'After The Battle' Group build progress photos.
Posted by Anonymous on Wednesday, April 27, 2005 10:42 AM
Hello fellow group builders. Here are some starting photos of the After the Battle group build that I’m working on. The subject is the Trumpeter 1/32 F-105D.
First photos are of the inside starboard rear fuselage and starboard wing areas that are marked with pencil to show where the panel lines are on the exterior. This will be the battle damaged areas.
http://i3.photobucket.com/albums/y78/Csaulet2001/enginebaymarking.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/InteriorRt.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/Verticlefinbeginning1.jpg
With those areas marked, I begin the application of the Bare Metal Foil on the exterior surface of the areas that will be battle damaged. This was also done with the starboard outer Pylon and the vertical stabilizer.
http://i3.photobucket.com/albums/y78/Csaulet2001/BMFapplicationexteriorfuselage.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/ApplyBMFtowingexterior.jpg
After the foil is applied, I began thinning the plastic of those areas using a Dremel with a round grinding bit. (If you use this technique, remember to grind down gradually and as evenly as you can.) The plastic is thinned down enough so that you can start to see the foil appearing translucent through the plastic. I stopped thinning it with the Dremel at that point and used 400 grit sandpaper to get an even thin skin. Next I applied foil over the thinned area. This was done on the upper and lower wing halves and to the right side of the right outboard pylon. Use a Q-tip to press the foil down so that you don’t puncture the thin skin.
http://i3.photobucket.com/albums/y78/Csaulet2001/Thinningupperinteriorwing.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/Thinnedinteriorwingbottom.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/upperwinginteriorBMFapplication.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/BMFappliedtopyloninterior.jpg
Next came the building the structure of the interior of the wing, fuselage and vertical stabilizer. I used a skeleton drawing of the F-105 as a reference of where bulkheads, spars and linkages were located. Since I planned for a large hole caused by AAA to be in the fuselage, I had to build the bulkheads and spars for the port side of the interior as well as the starboard.
http://i3.photobucket.com/albums/y78/Csaulet2001/interiorwingstructureapplied.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/1stbulkheadinplaceEng.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/EnginebayBulkheadsinstalled.jpg
That’s all for now. More to follow very soon.
Chris
    January 2003
Posted by yardbird78 on Wednesday, April 27, 2005 1:31 PM
Very nice start on your Thud. I will be anxiously awaiting further progress pictures.
Darwin, O.F. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
Posted by Anonymous on Friday, April 29, 2005 3:11 PM
Thanks yardbird. The cockpit shots will be coming soon.
Posted by Anonymous on Monday, May 9, 2005 3:36 AM
Here are some photos of the detail work on the landing gear & doors of my F-105. The Trumpeter kit is massive but the landing gear, gear doors and wheel wells lack detail. I used reference photos from the book ‘F-105 walk around’ to try and get the detail right or at least close to the real thing.
The interior of the kit doors are just plain smooth plastic with ejector pin marks in them. I used white putty to fill the pin marks. I also used my Dremel grinding bit to thin the edges of the gear doors.
http://i3.photobucket.com/albums/y78/Csaulet2001/Maingeardoor1.jpg
The main gear doors also have raised rivets along the door edges. I made a simple template from masking tape to mark where the rivets will be placed. I used a #11 blade to make the marks and then used a drill bit to make small holes. I used stretched sprue as the rivets and attached them with Pro-weld.
http://i3.photobucket.com/albums/y78/Csaulet2001/Maingeardoorrivettemplate.jpg
I added structural detail to the gear doors using sheet styrene and brass sheet cut and bent to shape.
http://i3.photobucket.com/albums/y78/Csaulet2001/Maindoorsmodified.jpg
There are a pair of small wheel doors that are just as plain as the large ones. These doors received the same treatment for detail.
http://i3.photobucket.com/albums/y78/Csaulet2001/Smallmaingeardoors.jpg
http://i3.photobucket.com/albums/y78/Csaulet2001/Smallgeardoorsmodified.jpg
I used the after market metal landing gear for this kit and added brake lines and electrical lines for the taxi light in each main gear.
http://i3.photobucket.com/albums/y78/Csaulet2001/CorrectedStbdgear.jpg
That’s all for now. More to follow soon.
Thanks for looking
