Help needed with F-111 Bomb rack question. Maybe Berny can Help?
    June 2006
Posted by Mark T Gold Coast on Thursday, December 14, 2006 12:52 AM
I'm building an F-111 at the moment and need to decide what stations to use.
It'll be loaded with MK-82 High Drag bombs, I've heard that these are caried in a slant 4 when carried on the inboard pylons and the full six are carried when on the next outboard pylon.
If you weren't to carry more than 12, would you load the outboard pylons only as this doesn't hinder the range of wing sweep? Or do they not use the full sweep position when loaded with these bombs?
Does anyone have any photo's of BRU's loaded with MK-82 or similar as I need to find how the bombs were mounted, I think my resin ones are lacking some detail.
Are the Bomb racks carried by the A-6/A-7 the same as the F-111?
This is a present for my Dad who flew them so it has to be right.
Any help will be much apreciated!
Thanks.
Mark
Posted by berny13 on Thursday, December 14, 2006 8:16 AM
I pulled out the F-111F flight manual and found out the following.  Wing stations 3, 4, 5, &, 6 when carrying MK-81 or MK-82 HDGP or LDGP bombs all six stations on the BRU can be loaded.  When loading only two BRU's, they were loaded on station 3 & 6,  With MK-117, MK-83 & MK-84 on station 4 and 5, they used the slant four load configuration.  Stations 3 & 6 could carry six MK-117, Mk-83 or MK-84 bombs.  The only time the wing sweep was limited was when stations 1, 2, 7, &, 8 was loaded.  The wings were limited to 23 degrees wing sweep.  When stations  3, 4, 5, &, 6 was loaded with MK-117, MK-83 or MK-84 bombs the wing sweep was also limited and full sweep could not be used.
The BRU's used on the F-111 was different than the MER's used by other aircraft.  I have yet to see any model maker include BRU's in their kits.  Even the ones used on the F-15E are different than the ones used on the F-111.  With some modification they can be used though.
Below are the only shots of the BRU I can find.  I can't find a good close up view of them.
Berny
 Phormer Phantom Phixer
On the bench
    June 2006
Posted by Mark T Gold Coast on Friday, December 15, 2006 3:00 AM
Thanks Berny,
I really appreciate your help, not just on this but all the problems I've had.
I know I'll always get a concise informative answer from you and that helps a lot.
Thanks again
Mark
Posted by berny13 on Friday, December 15, 2006 8:05 AM
No problem Mark.  Sorry I wasn't able to offer more help in the way of pictures.
Berny
On the bench
    September 2015
Posted by mags on Friday, September 18, 2015 2:15 PM
This post is old but i was a wepon loader on the f-111d the bomb racks are called bru-33s you can kitbash a tur into a 33.as for the place ment i (we) did load mk 82 high drag on stations 3-6.
