Delta Wing GB 5/11 - 1/12
    December 2006
Posted by Fly-n-hi on Sunday, May 8, 2011 10:36 AM
Hi guys.  I am about to start a Revell 1/48 EF-2000 and I thought it would be fun to turn it into a group build.  I was thinking that it would be a delta wing group build that would basically include all aircraft have a triangular shape.  Some examples would be (but not limited to):
  • EF-2000
  • Mirage 2000
  • Mirage F1
  • F-102/F-106
  • F-117
  • B-2
  • Concorde
  • F-21
  • Rafale
  • XB-70
  • Saab Gripen
  • Saab Viggen
  • Avro Vulcan
  • B-58
  • F-16XL
  • Space Shuttle
  • Snow Speeder (Star Wars)
  • J-10
  • TU-144
  • SR-71
  • Douglas Skyray
The models can be real, Sci-Fi, concept demonstrators, new or old.  The basic idea, though, is to build aircraft without the traditional horizontal stabilizers, i.e no MiG-21s or F-16s.  New builds are preferred but builds that are up to 50% complete are welcome.  Cross group builds are welcome are well.
I came up with a couple of ideas for GB badges but feel free to submit your own ideas.  The final decision will be made a little while later.
Happy Building!
    December 2006
Posted by Fly-n-hi on Sunday, May 8, 2011 10:37 AM
Builders:
  • Revell 1/48 EF-2000 by Fly-n-hi
    December 2006
Posted by Fly-n-hi on Sunday, May 8, 2011 10:40 AM
Saved...
    December 2006
Posted by Fly-n-hi on Sunday, May 8, 2011 11:39 AM
Ok. Here's a progress pic.  I'm going to build my EF-2000 mostly OOB but I am going try to put the leading edge slats in the extended position.  There will be a little work involved but it should be fairly easy to do.
I might have to fix up the intakes too.  There are no trunks or fan blades.  There's just a flat wall about an inch in.  Kinda lame.
    December 2006
Posted by Fly-n-hi on Sunday, May 15, 2011 5:50 PM
Well, I can see that this GB generated zero interest.  I'll keep posting pics of my progress anyway in case anyone else gets the urge to join.
Here's where I'm at so far.  The ejection seat is ok but the molded in seatbelts are cheesy so I sanded them off and scratch built some using foil tape.  I just folded it over itself and cut it into thin strips and added some little buckles.
I decided to attach the partially completed intake to the upper half of the fuselage instead of attaching it to the lower part like the directions call for.  After some dry fitting it seemed like it would be a little easier to make it seamless this way...and it was.  But that's just the inner part.
The APU exhaust was just a depression in the side of the fuselage so I drilled it out and cut a styrene tube to make a more convincing exhaust port.  This took about 5 minuted to do and cost practically nothing.
This kit has nice detail but it also has some bad fit issues.  The radome was a smaller diameter than the fuselage and the instrument panel sat about 1 mm higher than the glare shield.  I used Apoxie Sculpt to fill it out.
The dorsal spine, especially around the airbrake, had some nasty gaps, too.  If you want the airbrake in the retracted position you need to sand down the airbrake itself...and some of the oddly raised plastic underneath where it mounds to the fuselage.
Making the completed intake seamless is going to be a bit challenging but I think its doable.  I had to trim the side pieces of the intake mouth to get them to fit correctly.  I don't know if its because they were molded poorly or because I mounted the intake out of order.
There were some nasty gaps at the tail where the top fuselage half met the bottom half.  The putty is the same color as the plastic so its a bit hard to see it.
