P-38 J Lighting What color for inside Cockpit??
    June 2007
Posted by reef12 on Monday, September 3, 2007 6:43 AM
Hi all,
 Well was wondering if somebody Could tell me What color for P-38 J Lighting Academy kit 1/48 scale the cockpit is supposed to be.
I have shot it already with MM Acrylic Green  Zinc Chromate .
 But easy to fix it now then latter.
 Also who does a Decent Cockpit that is easy to paint for this thing?
Thanks all.
    June 2007
Posted by ironokie on Monday, September 3, 2007 7:34 AM
Zinc Chromate? I don't think so. Not for the cockpit anyway. I think the base color for your cockpit should be Interior Green.
    January 2007
Posted by Gigatron on Monday, September 3, 2007 7:55 AM
For USAAF CPs, I like Interior Green (Tamiya XF-04) - BUT, it's not always correct.  Some factories used one color, some used another.
Your best bet is too pick up some reference material and just look at the pictures.  For instance, my HellCat uses interior green, but my Jug uses regular Tamiya green.  From the pictures I studied, regular green was the absolute best match I could find - and it looks dead on.
For the resin cockpit, the only one for the academy I could find from squadron is this one  http://www.squadron.com/ItemDetails.asp?item=LF4020.
HTH,
Fred
    June 2007
Posted by reef12 on Monday, September 3, 2007 8:05 AM
Thanks to both I guess a trip to the store is required to get this color.
Gosh darn it Lucky I asked before I started to paint all the stuff in Flat black.
Couple of extra questions.
Applying decals do you use Future then dull coat then a semi gloss Finish or a respray of Future and leave alone no Dull coat?
First Plane in 30 plus years and that one was a Brush painted F4U Corsair.Whistling [:-^]
    January 2007
Posted by Gigatron on Monday, September 3, 2007 10:14 AM
There's a couple of ways to go.
One way is; Future, decal, future (then dull coat if you want a flat finish)
Another is; Future, decal solvent (micro sol), decal, decal setting solution (micro set), future (then dull if you want a flat finish).
The micro sol makes the decal much more flexible and really helps them to conform to diferent shapes.  The micro set pulls the decal down into the different shapes and makes the decal look painted on.
HTH,
Fred
    June 2007
Posted by reef12 on Monday, September 3, 2007 12:54 PM
Thanks again saved for Future No pun ReferenceWink [;)]
Found a Jar OF MM Interior Green big difference in color.
    January 2007
Posted by thuds1 on Tuesday, September 11, 2007 10:47 AM
 hey dude,
 try this web site ipmsstockholm.com   they have a great magazine in it.
go to the archives to 2004 then to feb . there is a great article that includes the p38
frank
    January 2015
Posted by CaptScott on Monday, August 12, 2024 12:25 PM
for the p-38 j, looks like a good color is british cockpit green (Mr. Color 364). but what color is good for the seat?  CaptScott
