The X-Files Group Build
GAF
    June 2012
Posted by GAF on Sunday, March 24, 2024 3:55 PM
Looks great, John!  What color did you use?
Gary
Posted by Gamera on Monday, March 25, 2024 7:58 PM
That looks great John!!!
Even more like a fire-cracker!!!
Posted by jeaton01 on Monday, March 25, 2024 10:27 PM
Thanks, Cliff and Gary.  I used Gunze Red Madder for the color, it looked good to me and I had it in the drawer.
This one is a wrap.  All the main gear doors are photoetch on this one, and they are rather weird on the real thing, with one door covering most of the gear well and standing way out from the gear strut. Very delicate! The decals were thin and liked to break, I had to find alternates for the insignia on the fuselage as the kit decals were hopeless. A good coat of Future covered all sins. It really wasn't a very large airplane as you can see in the last photo with a Mustang and D-7.
John
GAF
    June 2012
Posted by GAF on Tuesday, March 26, 2024 5:55 PM
That's spectacular, John!  That red really stands out!  Congrats!
I'll get you up on the front page ASAP.
Gary
    November 2003
Posted by bobbaily on Tuesday, March 26, 2024 6:36 PM
Nice build John-love the red!
Bob
    November 2003
Posted by bobbaily on Thursday, March 28, 2024 1:45 PM
Back at it-spent some time masking for the metallic grey for the lower body work-a red pin stripe decal goes above it so the front will be the more challenging task-a clear coat of Tamiya Clear Gloss after tape to hopefully prevent any paint seepage-noticed some 'dirt pimples' (as we called them in the automotive sheet metal stamping sector) that I attempted to polish out but went a bit too far and will require another coat of silver before clear coat....anyway, hopefully I can paint the grey tomorrow.
It appears that the good folks at Imgur have made some changes on posting formats, so I'll be researching for a bit....grrrrrr
Edit-looks like the folks at Imgur do give the option of using the prior format-thankful for that.....anyway, here's the Aerotech before trim work.  Gonna try to get the engine and suspension wraped up next week...
Bob
Posted by jeaton01 on Thursday, March 28, 2024 9:10 PM
Thanks, Gary and Bob.  Looks like you are getting pretty close, Bob.  I hate dirt pimples but they are certainly attracted to my paint jobs!
John
GAF
    June 2012
Posted by GAF on Friday, March 29, 2024 6:59 AM
Nice, Bob!  Off to the paint booth!  The "dirt pimples" will sand out.
Gary
GAF
    June 2012
Posted by GAF on Friday, March 29, 2024 7:05 AM
Douglas X-3
The Douglas X-3 Stiletto was the sleekest of the early experimental aircraft, but its research accomplishments were not those originally planned. It was originally intended for advanced Mach 2 turbojet propulsion testing, but it fell largely into the category of configuration explorers, as it never met its original performance goals due to inadequate engines. The goal of the aircraft was ambitious—it was to take off from the ground under its own power, climb to high altitude, maintain a sustained cruise speed of Mach 2, then land under its own power. The aircraft was also to test the feasibility of low-aspect-ratio wings, and the large-scale use of titanium in aircraft structures.
Construction of a pair of X-3s was approved on 30 June 1949. During development, the X-3's planned Westinghouse J46 engines were unable to meet the thrust, size and weight requirements, so lower-thrust Westinghouse J34 turbojets were substituted, producing only 4,900 pounds-force (22 kilonewtons) of thrust with afterburner rather than the planned 7,000 lbf (31 kN). The first aircraft was built and delivered to Edwards Air Force Base, California, on 11 September 1952.
The X-3 featured an unusual slender, streamlined shape having a very long, gently-tapered nose and small trapezoidal wings. The aim was to create the thinnest and most slender shape possible in order to achieve low drag at supersonic speeds. The extended nose was to allow for the provision of test equipment while the semi-buried cockpit and windscreen were designed to alleviate the effects of "thermal thicket" conditions. The low aspect ratio, unswept wings were designed for high speed and later the Lockheed design team used data from the X-3 tests for the similar F-104 Starfighter wing design. Due to both engine and airframe problems, the partially completed second aircraft was cancelled, and its components were used for spare parts.
With the completion of the contractor test program in December 1953, the X-3 was delivered to the United States Air Force. The poor performance of the X-3 meant only an abbreviated program would be made, to gain experience with low aspect ratio wings. Lieutenant Colonel Frank Everest and Major Chuck Yeager each made three flights. Although flown by Air Force pilots, these were counted as NACA flights. With the last flight by Yeager in July 1954, NACA made plans for a limited series of research flights with the X-3. The initial flights looked at longitudinal stability and control, wing and tail loads, and pressure distribution.
NACA pilot Joseph A. Walker made his pilot checkout flight in the X-3 on 23 August 1954, then conducted eight research flights in September and October. By late October, the research program was expanded to include lateral and directional stability tests. In these tests, the X-3 was abruptly rolled at transonic and supersonic speeds, with the rudder kept centered. Despite its shortcomings, the X-3 was ideal for these tests. The mass of its engines, fuel and structure was concentrated in its long, narrow fuselage, while its wings were short and stubby. As a result, the X-3 was "loaded" along its fuselage, rather than its wings. This was typical of the fighter aircraft then in development or testing.
