USAF 60th Anniversary Group Build--(non-aircraft subjects allowed)
    July 2006
Posted by Pruz on Wednesday, June 20, 2007 12:31 PM
Apart from a few small details I think we're about finished! I'll post the final pics at the end of the GB.
Here is my rendition of Revell AG's 1/48 B-1B dressed as 86-0125 "Swift Justice", 34th BS, Ellsworth AB, SD:
I still have to do the various aerials, pitot tubes, static wicks, and the crew ladder needs to be fitted, but I'm just relieved it still fitted together ok and seems to stand reasonably straight on its own legs. I made a small support to relieve the weight on the main gear as I am still not sure it will take the full weight of the plane for long.
I'll be following the progress of this GB, but for now thanks very much to cdclukey for modding it so far.
All the best,
Al
If it ain't Boeing, I ain't going! Finishing off: Revell 1/48 B-1B Lancer for USAF 60th Anniversary GB In production: Revell 1/32 F-16A - C conversion
    November 2004
Posted by cdclukey on Thursday, June 21, 2007 6:09 PM
Al, that bird is just AWESOME!! Great job and thanks for contributing.
    November 2004
Posted by cdclukey on Friday, June 22, 2007 11:18 AM
Here's an update on my F-106. I finished the wheel wells, have finished the filling and sanding on all the upper fuselage gaps and glued the aircraft bottom and wing top together. Looks like more gaps between those two, but that's the way it goes. Despite the good weather, I'm expecting to get a lot done on it Sunday afternoon (during the NASCAR race I watch the TV with one eye and model with the other) and next week. I expect to be laying down fuselage paint before the week is out. From here I think this one will be going much faster than the car I was working on.
BTW, if you're building one of these and you're cheap like me... Smile,Wink, & Grin [swg]...Rust-oleum sells a farm equipment paint that is a dead on match for the yellow on the 1962 bird in the Revell kit. Its formal title is "Yellow 7449" but the can label says it's a match for "Old Caterpillar Yellow." After this project's done I think I'll find another use for it...I can do a Cat model or find a car that would look good in a butterscothish yellow.
    January 2004
Posted by mph34 on Saturday, June 23, 2007 10:08 AM
GREAT JOB on the B-1B Pruz! Big Smile [:D]Thumbs Up [tup]Make a Toast [#toast]  Did a great job of detail, and you gave it just the right amount of "dirt & weathering".  Swift Justice looks ready to go hand out some serious justice to the bad guys.
Now, where is that bad boy going to live?  That is one big plane.
    January 2004
Posted by mph34 on Sunday, June 24, 2007 4:44 PM
Well, got started on the TF-15, Bicentennial scheme; Hasegawa 1/72 kit.  I decided to build the cockpit first, then paint.
I am considering applying a white primer now with the parts still on the tree.  Is this a good 'train of thought' for the overall Gloss White finish that is called for?
    February 2006
Posted by ruddratt on Wednesday, June 27, 2007 7:37 PM
Some great work on display here! Thumbs Up [tup]
Is it too late to join up?
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
Posted by Chrisr on Friday, June 29, 2007 10:00 AM
Hi All,
I have started an F15E Strike Eagle, 1/48 scale Revell kit. Kinda stumble upon the group build and would like to join in, if thats OK. Always wanted to join a GB and this one seems like a fun one with a fun bunch of fellow modelers. I'm a long time lurker, and this is my first aircraft kit in a lot of years.
Thanks,
 Chris
    November 2004
Posted by cdclukey on Monday, July 23, 2007 9:24 PM
No, not too late, feel free to jump in! What are you going to build?
    November 2004
Posted by cdclukey on Monday, July 23, 2007 9:27 PM
Welcome aboard, Chis. Looking forward to seeing that mud-moving Eagle!
    November 2004
Posted by cdclukey on Monday, July 23, 2007 10:05 PM
Update on my F-106:
I have finished the wings and aircraft bottome, and will be gluing the tailpipe and upper fuselage on soon--tomorrow night if I get enough work done tomorrow. Lots of putty...but again, I was warned. I've also painted a lot of the parts that will go on after the fuselage is put together.
