Supermarine/Vickers GB
    June 2017
Posted by fotofrank on Tuesday, March 9, 2021 8:09 PM
Gamera
Frank: Love the Mk XIV, probably my favorite Spit ever. So graceful, so brutal...
Gamera, the kit will be here tomorrow sometime. I'll do a brief inspection of the box conttents then start with the fuselage interior. I really like these new Airfix kits.
Edit: (03/10) The Mk XIV has just arrived.
OK. In the stash: Way too much to build in one lifetime...
Posted by Gamera on Thursday, March 11, 2021 8:56 AM
Gary: Looks cool! Good luck with the broken prop.
Frank: Awesome! Looking forward to you starting on her.
GAF
    June 2012
Posted by GAF on Friday, March 12, 2021 2:55 PM
Gamera,
The prop is an easy fix.  I get used to these things.  Big Smile
Got the base coat on the "Airplane That Shall Not Be Named" today.  There are a few spots that need touch-up, but the green needs to go on so it might cover them.  Color looks too light in this photo, but it'll darken as it is weathered.
OTOH, it's two steps forward, one step back.  The tape was not kind to my "night" side, but I decided to chance it.
Wonder if I can get away with "heavily weathered"?  Wink
Thanks for looking!
Posted by Gamera on Friday, March 12, 2021 5:28 PM
ACK!!! That was looking so good Gary, hope you can sand out and repaint the peeled paint on the wing without any issues. Indifferent
Posted by Bish on Friday, March 12, 2021 5:38 PM
O, Gary, thats not good. I have seen paint come up with tape but not that much.
    June 2017
Posted by fotofrank on Monday, March 15, 2021 3:30 PM
Well, the Eduard canopy mask arrived today for the Spitfire Mk XIV. So, being the patient man that I am, I immediately opened up the kit and began doing some assembly. I hafta say that the panel lines and rivet detail are so fine and there are so many tiny parts. This build will keep me busy for a while.
    May 2020
Posted by Deeve_ on Thursday, March 25, 2021 3:34 PM
Almost done with my Hasegawa mk.ix. I have done all the assembly and exterior paint. Just painting the roundels and markings. I picked up a Cricut machine a couple of weeks ago and have made decal masks and a canopy mask. First time doing this so here's hoping it turns out ok. This is a test bed now.
 In Progress.
1/72 Italeri XB-70 Valkyrie
1/72 Heller P47n
1/48 Monogram FW190A
1/72 Hasegawa HE111H6
Deeve_
Posted by Tojo72 on Saturday, March 27, 2021 2:30 PM
Here is my attempt to join this group build.Its been awhile since I participated in one but I really wanted to join since Bish was running it and I did have this kit on hand for a few years.hope I could get it done
Posted by Bish on Saturday, March 27, 2021 2:33 PM
I'll gte you on the roster Tojo. Good to see you getting the GB bug again.
Posted by Bish on Saturday, March 27, 2021 2:34 PM
Looks nice there Deeve. What masks are you useing for the markings.
    May 2020
Posted by Deeve_ on Saturday, March 27, 2021 3:21 PM
Bish
I made them. I scanned the decal sheet (Eagle Editions EC48-116) and cut them onto Tamiya masking tape with a Cricut machine. I did some of them using the removable vinyl sticker sheets that came with the machine when I bought it. I should have used just the sticker sheets cause they have a bit more rigidity and hold their shape better. The roundels were a bit of a pain in the butt to get lined up nicely. I ended up with a bit of wobble in some of the circles, but for a first try it came out pretty nicely I think.
I did get a bit of bleed under the masks, but nothing that I cant live with. Main issue I had is the images I had scanned were at a very hi resolution and when I imported the images into the Cricut machine, it took the pixelation to be jagged lines so some of the lines are jaggy and it shows in the end result. I will have to smooth out the lines before importing in the future. I am doing a DO 335 right now and I plan to make masks for all the insignias as they are relatively simple designs and will look better painted on.
 In Progress.
1/72 Heller P47n
Deeve_
Posted by Bish on Saturday, March 27, 2021 3:32 PM
Those came out really well.
    May 2020
Posted by Deeve_ on Saturday, March 27, 2021 5:01 PM
Thanks. I cant wait to get this one off the bench, I am in the home stretch. :)
 In Progress.
1/72 Heller P47n
Deeve_
    April 2006
Posted by jgeratic on Saturday, March 27, 2021 6:38 PM
Gary, that is some nasty paint lifting.  I suspect the fact that you had a layer of metallic paint underneath affected the adhesion of the black paint?   RAF Night is not a true black, and is often described as a dark blue-grey, composed of carbon black and ultramarine blue pigments.
Given that the white/black underwing was an important visual aid for friendly recognition, it's doubtful it woud be left to weather to such a state - but it is your model. If you are going to repaint, I'd suggest a Nato Black hobby paint.
Deeve, great job with the custom masks.  Does your cricut machine have a program that automatically converts jpeg (or whatever image file type you used)?  Usually masks are designed using vector software.   All linear drawing, and is scalable to any size afterwards, with lines remaining consant width.
regards,
Jack
    February 2010
Posted by 68GT on Sunday, March 28, 2021 8:44 AM
I'm in with this ICM Mk VIII in 1/48 scale. If the old Aeromaster Decals hold up I'll be building this one from 457 Squadron.
On Ed's bench, ???