These tests would lead to the X-3's most significant flight, and the near-loss of the aircraft. On 27 October 1954, Walker made an abrupt left roll at Mach 0.92 and an altitude of 30,000 feet (9,100 metres). The X-3 rolled as expected, but also pitched up 20° and yawed 16°. The aircraft gyrated for five seconds before Walker was able to get it back under control. He then set up for the next test point. Walker put the X-3 into a dive, accelerating to Mach 1.154 at 32,356 ft (9,862 m), where he made an abrupt left roll. The aircraft pitched down and recorded an acceleration of -6.7 g (-66 m/s²), then pitched upwards to +7 g (69 m/s²). At the same time, the X-3 side-slipped, resulting in a loading of 2 g (20 m/s²). Walker managed to bring the X-3 under control and successfully landed.
The post-flight examination showed that the fuselage had been subjected to its maximum load limit. Had the acceleration been higher, the aircraft could have broken up. Walker and the X-3 had experienced "roll inertia coupling," in which a maneuver in one axis will cause an uncommanded maneuver in one or two others. At the same time, several North American F-100 Super Sabres were involved in similar incidents. A research program was started by NACA to understand the problem and find solutions.
For the X-3, the roll coupling flight was the high point of its history. The aircraft was grounded for nearly a year after the flight, and never again explored its roll stability and control boundaries. Walker made another ten flights between 20 September 1955 and the last on 23 May 1956. The aircraft was subsequently retired to the National Museum of the United States Air Force.
Although the X-3 never met its intention of providing aerodynamic data in Mach 2 cruise, its short service was of value. It showed the dangers of roll inertia coupling, and provided early flight test data on the phenomenon. Its small, highly loaded unswept wing was used in the Lockheed F-104 Starfighter, and it was one of the first aircraft to use titanium. Finally, the X-3's very high takeoff and landing speeds required improvements in tire technology.
Posted by Gamera on Friday, March 29, 2024 8:26 PM
John: Whoa! She looks fantastic! Great job!!! Heart
Bob: Great to see her coming along! I always get the same 'dirt pimple' or dust or something in all my finishes.
    November 2003
Posted by bobbaily on Monday, April 8, 2024 4:32 PM
Making some progress on the Aerotech-got the dark metallic grey painted-not perfect but close enough
The front end was a bigger concern with the curvature-not sure if the decal will match but if not, I can live without the red stripe
The upper cowling will fit snugger so the seam should be minimal-it does show on the real vehicle.
Drivers seat attached
Indycar bodywork is attached to the Aerotech body, engine is maybe 85% complete-hope to have the ignition wiring & rest of the engine & chasis complete tomorrow (maybe)
Most flaws will be hidden by the body....Whistling
Gary-thanks for posting the info for the Douglas X-3 Stiletto-I've added the Lindberg kit to my stash, along with some other X-Files types for future GB's....or maybe this one if I get on a streak....
Bob
Posted by Gamera on Monday, April 8, 2024 11:03 PM
Bob: That looks perfect to me! Love how the finish came out. Heart
GAF
    June 2012
Posted by GAF on Wednesday, April 10, 2024 12:17 AM
Excellent work, Bob.  She'll be a beauty once finished!
Gary
    November 2003
Posted by bobbaily on Wednesday, April 17, 2024 6:34 PM
Thanks Gamera & Gary....having said that, I realized that I needed to add the cooling scoops to the body work-something that should have been done prior to prime/paint.  Here is the gap from the underside:
Attempted to do some Tamiya white putty, sanding & painting-not happy with it:
Also, thie pics don't show it but the Frog tape (and Tamiya 6mm also) left residue-I'm sure from not allowing the clear coat to cure but I could not get the seams to an acceptable finish and really didn't want to deal with removing the paint at this point.
Fortunatly, thanks to a very generous forum member who had the same kit he was willing to part with for a very fair price, I had picked up another kit to build the long tail version in the future. I had primed the short tail from the new kit prior (for some unknown reason), used the new kit front body work & added the cooling scoops and added Tamiya grey putty (had used Tamiya white for the initial attempts above) .  Also taped off the seams to minimize putty cleanup.   After sanding, happier with it-won't know until I prime (using Tamiya grey this time).
after filing & sanding:
Gonna be tied up until Monday but hopefully/maybe I'll get finished by the end of the month....or not..
Cheers
Bob
Posted by Gamera on Wednesday, April 17, 2024 9:07 PM
Oh wow, good luck Bob! Gawd I hate gloss finishes...
Finally got the FV4005 washed and the flat finish on. Hopefully pictures before not too much longer.
BTW: I've been calling it a FV four-oh-oh-five.
But being British I guess it should be a FV four-naught-naught-five...
GAF
    June 2012
Posted by GAF on Wednesday, April 17, 2024 9:29 PM
Great work, Bob!  Gloss finishes are a pain... really!
Gamera> A double-nought tank?  Reminds me of this. Wink
https://www.youtube.com/watch?v=1MWq6L19eNo
Gary
Posted by Gamera on Thursday, April 18, 2024 7:52 PM
LOL Gary, the Hillbillies were a classic!
Or I guess FV Four, Zed, Zed, Five would be British too....
