P-38 Lightning group build - Are we there yet???
Posted by VanceCrozier on Friday, March 4, 2011 7:10 AM
Sanding out putty is next on my list, the stuff around the boom to elevator joint. Canopy glass can probably go on soon too as well as the gun panel on the right side of he nose. It's getting so close now I keep wanting to start spraying the colours... must be patient though! I haven't touched it - other than applying putty - in a week, so I really should sit down with a cup of coffee and just look. I know there are some more details I wanted to add.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    September 2009
Posted by B17Pilot on Friday, March 4, 2011 8:31 AM
Thanks for the compliments, ya'll!  Definitely going to have to try to freehand a OD/NG scheme again, but that will probably be a while has the only one in the build stage with an OD/NG scheme is the B-17D I'm working on and its got a ways to go before paint.
Funny thing is I sprayed another aircraft during the same session, that was masked and it came out worse than the freehand, as the paint got under the tape and onto the white base color Angry
Posted by VanceCrozier on Friday, March 4, 2011 8:33 AM
B17Pilot
...Funny thing is I sprayed another aircraft during the same session, that was masked and it came out worse than the freehand, as the paint got under the tape and onto the white base color Angry
Murphy's Law strikes again! Bang Head
    September 2009
Posted by B17Pilot on Friday, March 4, 2011 8:50 AM
VanceCrozier
I really hate it when he shows up!
Posted by VanceCrozier on Friday, March 4, 2011 8:51 AM
B17Pilot
 VanceCrozier:
He usually drops by my place with fingerprints in unexpected places!
    August 2009
Posted by Sparrowhyperion on Friday, March 4, 2011 9:17 AM
I say we hunt this Murphy guy down and and tie him to a dummy bomb in a B-17F and go do some bomb range practice.
VanceCrozier
 B17Pilot:
 VanceCrozier:
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    March 2009
Posted by Spike190 on Friday, March 4, 2011 11:27 AM
Hey B17 great work on your freehand camo work, it's looking really good. I'm not sure how I'm going to tackle mine yet, still trying to sort out damn pesky seams and stuff! I've got the front and rear canopy attached and hope to get the primer on in the next few days. These P38's sure make you work hard!!
Cheers...
Mike  Toast
    March 2009
Posted by Spike190 on Monday, March 7, 2011 9:48 AM
A little progress.
All masked up and sprayed with Halfords grey plastic primer,
And a chance to experiment a little, I've painted some Humbrol flat Aluminium Metal cote onto some areas which I plant to mask with some liquid mask before the top colours go on, never tried it before so fingers crossed, aiming for some discrete chipping around various panels,
Cheers...
Mike  Toast
Posted by VanceCrozier on Tuesday, March 8, 2011 8:30 AM
Wow Mike, that actually looks good sitting on the red for some reason! I'm trying to decide if I should try that silver undercoat on mine as well. I'm hoping to break up the overall black with a little wear, and I keep wanting to try that salt technique I keep hearing about. (Although the nightfighters didn't see a whole lot of abuse from what I've seen - the P61s did most of the work at that point.)
The pledge: My name is Vance, and I will not neglect my P38 tonight! Sanding out the putty I had to add, and finishing the work on the ailerons are at the top of the list, again.
    March 2009
Posted by Spike190 on Tuesday, March 8, 2011 1:11 PM
Cheers Vance I guess if it looks a bit rubbish I can spray over the silver chippings, you should give it ago. Good luck with your sanding!
Cheers...
Mike  Toast
Posted by VanceCrozier on Tuesday, March 8, 2011 1:14 PM
HA - yes, it looks like one of those effects that can be covered up if it doesn't go as planned. Where mine won't have seen much action I'll be going at it fairly lightly anyway.
Posted by VanceCrozier on Wednesday, March 9, 2011 11:00 AM
VanceCrozier
Sanding on the forward wing-to-nacelle areas last night, once I started getting clear of the putty I realized I still needed to do some leveling between the two nacelle halves, so I just kept smoothing away. I may have to add a few panel lines here.
