"Dirty Robot" group build April 3rd - May 3rd 2020
Posted by Gamera on Friday, April 10, 2020 8:45 AM
Oh wow that looks awesome Stephen!!!
Personally I'd just use putty but liquid sprue should work just as well.
Good luck!!!
    May 2011
Posted by Real G on Friday, April 10, 2020 4:27 PM
I'll post some how-to photos of the sprue filler technique to allay any apprehensions to using the process.  It really changed the way I build models.
Anyway, this little Seapiggy got worked on last night:
I need to clean up the polycap joints before the leg halves can be glued together.  The material the polycaps are made of must be some kind of polymer blend, as it is possible to gently sand off the parting lines.  As much as I obsess on painting everything, I think I will leave these unpainted and only apply weathering on them.  A couple of buddies did theirs that way and they looked fine.
I need to keep focus and build the piggy.  Build the piggy, build the piggy, BUILD THE PIGGY!
“Ya ya ya, unicorn papoi!”
    July 2019
Posted by Robotism on Friday, April 10, 2020 6:23 PM
Here Piggy piggy piggy! Looks like it's coming along niceless. Not painting polycaps sounds a good idea.
Made a lot of progress tonight but I'll show that later or edit it in later because I want to record my success and suffering on this piece here.
The large piece has a flexible and fragile back "wing". The polycap at the front doesn't fit unless seriously trimmed down. The red cross bar has to go across another piece you install at the same time and there is no way to avoid having to do all this at once. The fittings are so fit you have to pre-trim them or this would never close and I struggled as it was. I've never found a kit with a difficulty curve before but this is the last boss or the super secret boss you're supposed to do after you finish the game.. Either way it's one of the hardest pieces I've ever built.
There's a lot of progress tonight but it looks way less than the work that went into it. The kit has quite a bit of internal detail but no good way to display it, so you build a lot of stuff only to cover the whole piece with large covers. I have lots of big chunky bits to show off later.
    April 2011
Posted by badlanguage on Sunday, April 12, 2020 11:48 AM
Love the Piggy so far! At some point in my life I'll have to build a MaK model.
Got lots o part primed. Gotta check/fix my seam filling and then it's painting time.
    July 2019
Posted by Robotism on Sunday, April 12, 2020 7:50 PM
Are you going for the original colours Bad or something original?
I guess this is the first true dirty robot post of the thread. Cover any small children's eyes and maybe the wifes... But here we go!
The legs are untouchable unless you want to go parts hunting. They're pure grenade and won't stay together enough to even take a photo with the legs built. I have the rear skirt and the weapons pod to build and then it's seam fixing time. Seams are really bad on parts but there's few of those parts.
I have no idea how to split this up for painting. Too many parts rely on each other and it's too stiff a build to split it apart.
    April 2011
Posted by badlanguage on Sunday, April 12, 2020 9:40 PM
Robotism
I'm planning going with a desert paint scheme, but then add a worn winter whitewashing to it a la German WWII armor. Never tried that before so we'll have to see how it goes.
Good luck on your build! You'll figure a way.
    July 2019
Posted by Robotism on Sunday, April 12, 2020 9:42 PM
That sounds great. I've been wanting to do a winter wash MS for a while not but haven't got round to it.
Posted by Gamera on Monday, April 13, 2020 11:20 AM
Ohhhhhhhhhhhh, those look awesome guys!!!
My wire came in Friday (thanks Real G!) and it fiddled around with it and the LED some Fri and Sat. I was hoping to get her all in place and ready to go Easter Sunday but ended up getting a splitting headache and nothing done.
Cross your fingers I'll get everything in place this week and be ready to paint.
    May 2011
Posted by Real G on Monday, April 13, 2020 5:10 PM
As promised, here is the sprue technique I use to fill gaps.
Some conditions, like the heel area, are better off using conventional putty.
And so puttying commences.
    May 2011
Posted by Real G on Monday, April 13, 2020 10:55 PM
Stephen,
Holding the stretched sprue in the liquid cement bottle for a few seconds helps sometimes. But if the kit’s plastic formula is brittle, it will still crack.  Yes use the Tamiya or Gunze glues, as they are a lot hotter than Testors.
    July 2019
Posted by Robotism on Tuesday, April 14, 2020 12:30 PM
was browsing through the Advance of Zeta books as research and stumbled across this Dom, good inspiration. Siek Zeon
    May 2011
Posted by Real G on Tuesday, April 14, 2020 1:00 PM
Robotism
That Dom was from 0080: War in the Pocket.
Advance of Zeta introduced the Dom Stutzer, which featured a long vertical fin affixed to its front for some odd reason.
https://gundam.fandom.com/wiki/MS-09R_Rick_Dom_%EF%BC%BBStutzer%EF%BC%BD
Posted by Gamera on Tuesday, April 14, 2020 1:46 PM
Real G & Stephen: Those are coming along great guys!!!
    July 2019
Posted by Robotism on Tuesday, April 14, 2020 3:26 PM
Real G
Robotism
The kit used is the Dom Tropen from 0083 not 0080. But that scheme is from AoZ which started the Zeon Alive slogans on the suits which is why I mentioned the source.
