ALL SUBJECTS - Aussie Group build (ends 10/31/04)
    September 2003
Posted by nicholma on Sunday, August 22, 2004 3:41 AM
Thks j.s. Rather odd because it shows up OK here for me and in the previewConfused [%-)]. I'll reload it from photobucket, hopefully it will work for you.
Reloaded; any betterQuestion [?]Question [?]
Kia ora, Mark "Time flies like the wind, fruit flies like bananas"
Posted by darson on Sunday, August 22, 2004 4:22 AM
nicholma,
I don't know about before, but it looks just fine to me now.
Great job! Thumbs Up [tup]
Darren
Posted by darson on Sunday, August 22, 2004 5:06 AM
phroosh,
I don't know if it will help your research at all, but I found the following picture of a 13 SQN Hudson stuck in the mud in 1941.
I also found out that the squadron serial was changed from N to SF in 1943, which was also when the squadron began to replace their Hudsons with Lockheed Venturas
The other thing that I found out about 13 SQN that I didn't know was former PM Gough Whitlam served as a navigator-bombaimer rising to flight lieutenant with 13 Squadron Ventura PV1's.
Cheers
Darren
Posted by Anonymous on Sunday, August 22, 2004 9:05 AM
got it now mate looks great,in the words of my son that looks sick manBig Smile [:D]Cool [8D]
Posted by Anonymous on Sunday, August 22, 2004 7:35 PM
nicholma,
Thanks for the info on the Bob jane camaro and the warning about the decals?Wink [;)] the merc looks very nice Big Smile [:D] considering the problems you had with it?
Cheers Trev
Posted by darson on Monday, August 23, 2004 8:19 AM
Well, the Spitfire Mk.VIII is moving along at a reasonable clip.
The cockpit is done and the airframe is now sealed with the wings attached. Next will be the tail area and then a heavy dose of pre-shading.
I was going to post a couple of progress shots but unfortunately the few photos of the interior that I took were all out of focus when I down loaded then to the PC (still working on the old close-up digital camera skills).
Oh well, stuff happens.
Cheers
Darren
Posted by Anonymous on Wednesday, August 25, 2004 2:01 AM
Heres a progress shot of the Spitfire MKV111,sorry the pics a little out of focus it's my first time using the digital camera.........J.S....
Posted by darson on Wednesday, August 25, 2004 6:22 PM
J.S
Looks pretty darn good to me Thumbs Up [tup]. I'm really going to have to extract the digit now to catch up.
Tell me, what color did you use to pre-shade and how much filler did you have to use in the wing roots and gull wing?
Cheers
Darren
Posted by Anonymous on Wednesday, August 25, 2004 7:02 PM
Well i final got the main rear wing on the serriaEvil [}:)]. Not easy to get it to sit in the right position. Well its on knowBig Smile [:D]. Just have to try and ellimente the joint Eight Ball [8].
Cheers Trev
Posted by Anonymous on Thursday, August 26, 2004 3:48 AM
QUOTE: Originally posted by darson
J.S
Cheers
Darren
Darren i used plain ol Tamiya flat black for the preshade and painted Testors polyscale acrylic Earth brown FS.....ummm whatever over the top,i tried to lighten the brown with about 10% Tamiya flat white but it would't mix,kinda just floated around in tiny little globulates......
As for the wing roots i had to use some filler on the trailing edge half of the wings but the leading edge half of the wing sat snug as.......
Incidentaly i am in the process of making the Tamiya Spit MK1 Battle of Britain Flown by Aussie ace Paterson Hughes of 257 SQD i think and i had to use filler on the wingroots of that one to....
I also have the ICM Spit MKV111 which has great detail including the wing cannons and Merlin and that sucker needed filling in the wingroots tooDisapprove [V]
BTW thats the only part of the Hasegawa model that i needed to use filler on.....
Cheers J.S.......
    August 2003
Posted by tweety1 on Thursday, August 26, 2004 5:58 AM
Hey all, just some pics of how the Sabre is going. Anyone with the resin kit will gain the most from this.
This was a week ago, been a little busy, but all seems to be on schedule.
Fingers crossed!
The grey areas are covered with Tamiya putty, which bonded well to the resin.
The black texta shows the areas I had to sand out ALOT to make the kit pieces fit properly.
After nose alteration.
I also added strip styrene and putty inside the intake to smooth it out and make it look like an intake!
This shows the section that has to be removed to allow the resin part to fit, and also makes the air intake larger so the resin nose cone can fit (sorta!!)
Hopefully this weekend, the 2 halves will be assembled, and the hellish fitting of the lower wing ass'y will beginDisapprove [V]
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by Anonymous on Thursday, August 26, 2004 10:08 AM
Tweety1 full steam ahead eh mate...
I've been tinkering with mine a bit lately,have you you had a hard time figuring out what's flash and what's panel......
