time. It seems to have a lot of interior green...is it best to do all that one color at the same time rather than cleaning up...spraying and then cleaning up again.? If i sound stupid, there is a good reason (smileBig Smile [:D]. Looks like a lot of canopy masking also...i have some left over stuff from EZ mask that i used on the Avenger, that i will probably cut up and use.
Posted by JGUIGNARD on Friday, May 16, 2003 7:08 PM
I was at the AMtech site recently, and it looks like they will be releasing a series of 1/4th P-61's in the near future.
Go Here ====> http://www.amtechmodels.com/
Jim
Most of us are acquainted with at least one "know-it-all". He may be as close as the mirror. [}:)]
Posted by Anonymous on Friday, May 16, 2003 7:10 PM
I've built that kit a couple times over the last couple decades also, and probably will do moreTongue [:P].
My father was at an air show in MI. during or just after the war and saw one. A wing spar collapsed on a low pass and it went in inverted.Sad [:(] He said the crowd first ran to it then away as the ammo cooked off.
Posted by gregers on Friday, May 16, 2003 10:28 PM
Hi Huskerguy. For noseweights see if you can scrounge or buy some car wheel ballance weights used for alloy wheels they are in strips, are in 5 and 10 ounce increments and have a self adhesive back. they are ideal if you havn't got much room in the kits nose. Gregers
Why torture yourself when life will do it for you?
Posted by toadwbg on Saturday, May 17, 2003 12:02 PM
Hey Huskerguy- I've built this kit in the past, it's a fun one. In fact, I'm going to have to get another one someday soon.
I'd reccomend BBs (from a BB gun) for weighting the thing down. I use superglue to initially hold them in place and then drown them in Elmer's White glue to really keep them in there.
Yup, the canopy masking can be a pain on this one. Since the are nice little squares, I did mine with Scotch clear tape and cut them to size with a very sharp Xacto knife.
Interior Green- Yeah, spray all your green stuff at once and then assemble. I'd reccomend Testors Model Master Interior Green for this- works well when airbrushing.
How did your Avenger turn out? I still havn't started mine!
Toad
"I love modeling- it keeps me in the cool, dark, and damp basement where I belong" Current Projects: 1/48th Hasegawa F-14D- 25% 1/48th Tamiya Spitfire- 25%
Posted by Anonymous on Saturday, May 17, 2003 1:01 PM
With the exception of the darned turret...the Avenger turned out pretty well for an amateur. Thanks for the info on the "Widow"...i thought it would probably be easier to do all the interior green...and i am using model master. By the way, how the heck do you "stack" BB's, so the super glue holds?
Posted by BlackWolf3945 on Sunday, May 25, 2003 5:05 AM
The Mid-Atlantic Air Museum has been restoring that BW back to flying condition for going on 20 years now, I wish they'd hurry up and finish it! Tongue [:P]
Please, no comments on how difficult it is to get a warbird back into the air, especially such a rare bird like the P-61. It was a JOKE! (humor? whazzat?)
I'm not greatly involved in restoring warbirds, but I am most appreciative of what it takes to get these things flying again. I remember seeing MAAM's B-25, "Briefing Time" at many an airshow when in my early and mid teens, and talking to the guys about the P-61. Here, I'm now 30 freakin' years old and that thing is still "gonna be flyin' in a year or two". LOL I just love the warbird scene...
Here's a shot of the MAAM P-61.
Here's a link to Mid Atlantic's website:
http://www.maam.org/
For more shots of the P-61 project, click on "the Widow's Web".
Fade to Black...
Posted by John P on Sunday, May 25, 2003 8:14 AM
Here's that Widow that Dad got into a "graveyard spiral." Margie, squadron uncertain, Ie Shima, 1945. I've been going to use the Monogram kit to model her for years now, but now i think I'll wait for the AMtech kit.
At least I don't have to worry about not knowing her serial number for the markings (apart from the "4" at the end :D)
    December 2012
Posted by FreedomEagle1953 on Sunday, May 25, 2003 4:11 PM
My experience with the old Monogram kit (which I hear is now re-issued as a Revell kit) has been good ... I enjoyed building this kit and am happy with the results. I will look forward to the Amtech kit mentioned above. The 1/1 scale a/c was/is a really cool looking plane. Smile [:)]
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
Posted by Anonymous on Sunday, May 25, 2003 4:56 PM
i have had some problems getting this thing together. I couldnt get the booms to glue to the wing section first time around, and in the process knocked off the nose wheel and the left main gear. Dont tell me how clumsy i am. But, why dont they make the gear stronger. To me, that is the real wink link in most kits. And once you break one, they are a bitchkitty to glue back on again. Any suggestions?????
Posted by Butz on Sunday, May 25, 2003 6:47 PM
For some reason I cant really place it but I seen this same pic in a book once before(it will come to me,just give me time. I think I saw it in an Air Power book).
I remember seeing the section of the boom w/out the paint and thinking how did the insignia stay on(must have used a lot of solvasetTongue [:P])
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by BlackWolf3945 on Sunday, May 25, 2003 8:26 PM
Butz,
You may have seen several photos similar to that one. P-61's shedding paint en masse was a common occurrence, especially in the PTO & CBI.
There were several contributing factors to paint peeling off of P-61's almost in sheets, but it comes down to weather, operational conditions and maintenance, all of which were aided by poor paint adhesion. Given these conditions, any violent maneuvering might, indeed, have been enough to shed a bunch of paint all at once. And I do seem to recall reading a similar story somewhere in a book or a rag.
I ran across a shot (which I can't find at the moment) of a Black Widow in France that had just been prepared for action at a depot after coming over on a ship. The sealing tape used to protect the aircraft had peeled the paint off in neat strips along the panel lines. Really neat lookin' photo.
