Ju-88 A-4
Ju-88 A-4
Posted by Anonymous on Sunday, February 13, 2005 4:06 PM
Hi guys,
I would like to ask a question.
I bought a 1/72 Revell Ju-88 A4, but you know Revell, always with their mixing...
I would like to ask you guys wich paints I should use.
Revell instuction says:
UPPER COLOURS:
* 75% greenish gray (67) + 25% yellow (15)
* 90% granite gray (69) + 10% white (5)
UNDERSIDE COLOUR:
* 60% light green (55) + 10% grey (57) + 30% white (5)
Well, I would like to hear your opinion...
But if you give some paints, be sure it are Revell, Humbrol, Tamiya or Model Master paints, because those are the only I can find...
Thanks and GreetzSmile [:)]
PS: Oh, yeah, how do I have to paint (wich colour) the pilots and the cocpit)?
    September 2004
Posted by razordws on Sunday, February 13, 2005 4:51 PM
Sign - Welcome [#welcome] to the forum.
I am not familiar with Revell's paint system but the Ju 88 A-4 usually had a RLM 70/71 over a RLM 65 color scheme. The RLM is the Luftwaffe's official color designation. I usually use model master acrylic paints and they have colors for the above scheme as follows.
RLM 70 schwarzgrun is #4780
RLM 71 dunkelgrun is #4781
RLM 65 hellblau is #4778
For the interior you should use RLM 66 (schwarzgrau) which is model master #4779 and RLM 02 (grau) for the landing gear and landing gear bays which is model master #4770.
If you prefer enamels they have similar colors available but I do not know the product numbers.
I don't know off hand what the pilot colors should be.
hope this helps
Dave
Posted by Anonymous on Monday, February 14, 2005 11:14 AM
Hi razordws,
Thanks, I think that's going to help, only, I'll have to look for the enamel paints, because I can't find easily the acryls...
Thanks
    May 2004
Posted by Zero Enna on Monday, February 14, 2005 7:12 PM
Which markings have your kit?... it all depends on them... may be RLM 65/70/71, or if it is a maritime plane, it could be 65/72/73... or if it have a desert scheme: RLM 78/79/80... for interior surfaces, RLM 66 in the cockpit and RLM 02 on landing gear and other interior surfaces...
"Vivir venciendo o morir matando"
Posted by Anonymous on Friday, February 18, 2005 10:26 PM
flyingraptor:
Here are the Model Master Enamal color numbers for the RLM 70/71/65 scheme -
RLM 70 - #2080
RLM 71 - #2081
RLM 65 - #2078
and for the interior and wheel wells -
RLM 66 - #2079
RLM 02 - #2071
Hope this helps....have fun!
Posted by Anonymous on Saturday, February 19, 2005 7:34 AM
Hey,
Thanks to all to help me!
It will be a good help...
Greetz
    March 2016
Posted by Per Skjelbred on Monday, March 21, 2016 11:03 AM
Ju 88 from series A to seriesC3 have RLM 02 interior color. Instrument panels were RLM 66 and instruments black.
The wheel bays were also painted RLM 02.
The landings gears RLM 02, The polished steel oleo area in steel/silver. Dampers very dark gray. Wheel hubs semi gloss black,with exception of tail weel hub which was either unpainted (gray metal) or RLM 65. The overall camouflage was RLM 70/71/65
I see many models with the wrong colors. RLM 66 was introduced as interior color in late Nowember 1941.
The JU 88 A series were used in the battle of Britain in the summer of 1940.
I hope this information is of interest.
Regards
Per S
Tags: Ju 88 colors