BTW thanks for the pics,i was wondering what that bit was,now i know its for the intakeWhistling [:-^]sorry but the intstructions are a little vagueConfused [%-)]
Posted by Anonymous on Friday, August 27, 2004 3:37 AM
phroosh,
Cheers
Darren
Thanks Darren, that info on the changing of the serials is great, as my Dad was seriously wounded on the 3rd of March 1943, ending his service. I didn't know the timeframe of the serial change. It is quite possible that they were carrying the SF on the rear fuselage as the Ventura is in the second picture by then.
Every little bit of info helps, thanks a bunch
    August 2003
Posted by tweety1 on Friday, August 27, 2004 4:20 AM
Mate, the flash or panel question is still going on!!!Sad [:(]
Wait till you have the halves together, and try to figure out how much to remove for the wheel wellWink [;)]
And the word 'vague' doesn't even begin to explain the instructions. My personal favourite is the photo's.
So well defined aren't theyTongue [:P]
Someone should tell them how to turn the toner down on the photocopier.
    August 2003
Posted by tweety1 on Saturday, August 28, 2004 11:32 AM
Just a couple of progress pics, showing the cockpit so far.
There are a few tings I need to fix, like the bezels around the instruments, and a seat cushion and belts, but so far so good.
I have to admit the Academy instrument panel didn't impress me much, but after some work, it looks ok, not great, but ok will do for now.
That said, for the next Sabre I do, I will definately get the Aires and Eduard kits to suit, the factory stuff really isn't up to scratch.
Posted by Anonymous on Sunday, August 29, 2004 4:39 AM
Lookin good so far Tweets....Bow [bow]
Ok so those black and white smudge lookin things are photos eh.....
BTW I liked the c/pit detail so much i went and ordered a whole new one from TrueDetails..I see you went for the grey primer on the inside thats a another vague area the instructions said it could be grey but it might be black Confused [%-)]
Cheers J.S..................
    July 2003
Posted by madmike on Sunday, August 29, 2004 6:02 AM
Hi all
My first foray into the world of airliner modelling. I have chosen the 737-300 kit after winning the Virgin Blue "reverse livery" decals off ebay. Produced by Hawkeye, they look nice on the sheet. Let's hope they perform ok!
Virgin Blue 737's are generally all over red with a white and blue tail and logo. However, this ex ANSETT ship was never repainted and after a red nose was added to replace the original nose damaged by a bird strike looked even stranger! Livery was all over white with a red/blue tail and the Virgin logo. Pretty interesting scheme which I hope to compliment with a 1:144 Revell 737-800 done out in the all red VB livery.
Pic shows the fuselage and engine nacelles with the white on and the primer coat on the wings and horizontal stabs.
not much to see really at this stage but here it is anyway
more pics to come
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    August 2003
Posted by tweety1 on Sunday, August 29, 2004 6:05 AM
The TD item is pretty cool, but the Aires item I liked the look of a little more.
As for the c/pit colour, it's actually Gunze RLM 65 Light Blue!Wink [;)]
I tried the grey, and it didnt seem to look right with the research pics I have found.
Black didn't seem right to me, seeing as all the instruments and control knobs were black mostly, it would have been hell to see.
The blue actually looks close to spot on.
As for the wheel wells, a few people have said it is green, zinc chromate to be precise.
Posted by Anonymous on Sunday, August 29, 2004 9:57 AM
RLM 65 for the c/pit eh,cosidering the amount of research you've put in to this i'll trust in your judgement and paint the same colour,RLM 65 is a colour i have plenty of...
zinc chromate is that like the colour in A6M Zero wheel wells.....
hey i hope you don't mind me saving your pics for future reference....J.S
Hey Mike your 737 looks nice and clean,looking forward to seeing it finishedThumbs Up [tup]
Thumbs Up [tup]Thumbs Up [tup]
    August 2003
Posted by tweety1 on Monday, August 30, 2004 3:46 AM
The main reason I went for the RLM 65 was for scale effect.
I mixed 10% white white with the grey, and checked it against the RLM, and it was nearly spot on. Saves mixing. And I'm lazy at heart!!Tongue [:P]
As for the green, I intend to use Model Masters 1734, Green Zinc Chromate.
This is the enamel one, same as I used on an earlier P 38.
The inside of the wheel bay doors is the same as the outer skin, BMF.
Mike, I like the look of your project, can't wait to see more pics!
Posted by Anonymous on Wednesday, September 1, 2004 4:38 AM
I'll have to grab some of the MM Green Zinc Chromate next time i go to the LHS thats if they have it.....
