Final construction stages are complete! The last major components were the weapons bay doors. These needed careful trimming and test-fitting in order to fit neatly. One area of frustration was the door actuating jacks. These were shown anchored to the inner and outer edges of the doors, while even a glimpse at the real thing ould have shown that the actuators are fixed to a point halfway between the inner and outer edges of the doors at one end, and to rails in the weapons bay at the other. I therefore scratchbuilt these rails, and installed the actuators in the correct position. The actuators, incidentally, bear not even the slightest resemblance to the real thing, being, mostly, hydraulic jacks.The kit parts are just rod structures, with no attempt to reproduce the real thing accurately.
I next installed the torpedos. I coundn't find any reliable photos of these weapons, so I left them painted semigloss white with a brown acrylic ink wash, to give some depth and interest. I cemented them in place with white glue, so that If I later find some reliable piccies, I can remove and modify them.
Further detail work included installing the Sidewinders and the navigation lights. For these latter, I used Bare Metal Foil, rubbed down, cut to shape, and then painted with Tamiya acrylic clear red and green. Final work was to install the electronics aerials, including the long wire ones. The locating points for these had to be scratch-built from brass rod, and the wires themselves from lycra rigging thread.
And there it was - finally - complete! Project started February 13th, completed April 7th. Almost two months - the longest model aircraft build I've undertaken since a Tamiya 1/32 Mitsubishi Zero about seven years ago. Next up, something nice and simple - this year's instalment of the Heller 1/100 HMS Victory...
Piccies and final comments to come.
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
