A multi-part update, with photos this time!
Apart from various other projects, I HAVE been working on my Goose, also. Here's what I got to bring y'all up to speed:
This monstrosity is the finished battery box. The battery will slip in vertically, and connect to a terminal at the top (which I still need to add) and the bottom. I learned that the only way to get the battery OUT once it's dead is to use needle nosed pliers. Oh, well.
One aileron and flap are gone. As you can see, I still need to clean up the flap actuator housings (those spiky things on the underside) with a dremel or something.
My next update actually makes me feel rather good. For a long time the curved edges of the planing hull has ticked me off. These should be rather angular. I debated just leaving them alone, but finally got the motivation to fix this. It was a rather simple fix involving some small angle stock and, yes, LOTS of putty.
Here's the before:
(Notice rounded bottom edges)
And now:
I still have a bit of work to do (UNDERSTATEMENT!!!!), but you get the idea.
Hey! Progress! Woo hoo! The nex hurdle for me is cleaning up the wing joints. I'm going to wait to get some epoxy putty so I can resculpt the wingtips. The bottom wing is about a quarter inch longer than the top, and it leaves a shelf at the tips (---I__). Bad drawing, I know. Either way, it'll require some major work.
But hey- at least I'm doing something, right? Stay tuned for more!