Anyhoo, here's some more shots of PTO & CBI P-61's sporting a similar look.
By the way, John P, if that shot was taken on Ie Shima in '45, 'tis most likely a P-61 of the 548th NFS.
Here's the 548th's emblem. Kind of a coincidence, I just finished making a hand-painted replica on leather. Feel like I'm in the Twilight Zone... doo-doo-doo-doo...
Can't wait for the AmTech kit!
Fade to Black...
Posted by toadwbg on Sunday, May 25, 2003 8:30 PM
Huskerguy, I don't remember how the instructions go on this kit, but I always put the landing gear on very last if possible, that way it doesn't get knocked off during so much handling that goes on. The same goes for other small details (arials, guns, etc.)
As for the BBs. It's really pretty simple. I think on this kit I put he weight in the nose (and sealed the nose off /glued it shut instead of having it removable to show the radar). Turn the thing upside down (opening up) Drop a few BB's in the nose, add just a little superglue, enough to freeze them in place. Repeat by adding more, and more and more until your happy. No need to overdo it with the superglue. Let this all dry in place for about a good hour. Now come back and pour in the Elmer's glue to fill up all the cracks. Ths can take a few days to dry completely but now you've got a rock solid and heavy nose to weight ths puppy down.
Posted by Butz on Sunday, May 25, 2003 8:34 PM
Whaz up Blackwolf,
Yes good ol "mother nature". She sure can be mean cant she..LOLTongue [:P]
Cool pics too. Its still gonna bother me about that pic John P posted. I know I've seen it.
Guess I'm going hunting very soon.......Tongue [:P]Tongue [:P] I'm soo looking forward to the AMtech Widow Maybe I'll be giving the ol Monogram kits to good ol DanWink [;)] unless he changes scales again.
Flaps up, Mike
Posted by BlackWolf3945 on Sunday, May 25, 2003 8:37 PM
Butz,
Haven't you heard? Dan's already into 32nd again. Get 'em while you can! (Before I clean him out, that is! Tongue [:P])
Fade to Black...
Posted by Butz on Sunday, May 25, 2003 8:42 PM
Hey Blackwolf,
What, did Rich give Dan his Academy 32d 18 ALREADY...?????Tongue [:P]Tongue [:P]Tongue [:P]Tongue [:P]
Flaps up,Mike
Posted by BlackWolf3945 on Sunday, May 25, 2003 8:46 PM
Actually, I was only joking about the 32nd. Though he is taking trades in both scales! (Surprise, surprise!)
Anyhoo, I did manage to get another couple of kits out of him. Some armor and a Mauve P-40.
And negative on the F/A-18, Rich wanted to give up his Hasegagme F-16 and give it to Wayne so he could start on the Hornet, but we convinced him to keep the Viper and finish it. It looks too good for him to pull his usual maneuver. Needless to say, Wayne wasn't too happy about us intervening! LOL Evil [}:)]Tongue [:P]
Fade to Black...
Posted by Butz on Sunday, May 25, 2003 8:50 PM
Ya know Steve I may have a few ideas to where I can look on the 61 pic. But than again my ideas usually turn into brain fartsDead [xx(].
I may have some leads................. Does Dan have any more Mauve kits??
Flaps up,Mike
Posted by BlackWolf3945 on Sunday, May 25, 2003 8:59 PM
Nope, no more Mauve kits. But one could be had for a more than nominal fee... Man, I think we should start our own chat thread instead of clogging this one up! LOL Tongue [:P]
Lawrence, WE WANT LIVE CHAT! LOL
Fade to Black...
Posted by Anonymous on Monday, May 26, 2003 8:02 AM
For weights, I go to my local hobbyshop to the railroad section. They have "tape" weights. Flat, narrow lead bars that are segmented and will break off in any length and weight that you want. They have tape on the back side. You just peel and stick wherever you want.
Posted by John P on Monday, May 26, 2003 9:22 AM
Butz, I don't see how you could have seen that particular pic before, since Dad took it himself and it's been languishing in his memory box for 60 years. Maybe someone else took a pic of Margie, though. Dad only flew her that once - the NF squadron was short pilots and asked the regular fighter groups for volunteers. Dad wanted to fly everything, so he gave it a shot. Next thing he knows he's flying in pitch dark, the gunner sitting behind him is kicking him on the shoulder yelling "pull out!" the horizon ball is pegged into a corner and the altimeter is unwinding. He pulled so hard he set up a tail flutter and there went the paint! :D
Posted by Anonymous on Monday, May 26, 2003 10:25 AM
Hi there! I've just finished my Monogram P61. It was alot of work. Ingraved panel lines, Fitted Eduards two photo etched sets, and vac formed new canopies.
I'm happy with the results, until I heard a new state of the art 1/48th kit is out from Amtech. Oh well thats life. Needed loads of nose weight. Nose cone packed full of lead shot and then some more in the nacells. A lovely aircraft worth the effort to build the older Monogram/ Revell kit. Maybe someone might do one in 1/32nd?
Posted by wayne baker on Monday, May 26, 2003 8:04 PM
Huskerguy
Still need to repair the landing gear? Drill a hole in the strut and where it broke off. Glue in some rod or sprue the same size as the hole. It will reinforce the break. As I have said in some other threads, I like to mix some 2 part, 5 minute epoxy to hold BB's or shot that i like to use.
Semper Fi
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by BlackWolf3945 on Monday, May 26, 2003 8:08 PM
I think someone may have taken a similar shot of "Margie", because I swear I've seen it before. Been searching like mad! Tongue [:P] I remember the name on the nose fersher...
Gotta love Black Widows!
Fade to Black...
Posted by John P on Tuesday, May 27, 2003 7:30 AM
Fade to Black...
In that case I'd LOVE to see it too!