After that all i'll be waiting on will be the new c/pitSmile,Wink, & Grin [swg]and then i have to put it all away till JanSigh [sigh]Sigh [sigh]
Havn't done much to the spitfire lately,only put a coat of gloss over the Brown so now i'm back to where i started from before the mask pulled all the paint off.....
this weekend i might cut some new masks and get a move on,hopefully it should be finished in a couple of weeks......Propeller [8-]Party [party]
Posted by darson on Wednesday, September 1, 2004 6:28 AM
Finally I have some progress to report on the Spitfire and a couple pictures to post. After a bit of mucking around it's sealed up, masked, seam filled, sanded and now pre-shaded.
I used MM RLM 66 as the pre-shade color as a bit of an experiment after I read an article on someone doing the same thing (can't hurt anyway).
J.S, if you are having trouble getting hold of MM Zinc Chromate, drop me a line and I'll pick some up and mail it up to you.
Also, if these pics are too big or take too long to load etc, etc, let me know and I'll make them smaller next time.
Cheers
Darren
Posted by harvs73 on Thursday, September 2, 2004 3:52 AM
Progress report on the Mosquito and A-20, pictures to follow as soon as I can show an improvement.
I have finished the decals on the Mosquito thanks to David Edwards and am about to give it another coat of clear varnish prior to weathering.
The A-20 is just waiting a coat of 'One Go' prior to putting on the decals.
I am very slowly assembling the 1/48 Liberator. And I mean VERY slowly.
Dave Harvey
Avon Sabres
Posted by Anonymous on Thursday, September 2, 2004 9:21 PM
Hi Folks,
I see a few Avon Sabres on the go, very nice.
I can recall black cockpits on the prototype A94-101 and also the early Mk30s. The primer grey for the rest is quite pale, well captured. The very front of the cockpit floor and side console walls is also black, tricky to paint. Can email pics if they're of interest.
All the Avon Sabres I've seen (6 or so) have silver lacquer wheel wells, same as the rest of the airframe. There are some good detail shots of the Classic Jets Fighter Museum Sword on their site and at ARC.
Cheers,
David
Posted by Anonymous on Thursday, September 2, 2004 9:44 PM
Darson your spit looks just like mine cept the colour of the preshade right down to the blue tac in the wheel wellsLaugh [(-D]LOL....
I went for the black preshade cause of the dark colour scheme on my model....
From memory( which is not that good ) your'e scheme is Green/Grey so RLM 66 is a good choice for it.....
I'd Better get a move along on mine,i want it finished in a couple of weeks before i start the British and Commonwealth Armoured GB....
David thanks for your input mate,seems to me that the Sabres in RAAF service were quite varied which can make it difficult to get an accurate picture of what to build and in what colour.....
BTW if you have pics by all means post em up,there's a couple of us here with Sabre feverSmile,Wink, & Grin [swg]
    August 2003
Posted by tweety1 on Saturday, September 4, 2004 12:53 AM
.........David thanks for your input mate,seems to me that the Sabres in RAAF service were quite varied which can make it difficult to get an accurate picture of what to build and in what colour.....
Sabre fever huh.......gee j.s., I have no idea what you meanTongue [:P]
Mind you, what you call fever, my wife calls addiction!!
She is just so understanding of my personal needs. (not!!)
Anyway, Im planning on going with Alclad II White Aluminium BMF (yeah, I ordered some...), and MM Chromate Green wells, this seems to have turned up alot more in my research than anything else.
Posted by pingtang on Monday, September 6, 2004 8:54 AM
G'day everyone,
Heres my entry for the Aussie Group build all finished. It is a Beaufighter Mk.XXI from 93 squradron. It is A8-116 'Babs'. It was built from the Tamiya kit with an Aires cockpit and Aussie decals.
I've gottas say thanks to Lobbie for all the info he sent my way as well as the resin exhaust pipes and pilots seat.
Thanks for having a look and I'll see you all for the Aussie GB round 2.
By the way... some of the other projects I've seen in here look great. I'm interested to see how they turn out. Just goes to show we Aussies can match it with the rest of the world (don't know about me though, but I'm still learning).
see you all later...
-Daniel
    August 2003
Posted by tweety1 on Monday, September 6, 2004 9:31 AM
Bow [bow]Bow [bow] Love your work ping, very impressive looking bird.
Keep it up!!Big Smile [:D]
Posted by Anonymous on Monday, September 6, 2004 9:53 PM
hey Tweets your missus sounds about as understanding as mine.......
i'm painting my sabre in the same colours mate, i picked up some MM Zinc Chromate from the LHS last week,could'nt beleive it my LHS actually had what i was looking for....
BTW isn't it an ugly lookin colour.......
Pingtang i like your work mate,very nice indeed for a blues supporterThumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup]
    August 2003
Posted by tweety1 on Tuesday, September 7, 2004 8:22 AM
Yeah, the Zinc is a little full on.Yuck [yuck]
Gonna have to lighten it a bit, otherwise it will draw your eye away from the a/c.