    April 2011
Posted by badlanguage on Tuesday, April 14, 2020 10:33 PM
Did some painting on my pieces parts:
I think this paint is the flattest flat ever. I love it, but I need to clear coat, decal, clear coat, hair spray, white, mess up, hair spray, white, mess up, wash, and maybe clear again. We'll see. Oh, and do the metal parts too. Can't forget that.
    July 2019
Posted by Robotism on Wednesday, April 15, 2020 10:24 AM
What paints are those Bad? They look fantastic.
    April 2011
Posted by badlanguage on Wednesday, April 15, 2020 3:27 PM
Robotism
Thanks! They're Tamiya paints - the brown is flat earth, the medium tan is desert yellow, and the lighter tan is buff. No idea why I had them lying around but I'm glad I did.
    April 2011
Posted by badlanguage on Thursday, April 16, 2020 3:50 PM
Got a clear coat on, and wanted to put the fella mostly together to put decals on. Here he is:
I'll probably take him apart down to arms, legs, and torso to whitewash and gunk up and stuff.
    September 2006
Posted by NucMedTech on Thursday, April 16, 2020 10:00 PM
That is looking real good. I like the desert scheme you got going on there.
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
Posted by Gamera on Friday, April 17, 2020 9:08 AM
Yeah, that's superb work BL!  Looking forward to seeing him all dirtied up.
    May 2011
Posted by Real G on Friday, April 17, 2020 12:56 PM
Round 1 of scraping putty and sanding seams is done.
I noticed when the body side panels are closed up, they can move past the vertical, which causes gaps between them and the front body armor.  So I glued a length of sprue to steady them.
Seems to work.  I'll be doing this on all Wave SAFS based kits in the stash.
Now for filler Round 2...
    July 2019
Posted by Robotism on Friday, April 17, 2020 8:27 PM
Tonights progress, which completes the full MS. The weapons still need doing but the main body is done being built. Had to take a few days off so progress has slowed. I would of liked to build more tonight but after almost stabbing myself with a dropped knife and having a part with super glue ping off towards my eye I called it a night.
    April 2011
Posted by badlanguage on Saturday, April 18, 2020 11:31 AM
Robotism
MS is looking good! I think near misses with knives and superglued eyeballs are omens to quit for the night...
Real G, the pig is coming along nicely! Great job to all!
Posted by Gamera on Sunday, April 19, 2020 2:03 PM
Yeah Real G and Robotism, those look great guys!
I worked yesterday trying to get the LED in OF's head and it just didn't work. The head is just too small in this scale. So I canned it and just went ahead and assembled the figure. I masked off the visor and primed the figure today. Guess it's kinda silly to prime a figure made of black plastic and going to be painted in black chrome with grey primer but I wasn't sure where I'd sanded the edges of some parts if it would show under the Alclad black chrome. So a coat of primer can't hurt...
    May 2011
Posted by Real G on Monday, April 20, 2020 12:44 PM
Gamera, Obsidian Fury looks like he wants to take my toilet paper - or get a hug!  Stick out tongue
Robotism, so what kind of weathering do you have in mind?  It's a space MS, so... SPACE MUD???  Big Smile  Sorry, a friend that is obsessed with weathering concocted the term so that he could demand all my space MS should be covered in mud.  Maybe crispy marks and soot?  Bandai's box art as of late has some great heavy space weathering ideas, like the Jegan.
Badlanguage, okay your MS IS a ground pounder, so have fun with the whitewash and mud!
This little piggy went to the workbench and got another round of wet sanding.
My part alignment for the complex multi-part body shell was not perfect, but things are smoothing out.
    April 2011
Posted by badlanguage on Monday, April 20, 2020 12:55 PM
Gamera
OF is coming along great, can't wait to see him painted!
I added some decals to my Zaku, and got it ready for some white.
I added a coat of white onto him. Now to scuff it up!
    October 2004
Posted by ikar01 on Monday, April 20, 2020 1:57 PM
    September 2006
Posted by NucMedTech on Monday, April 20, 2020 6:54 PM
Real G, spacepiggy is looking good. I can't wait to see how you paint him up.
BL, desert cammo is looking good, interested to see how the scuffed look will turn out. I am kind of iffy with mine.
I went on the opposite end of the thermometer with mine and am trying a winter cammo. Nope, not trying to make it a white rose unit. Yeah, I found that one on wiki so don't be to impressed. I have also started work on the 35mm hand gun.
Not sure why wiki says the hand machine guns are 35 mm while the gattling gun is 75 mm. The barrels on the hand gun are about 4x larger than the gattling gun. Go figure.
Stephen
Posted by Gamera on Tuesday, April 21, 2020 7:39 AM
Oh wow, Stephen, Real G and BL those are coming along great guys!!! Yes
Ikar: I can not see your photos. I clicked on one and I still get don't get anything.
Real G: HAH! So we discover the real purpose for the aliens invasion. They come from the dimension CORNHOLIO and they came to take our TP!!!
All joking aside I sprayed the gloss black on OF as primer for the black chrome over the last two days. It's a new experience since I sprayed the front and back Sunday. Then flexed the joints and sprayed again to get in all the nooks and crannies then flexed the joints the other way and sprayed a third time. I think I finally got everything though.
