Albatros Dark Mirage Decals.
Posted by Anonymous on Tuesday, May 27, 2003 9:07 AM
Hi,
I'm a new user to this site and have just recently started back into modeling after a 20 year hiatus.
I have just completed an Italeri 1/48 Mirage F1CZ of the South African Airforce 3 Squadron. To complete the decal process I used Albatros Dark Mirage decals. And here is my problem; I have experienced very extensive silvering on every decal from this product. I have tried applying gloss to the model before applying the decals and also fine pricking to release trapped air, but nothing works. Have any of you out there had the same problems with this product and if so, how did you get around the problem?
Kind regards,
Mirage.
Posted by BlackWolf3945 on Tuesday, May 27, 2003 4:56 PM
Are you using any decal solvents? They help a great deal with silvering, bubbling and the like.
Some of the more popular stuff: Micro Sol/Set, Aeromaster Sol/Set and the omnipresent Solvaset. There are other decal solvents out ther made by Testors, Polly-S/Scale, Gunze Sangyo (Mr Mark Soft or sumthin') and others.
The two-part solvents are designed to be used together as a system. One goes down on the model before you actually apply the decals and the other goes on top of the decals.
Then there's good 'ole Solvaset. This stuff ROCKS! Very strong and it'll solve most of your decaling woes. Although sometimes it can be TOO strong, depending on the type of decals you're using.
Fade to Black...
Posted by Anonymous on Saturday, June 21, 2003 7:21 AM
Thanks for the tip, mate! Sorry it took so long to reply. I like the bi-plane on your message though. How did you do it?
Mirage.
Posted by BlackWolf3945 on Saturday, June 21, 2003 7:00 PM
Hey Mirage,
Hope that helpes you out in the future!
As far as images, here's a link to a thread on how to insert images into your posts:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=30
In this case, I put the airplane into my signature, which you can do by editing your profile.
Even though I gave you the link, I'll give you a demo here.
First off, whatever image you'd like to use, you must have hosted on the net somewhere. I use http://photopile.com/start.htm to host my images.
When replying to a topic, look for this button:
If you click on that, this will appear in the text box:
Only it won't have the spaces between the brackets and the "img" or "/img".
Say this is the image you want to insert.
You must find the URL of the image in order to insert it into the message.
If you host your own images, it should tell you what the URL (or address) for a certain image is.
If you want to find out the URL for any image on the net, right click on it then select "Properties".
A box should pop up, just look for the "Address: (URL)" and copy it.
Then past it in between the but DO NOT include the spaces between the brackets and "img".
The URL for my signature image is:
http://photopile.com/photos/blackwolfscd/SHforum/13534.bmp
If you wanted to insert this image into a post, it would look like this (WITHOUT the spaces!)
That's all there is to it!
Fade to Black...
Posted by Woody on Saturday, June 21, 2003 8:02 PM
Hi Mirage, Try mixing white glue and water(1:4). Silvering is air trapped under your decal. Just put 1 drop where you are going to place your decal and apply as you normally would. The suggested solution will break the surface tension that allows the air pockets and assist in securing the decal. I use foam makeup applicators to position and soak up most of the solution. I use lint free cotton cloth to get the rest. You can still use a setting solution if your decal doesn't lay flat or needs to snug down into a seam.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
