Military trainer aircraft Group build 2020
    November 2003
Posted by tempestjohnny on Tuesday, March 24, 2020 5:03 AM
mach71
Nice start tempestjohnny!
How is it going togther?
Its a fairly simple kit. A little putty in the seams. Nothing to bad.
    March 2010
Posted by mach71 on Tuesday, March 24, 2020 11:46 AM
Sounds good!
I've heard that Revell Germany might be working on a big, 1/32, kit of the magister.
I'm still pluging away at both cockpits for my Trumpeter kit.
    November 2018
Posted by sickdude on Wednesday, March 25, 2020 2:19 PM
Hey Mach, could you please withdraw me from the gb, said explanation is given in my latest post on the british army group build. Still sticking around to enjoy your builds fellers (and gals). Thanks all! Big Smile
William (Willy)
    March 2010
Posted by mach71 on Wednesday, March 25, 2020 4:10 PM
No worries at all.
I'll leave you on the list in case you change your mind. Only about half of GB members complete the builds on time.
    March 2010
Posted by mach71 on Wednesday, March 25, 2020 4:11 PM
The kit cockpit is done.
The rear panel is shifted a bit, I'll try and correct that.
    March 2010
Posted by mach71 on Wednesday, March 25, 2020 8:25 PM
The gear wells locators are very well engineered.
No glue is really needed, they are held really tightly.
    March 2010
Posted by mach71 on Wednesday, March 25, 2020 8:28 PM
sealing it up.
    November 2003
Posted by tempestjohnny on Thursday, March 26, 2020 6:21 AM
That looks great
    November 2003
Posted by tempestjohnny on Thursday, March 26, 2020 6:23 AM
Question. I'm still up in the air on the markings for my Magister. Patrouille de France is a possibility. Anyone know a Tamiya color or mix for the blue 15180 is the fs number.
Edit. Just found something that says xf-8 is 15183. Close enough
    November 2003
Posted by tempestjohnny on Thursday, March 26, 2020 7:26 PM
So today was my day off from my essential Whistling job.  I actually was able to finish the little Magister.  It's not perfect. But it'll do in the display.  Done as a fledgling German Luftwaffe trainer in the late 50's. Had a lot of fun with this. Didn't sweat the small stuff
    March 2010
Posted by mach71 on Thursday, March 26, 2020 7:54 PM
tempestjohnny
Excellent! 1st to finish!
Nice job!
    March 2010
Posted by mach71 on Friday, March 27, 2020 12:00 PM
Working on the seams of the T-38 now. They are not too bad.
    November 2018
Posted by sickdude on Friday, March 27, 2020 2:37 PM
Wow! That went fast tempest, good job Yes. The T-38 is coming along right fine mach, can't wait to see some paint on it Smile.
William (Willy)
Posted by jeaton01 on Friday, March 27, 2020 3:28 PM
The Majister certainly looks goodenuf from here, John.
John
Posted by oortiz10 on Tuesday, March 31, 2020 3:14 PM
Hey mach71,
I have a question about getting in on this GB. I found a couple of started SR-71s at a garage sale that are in different states of completion/disrepair. One of them is a -B model. My goal is to do what I can to restore/finish the bith of them. The problem is, rhe -B might break the rule number 4; Any build, kit/kitbash/scratch build as long as it's less than 50% complete at the start
Is it too far along for this GB?
Let me know. Thanks!
-O
-It's Omar, but they call me "O".
    March 2010
Posted by mach71 on Tuesday, March 31, 2020 8:41 PM
No, it's fine.
Welcome to the GB!
    March 2010
Posted by mach71 on Thursday, April 2, 2020 2:43 PM
Back to work on my T-38!
The wings/Stabilizers are on.
I've started to do some detail painting.
    March 2010
Posted by mach71 on Friday, April 3, 2020 2:18 PM
The gear doors and nose gear are on.
And getting the main gear ready.
    March 2010
Posted by mach71 on Saturday, April 4, 2020 4:08 PM
2 coats of primer.
The under wing seams are proving to be a pain.
Posted by Bish on Tuesday, April 7, 2020 10:06 AM
First build post from me of the Me 262.
I am adding an Eduard PE set which is designed for the Revell kit but seems to be fitting this well. The pit wnet together quickly, i used the kit decals for the side instruments as tehre was no PE for those bits. The kit seats have been completly replaced with PE.
The pit was then fitted and the fuselage put together.
And the wings were added.
I am building this alongside another aircraft and my S-100 boat so it won't go together as quick as it could, but i hope to have another update soon.
Posted by jeaton01 on Tuesday, April 7, 2020 12:49 PM
Those seats look pretty good, Martin.
John
Posted by jeaton01 on Tuesday, April 7, 2020 12:50 PM
It's coming together nicely, Mach 71.  Those underwing seams might be a candidate for epoxy putty like Milliput and a wet finger.
John
    March 2010
Posted by mach71 on Tuesday, April 7, 2020 3:13 PM
Bish, your 262 looks great! The cockpit is outstanding!
Thanks Jeaton. I'll give it a try.
I'm out of white paint, so I have some time.
Some stuff to pass the time today:
This stuff might be used in this GB.
    March 2010
Posted by mach71 on Wednesday, April 15, 2020 3:40 PM
I've been working the seams on the under wing of the T-38. Not much is really working well. I tried Aves putty and thined white putty. I might have to live with them.
I've also been working on a small T-37 I found in my stash. It's a 1/72 Hasegawa kit that is missing the instructions.
Working on the cockpit.
The big parts are on.
I'm thinking about a possable diorama with both aircraft.
Posted by Bish on Wednesday, April 15, 2020 3:43 PM
Thanks guys.
Thats come together well Mach. Is that ground equipment from one of those Hasegawa sets?
    March 2010
Posted by mach71 on Wednesday, April 15, 2020 3:59 PM
Yah, It's from the Hasegawa 1/48 USAF ground crew set.
    September 2011
Posted by falconmod on Thursday, April 16, 2020 7:58 AM
I would like to add the Revell of Germany Bae Hawk T.1 to my list.  Since I'm working at at home during this covid business this one jumped out of the pile sitting on my work bench
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    March 2010
Posted by mach71 on Thursday, April 16, 2020 8:06 AM
Updated!
That looks nice!
    March 2010
Posted by mach71 on Thursday, April 16, 2020 2:39 PM
Canopy masking time!
Having to mask a canopy by hand really makes me appreciate a nice pre cut mask!
    March 2010
Posted by mach71 on Friday, April 17, 2020 3:03 PM
The tweet got it's 1st coat of primer today.