    November 2008
Posted by daddy1 on Thursday, March 10, 2011 9:49 AM
VanceCrozier
 VanceCrozier:
 I know the feeling Vance. Been going through some emotionally stressful times here and it has been hard to get into the modeling rhythm . But forward progress is being made. Here's some update pics.
 In the first pics , I noticed from reference pics this little inlet on the nacelles are usually molded to look like tiny scoops on the skin surface, when actually they're tubes coming through the cowling.
 Easy to trim off the scoops ,drill a small hole, glue in a bit of stretched sprue, trim to length. Also drilled out end of the new "tube".
I was cleaning up the seams on the turbo air scoops when one slipped from my fingersOopsBang Head and ended up somewhere  Confused
After much looking and searching, I realized I'd have to scratch a replacement out of sprue  . I still had one as a model.
Found it better to make two new scoops for a better match . I think they are an improvement over the kit parts.
The nose gear well detail looked flat compared to the mains so I decided to add a new roof to the well , which also gave the depth needed to make the little recess the tire fits into. Then added the hydraulic lines and stuff from wire and bits of scrap plastic. Not rivet counter perfect, but a good representation of the nest of lines in the real deal.
Weathered with sludge washes and pastels . I remember seeing a pic of a Lightning taxiing through the mud on some Pacific field . Could barely see the airplane from all the muddy water splashed up, so I imagine the gear wells ended up looking pretty grubby.
Used a round cutter from my Dremel tool , chucked into a pin vise to carve out a shallow "bowl" in the landing light lens. Painted chrome silver , then added new lenses punched out from clear sheet.
Ready to mask and paint after giving a prewash of MM flat black.
This is the waethered effect I'm aiming for .
It's going to be tedious working all the panel lines , but I've been trying out various washes, pigments and pastels on some sheet plastic to get a feel for the colors I'll use.
 I like starting my paint with a base of factory fresh color lightly coated over the prewash and weathered in layers . Weathering happens over time and unevenly.  Should be intersting.
 Got the neutral gray airbrushed on the undersides. Now if the weather will cooperate so I can get the OD on today . Anxious to start getting it aged.
 Howard
http://whlswngsthngs.shutterfly.com/
    March 2009
Posted by Spike190 on Friday, March 11, 2011 6:02 PM
Howard thats some mighty fine work you've got going on, cant wait to see you get the paint going on, should be fun Yes.
Vance you were right, I pulled off the liquid mask and it had worked perfectly but looked wayyyy over done, in fact 'crap' would some it up, so I sprayed over it and now plan on using the tip of my knife or a pin to chip a few small areas. I'll get some pictures up in the next few days.
Cheers...
Mike  Toast
    November 2008
Posted by Wabashwheels on Saturday, March 12, 2011 12:15 AM
Howard,  If you're going to replicate the Lightning in the photo, you might as well grab a wide chisel brush, some OD, and several other shade of dirt and start slapping it on.  That bird is a wreck.  It'll be a lot tougher to make it look "beat to  a pulp" than to make it look perfect.  Good luck, things look great so far.  Rick
    January 2003
Posted by p38jl on Saturday, March 12, 2011 11:44 PM
Looking good !Yes
[Photobucket]
    November 2008
Posted by daddy1 on Sunday, March 13, 2011 7:49 AM
Wabashwheels
  I've got the base neutral gray/olive drab paint on. The Army usually had a hard demarcation between the OD and gray so I used low tack 3M blue tape with Microscales liquid mask along the separation line. Should have used strips of electrical tape for the wavy edge, the liquid mask dried very thin and doesn't want to come off along some key curves. Hard to lift without damaging the paint.  I'm going to gently sand those edges and with a little touch up, use the problem to my advantage to show some wear of the paint.
I probably won't take the wear quite as far as the photos but still enough to give a really tough battle hardened look. I'm still playing/practicing with some washes and pastels on some sheet plastic to decide which way to go to get the effect I want .
