Well, I got my first post in on Metalizers and already have a change. Since the post I did more Metalizer research. I'm not sure I want to deal with the headaches of trying to successfully mask Metalizer (which apparently doesn't work well), dealing with decals (and clear coating over them), or the delicacies of handling. I'm pretty adept at modeling, but have never worked with Testors Metalizer and don't plan on working with Alclad.
Are there other alternative paints that will get me close to the aluminum and magnesium look, such as...?
- VHT Nu-cast Engine Coating: they are all rattle cans, but they have a color called "Cast Aluminum Look," which I suspect might be similar to magnesium. I'm concerned that it might spray too thick, although previous auto experience with VHT paints were pretty good.
- Dupli-Color Wheel Coating: comes in silver and graphite. Used to dress up worn out auto wheels (acrylic enamel). Claims to have a highly reflective metallic finish with superior adhesion to plastic.
- Eastwood Factory Gray High Temp Coating Spray: it says cast iron color, so it's probably way too dark, but at least my B-36 model could now withstand temps up to 1200 degrees.
I'm looking for a finish that is not as delicate as Metalizers and I can still mask and decal (and handle) carefully, but without paranoia of damage.
Thanks.