    May 2020
Posted by Deeve_ on Sunday, March 28, 2021 3:22 PM
jgeratic
regards,
Jack
Yeah, the Cricut software that comes with it allows you to import a JPG, PNG, GIF, whatever image file format you prefer. It imports it and vector drawings as well. When I did the Roundels, I actually created them in Coreldraw, using a vernier caliper to measure the decals, then sized the circles up on the grid in the Cricut software so I got them the correct size. Worked out pretty well. But the Letters were just straight from the scan of the decals. Same thing with the tail markings. With the tail markings, I actually went into the JPG and smoothed out the lines, which was easy since they are all straight. Big Smile
I am excited to have this machine, there are so many possibilities. I also found an image of the canopy masks, cleaned it up a bit and cut them. I used my hacked canopy masks, I am about to peel them off to see how they turned out. Hopefully its adequate. Tongue Tied
Only bad thing is that I think I am going to have to buy a copy of Coreldraw. I downloaded the trial version of the current one. Problem is it is like $350. I have a copy of version 9, it works in widows 10, but it lacks so many features and doesnt save in the format that the Cricut software uses.
 In Progress.
1/72 Heller P47n
Deeve_
Posted by Bish on Sunday, March 28, 2021 3:27 PM
Roster is updated, i think i have everyone.
    April 2006
Posted by jgeratic on Sunday, March 28, 2021 6:00 PM
This should come in handy:
regards,
Jack
Posted by jeaton01 on Sunday, March 28, 2021 7:20 PM
My Silhouette likes dxf files, which I draw in Autocad but a less expensive drafting program should be able to output that type of file.  I'm using version X6 for Corel Draw and it doesn't work for me.  The newer versions than X6 are not likely to handle them well either, but I don't know.  The Silhouette software is hard for me to work with but that may be because once I made dxf files from Autocad work there was no point in going further.
CorelDraw is great for drawing decals because it handles colors far better than AutoCad.
John
    May 2020
Posted by Deeve_ on Monday, March 29, 2021 12:28 AM
jeaton01
I actually used a DXF file when I was saving in Coreldraw 9. Worked ok for that. But I would like to have the options for other file types too.  Ive heard the Silhouette has better software than the Cricut.
 In Progress.
1/72 Heller P47n
Deeve_
Posted by Gamera on Monday, March 29, 2021 11:33 AM
Deeve, 68GT, & Tojo: Those all look awesome guys!!! Yes
    May 2020
Posted by Deeve_ on Wednesday, March 31, 2021 1:05 AM
OK. Finnally wrapped up my Hasegawa Spitfire MK.IXc. I added more aftermarket to this kit than any kit I have ever done. Years ago I built a Hasegawa Typhoon and ruined the upper wing roundels. I poached the ones from this kit to finish the Typhoon so I had to find some decals to replace the box ones and picked up EagleCals #116 decals. I decided on AE-W, Lorne M Cameron's aircraft. Simply because I liked the skeleton nose art. Big Smile On top of that I had to replace the wheels due to the lack of 5 spoke wheels included in the kit. Had 3, 4 spoke and solid wheels but not 5. When I ordered the wheels from Ultracast, I also picked up some exhaust stacks. Previously I had picked up Dept of Correction early Spitfire Mk IX prop and spinner. Luckily Lorne's aircraft was an early MK IX so I could use it. I also picked up some Eduard Superfabric belts. I cut off the outer cannon fairing as the aircraft had it deleted. I cut out the door and added the handle and locking bar. I used a Cricut Machine to make masks for the roundels, Identification markins and the tail markings. I used the Cricut to make the canopy masks from a picture I found online. I also hucked out the tail wheel gear and added brake lines to the landing gears.
Things I screwed up. I got some bleed under the canopy masks. As usual, I suck at canopies. I broke the tab that attaches the spinner to the fuselage, so I had to drill everything out and use a toothpick. I neglected to shave off the bulges on the wings as per instructions, until after I had already assembled and primed the whole shebang. Its gone, but you can tell it was there, its all wavery and uneven. I did a poor job of it. I also attached the canopy pieces before I realised I neglected to install the gun sight. That was not easy to put in place with the canopy in place.
Anyways, onto the evidence.
 In Progress.
1/72 Heller P47n
Deeve_
Posted by Bish on Wednesday, March 31, 2021 2:44 AM
Very nicely done there Deeve. Came out great despite the issues you have had.
Thanks for taking part, i have added a pic to the front page.
    June 2017
Posted by fotofrank on Wednesday, March 31, 2021 7:47 AM
Deeve, that's one fine looking Spitfire. Really well done.
Don't be telling us what's wrong with it 'cause we'll never notice...lol.
The build just looks too good overall.
Posted by jeaton01 on Wednesday, March 31, 2021 1:48 PM
Your Spitfire looks great, Deeve, nice finish.  Don't Worry, Be HappyParadise
John
    November 2003
Posted by tempestjohnny on Wednesday, March 31, 2021 2:45 PM
fotofrank
I wouldn't have noticed without....
    April 2006
Posted by jgeratic on Wednesday, March 31, 2021 8:37 PM
Deeve, I like it, and a Canadian Squadron to boot. Yes
regards,
Jack
    May 2020
Posted by Deeve_ on Wednesday, March 31, 2021 9:54 PM
jgeratic
regards,
Jack
Doing a little research, Lorne Cameron is laid to rest not far from where I live.
 In Progress.
1/72 Heller P47n
Deeve_
Posted by Gamera on Thursday, April 1, 2021 8:40 AM
Deeve: That's beautiful!!! I too honestly wouldn't have noticed any of the issues if you hadn't pointed them out!
You should be proud of her, fantastic!!!
Heart
    February 2010
Posted by 68GT on Thursday, April 1, 2021 9:41 PM
I started the ICM Mk. VIII.  Not much to look at but its started.
On Ed's bench, ???