 Howard
    January 2007
Posted by Clebode on Sunday, March 13, 2011 12:37 PM
Spike--That's a very clean build.    My next project is an NM B-17 G so I'll be paying attention to you you finish,
All--Here is my finished "Jeanne" flown by Capt. Roy Scrutchfield, 55th FS. 20th FG.
On to the B-17 G "Bottome Up"!
Hugh
Posted by Wingman_kz on Monday, March 14, 2011 2:34 AM
Clebode, Jeanne looks mighty fine! I'm sure the Captain would be proud. Yes
Tired of making excuses fellas. Had big plans for last week and layed around all week with the flu. So here's the plan...
I had openend the shell ejection chutes and did manage to fit some square tubing behind them. Had already drilled holes in the front and rear of the rear landing gear bays for the tubing going to the radiators and fitted some pieces of solder for the tubing. I'm leaving it at that. Gonna button everything up, mask the canopy and start shooting some paint. To paraphrase someone's signature, *Better done than perfect*. Toast Wish me luck...
Tony
    March 2009
Posted by Spike190 on Monday, March 14, 2011 4:58 AM
Good luck wingmanYes
Hugh she looks great, I like the variations in the OD. Top job sir Toast
I've been playing with paint Big Smile. Pictures are a bit dodgy I'm afraid.
I want to add some highlights on the under side and then I can get to the decals before doing some more weathering.
Hope you like so far.
Cheers...
Mike  Toast
Posted by VanceCrozier on Monday, March 14, 2011 7:04 AM
daddy1 - nice recovery on the turbo scoop & good call on scratching a pair for the better match. The gear bays look great too. Pre-wash of flat black rather than airbrushing panel lines? Why not - looks good so far!
Spike190 - not so much that I was right about anything, so much as me thinking "what would I do after I screwed that one up!" The topside colours are looking great on yours as well, love the variations.
Clebode - is next past the finish line! I love the variation on your topcoat, great job buddy. I'll add this to the finished list up front. I love those big toothy smiles!
Wingman_kz - Better done than perfect!? Yep, I need to follow through on that one. This past week was March break for the school-age gang. We didn't go anywhere but the kid was all over the place (needing transport) or hosting other 13-year old cheerleaders at our place, five or six at a time Indifferent… not conducive to modelling! Crying Back to school this week, more sanding tonight.
    January 2003
Posted by p38jl on Monday, March 14, 2011 8:24 AM
Cleobold.. ! nice job ...! Toast
[Photobucket]
    November 2008
Posted by daddy1 on Monday, March 14, 2011 9:27 PM
Had a bit of a set back last night. I had removed all the stubborn mask along the demarcation lines and almost finished touching up the paint when OopsBang Head, the thing decided to take a brief flight from my hand to the floorCrying
 Fortunately, it hit on the nose and broke only along the seam where the nose attaches anyways. Simple fix , but was looking forward to start the weathering process last night . Got it fixed and touched up and will start weathering tomorrow.
RATS!!!
The gods were smiling on me as it broke on the seam without any chunks of filler breaking away. Just a matter of re-gluing the nose back on, cleaning up the seam, and touching up the paint. This time without dropping it.
Another of my sample sheets to check various washes and pastels.
Not a bad recovery. Hand brushing a light coat of OD came out a touch darker than the airbrush, but with weathering it will blend and even enhance the effect.
 BTW- The prewash method actually works better than the pics show. I've only started pre shading and pre washing  the past year and a half or so. Still getting the hang of painting my color on without covering up the shading . I need to learn not to make that one more pass with the airbrush.
 Howard
Posted by VanceCrozier on Tuesday, March 15, 2011 7:22 AM
Howard, that may be the best bad luck I've ever seen! You're right though, after weathering that could actually add to the look - nice recovery. You need to tell us about your "sample sheet"! So you've done a base coat & applied various weathering & washes?? You sir, have done your homework! Indifferent
Got a few minutes at the bench last night, think I'm just about done sanding with the exception of one seam on a boom, I may have to run a little more filler in there & sand it out a little more. Once I'm done all the bodywork I can add the canopies.
