flat red?
    May 2003
flat red?
Posted by nsclcctl on Wednesday, August 27, 2003 7:51 AM
why doesn't flat red exist in the FS charts or am I missing it. All I can find is insignia red. Is it gloss or flat? I see flat red in cans but not bottles. I am using it on the belly of my FW109.
Posted by Anonymous on Wednesday, August 27, 2003 8:26 AM
nsclcctl - The paint that was used on the 190's underside is RLM 23 Rot. I know MM makes one, and there are probably acrylic ones available, too. There may not be an FS # for it (I don't know), but the color that the Germans used there was RLM 23. Hope this helps !
    May 2003
Posted by nsclcctl on Wednesday, August 27, 2003 9:04 AM
Thanks PIX, I didn't know that. I will pick it up tonite. Is it a flat? Actually, I don't see it in the Modelmaster chart I have. I did remember seeing it in the shop, I don't recall who made it.
Posted by Anonymous on Wednesday, August 27, 2003 9:47 AM
The MM stock # is 2073. It is semi-gloss, and has a slight "pinkish" hue. You're welcome ! Good luck, & post pics of that bird when she's done !
Posted by berny13 on Wednesday, August 27, 2003 10:17 AM
Flat insignia red is FS 11136. Gloss insignia red is FS 31136. The US military uses only these two colors. Other countries might use a different color of red.
Berny
 Phormer Phantom Phixer
On the bench
