hkshooter wrote: |
Which one is it, the -3 or -5? I've built the -3 and had problems with the lower wing to fuse fit also. The biggest problem was the cowl and gun trough panels. These were entirely wrong and it took AM weeks to get me the correct parts. The IP would not fit under the combing pad either. |
The problems are isolated to the -3 late kit only, which has a mix of parts from the -3 and the -5 kit. This link discusses the problems: http://www.internetmodeler.com/2007/october/aviation/am_sbd3dauntless.php
Don't fear the other AM kits. I've built about five of their mustangs and the fit is good on those. I've also built the Yak 1b and the fit was good with that one too with only minor fiddling. I've heard nothing but good about the Avengers. Havent heard squat about the vindicators other than they are repops of the old and nasty Monogram kit, to be avoided. |
The only 1/48 ex-Monogram kit that AM has released is the SB2C Helldiver, which is the excellent Pro Modeler kit. They have recently released a few old 1/72 Monogram kits. Revell-Monogram still own the molds for the old 60s vintage Helldiver from Monogram.
As jeanton01 said, the AM Vindicator is an all new kit. The HiPM kit is the best known previous kit. There was another one released by a limited production company who's name escapes me. They were much better known for 1/72 scale kits and only released the Vindicator just before they folded.
AM has new management now. They folded for a year or so earlier this decade. The problem with the old management was that they tended to put so much effort into their kits that they had trouble getting their money back out again. The new management is a bit more focused on turning a profit than being perfectionists. They have turned out an excellent Vindicator, but the -3 Midway SBD was not fully thought out.
Another thing to keep in mind when building AM kits is to closely follow the instructions step by step. Some of their sub assemblies are engineered such that if you aren't following the instructions closely, you can end up painting yourself into a corner.
Bill