    January 2003
Posted by p38jl on Tuesday, March 15, 2011 12:40 PM
Howard.. good recovery !
Vance ! man... hope to see some pics !
ps.. thinking of adding a 2nd -38.. with mystery markings.. real,, but not seen often...Surprise
[Photobucket]
Posted by VanceCrozier on Tuesday, March 15, 2011 12:47 PM
Well I keep going back to the nacelles & sanding/puttying... it still looks the same, but I swear I'm actually doing something to it! I need an extended "home alone" session. ~cough cough~ maybe I'm coming down with a cold & need to stay home... Whistling
    November 2008
Posted by daddy1 on Tuesday, March 15, 2011 11:16 PM
Vance-  I hear you about the home alone session. My daughter's 8 , does this sound familiar? " Emma , get in your bed and go to sleep." "But, I'm not tired."  LOL
 Anyways , my sample sheet is just a piece of sheet styrene I base coated with OD ( I have another with neutral gray). I've been trying out different color washes , pastels , and pigments  on that to get a feel for how they affect the base colors and also how much an overcoat of clear will affect them.  Basically practice before applying to my model.
I've only recently started using pastels and pigments , I like the way they can subtly alter the base colors they're applied to. Easy to use too. Another weapon in the modeling skill arsenal.
 I've got 4 jars  of Model Makerz pigments I won in an online contest at uberhobby.com.  Liked how well the stuff worked , decided to pick up some  General's pastel chalks in a earth,portrait, skin tone set from Michale's craft store. Also picked up some pastel chalks on clearance at a local art supply store. I've also given thought to trying out some shades of of eye shadow/makeup as weathering pigments.
  My wife had a couple extra brushes from her Bare Minerals stuff that work great for applying and blending the powdered pastels and pigments. They're thick, soft and can be found in sizes from a fine point to large , broad  and flat. The little foam tipped makup applicators are useful too.
 Amazing what we can find beyond the LHS.
 Howard
Posted by VanceCrozier on Wednesday, March 16, 2011 7:48 AM
daddy1
Very familiar, except mine is 13 and routinely just getting home from cheerleading practice at 9pm... Indifferent
That's a great idea for the sample sheet. Several times I've looked at doing some effect on an almost-finished kit & then thought better of it because I wasn't sure how it would turn out. If I built quicker I'd have a test mule somewhere...
    November 2008
Posted by daddy1 on Wednesday, March 16, 2011 10:20 PM
Vance , how do you get the rotating GB badges in your siggy? I like it , good way to show all ones badges.
 I used to build quicker till I raised the bar for myself getting involved in these forums. They're a great learning tool and confidence builder.
 I've started working some pastels into the paint to get a well faded look. The underside looks good but I'm about halfway across the topside OD and it seems a bit too whitish , although the vintage color pic I posted isn't far off from what I'm coming up with. Will post some fresh pics in a day or two.
Howard
Posted by VanceCrozier on Thursday, March 17, 2011 8:22 AM
daddy1
Howard
I'm using Photoshop to create an "animated gif", you set up multiple frames & add a transition between them. (I'm a graphic designer, so I've got Photoshop on every machine I own!) Not sure if you can do the same thing on Photoshop Elements, or any of the other "light" graphics programs that often ship with digital cameras. I know you can do the same thing using GifBuilder, a freebie program that has been around awhile (http://www.tucows.com/preview/206447).
I think we all used to be quicker Howard! (except for fermis - he seems to be getting quicker!) This forum does tend to make me want to try new or different things for sure - that's a good thing right?! Which reminds me, I need to track down some pastels so I can give that a shot.
That OD upper surface did seem to get washed out pretty hard in the Pacific sun, you're probably fine.
