Winter Camo for Stuka JU 87?
    March 2008
Posted by mark983 on Tuesday, March 11, 2008 4:03 PM
I would love to model my Stuka in winter camo from it's campaigns in Finland or Scandanavia.
Anyone have any great examples I could check out?
Mark
    August 2006
Posted by HawkeyeHobbies on Tuesday, March 11, 2008 4:15 PM
Google is your friend...type in Ju87...click then click images at the top of the page...
click
Essentially they used the Huckleberry Finn method...white wash the upper surfaces to break up the dark camo.
Gerald "Hawkeye" Voigt
    February 2006
Posted by Wulf on Tuesday, March 11, 2008 4:32 PM
This is a Stuka 87D  I did a while back. I found this unusual winter scheme off the decal set I used for it. The service was in Russia 1943-44. Instead of a white wash, white dots were sprayed over the original splinter camo. Also, check out the Wing's Palette site. They have an extensive marking/color archive.
Andy
    February 2004
Posted by chris hall on Tuesday, March 11, 2008 4:35 PM
Be careful - I'd want photographic evidence that Stukas were actually used in combat in those areas during the winter months, as opposed to spring or summer. Norway especially.
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
    December 2015
Posted by dcaponeII on Tuesday, March 11, 2008 6:51 PM
I did a winter camo on an Fw-190A-6 in the Feb 2008 issue of Scale Aircraft Modeller abd tried to explain the basics for application of the finish.  They are quite variable but it would give you a starting point to work from.  But I second Chris and confirm winter camo from photographic evidence or at the very least a profile in a book.
    September 2003
Posted by dragonfly on Tuesday, March 11, 2008 6:52 PM
Here's a couple.
Jerry
    December 2015
Posted by dcaponeII on Tuesday, March 11, 2008 6:55 PM
Looks like it could be the same aircraft in the photo as the profile.  Shows how innacurate the profiles can be sometimes.