I definitely want to get this thing moving faster though...I want to finish it by mid-August at the latest, including the display base.
    November 2004
Posted by cdclukey on Saturday, July 28, 2007 1:59 PM
A further update on my F-106. Most of this work was done last night.
1. Painted the burner can. I had already brush painted the interior with flat black and sprayed the turbine and flame ring; last night I put a black acrylic wash on them.
2. Sanded off the very, very inconveniently located ejection pin marks inside the intakes and brush painted the intake interior.
3. Painted and washed the ram air turbine. Painted the insides of the turbine door, main gear doors, nav door, torsion links, retraction struts and cylinders. Painted the red nav light that foes in the nav door and the clear ones (painted the back silver) that go in the outer main gear doors.
4. Painted the arrestor hook.
5. Painted and assembled all the gear wheels. Put a coat of white on appropriate portions of the gear struts, but it needs at least one more coat to cover.
6. Assembled drop tanks.
7. Painted speed brake actuator cylinder and the interior green portion of the speed brake.
If I can sneak away from the room renovation I'm doing the rest of this weekend, I'll spray the metal parts of the intakes and air ramp, but I definitely won't get anything else done until Tuesday or later. In fact, it will probably be next weekend because I need to get the text of my quarterly magazine over to the designer, and I'll probably need to put in an evening or two on that. The good news is that with the exception of the main aircraft gray paint job, I have almost every part in the kit painted, so once I actually get the fuselage together and spray it I'll probably be able to complete assembly in a single evening and complet the decals the next.
    June 2003
Posted by Avus on Tuesday, August 7, 2007 1:34 AM
Great work on your B-1 Pruz!
Your progress sounds interesting cdclukey ... any pics are there, perchance?
My progress went as far as getting Eduard's PE set for the pavehawk and Cobra's MH-60 update and UH-60 correction kits. I won't be using all the aftermarket I got since I have some scratch built part, but there are some tiny details I couldn't deal with.
Hope to get back to my helo late next week ... but since I'm moving it might not work out!
Klaus
Thanks to ImageShack for Free Image Hosting
    November 2004
Posted by cdclukey on Tuesday, September 18, 2007 5:05 PM
Hey guys! Sorry it's been awhile since I checked in, and more importantly...<P>
HAPPY BIRTHDAY USAF!!!
Avus asked about in progress pics. I took them, but the camera they were in was involved in a gravity-related incident and they were exposed. The good news is, I have completion pics. I hope you like them!
    June 2003
Posted by Avus on Wednesday, September 19, 2007 1:29 AM
Very nice looking aircraft you got there, cdclukey!
So yesterday was the deadline ... gess that makes me dead!
Sorry I didn't manage to work on my helo, guess I severely misjudged my time.
Thanks to all for sharing their progress and completed models.
Klaus
    January 2004
Posted by mph34 on Wednesday, September 19, 2007 9:38 AM
Nice looking F-106 there cdclukey Thumbs Up [tup]
Another Group Build that I miss the deadline! Thumbs Down [tdn]  My TF-15 is started, but not anywhere near completion.
Posted by Chrisr on Thursday, September 20, 2007 10:50 AM
 Sign - Ditto [#ditto]......I too am sorry I couldn't get more done on my F15. But some family health problems had priority.
One of these days I'll get something into a GB!!! Smile [:)]
Posted by espins1 on Thursday, September 20, 2007 11:49 AM
Hey guys, very sorry I wasn't able to work on my project for this GB.  It's been a tough year for the family health wise so my modeling time has been very sporadic and will continue to be so for at least the forseeable future.
Thanks for hosting this GB, there was some great work done here!
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    February 2006
Posted by DantheMan85 on Monday, November 19, 2007 9:16 PM
Heres an update on my BlackBird,  I know I've not posted here in a while.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    November 2004
Posted by cdclukey on Monday, November 19, 2007 11:37 PM
Thanks for the update...looks like it's going to be a real beaut!
    February 2006
Posted by DantheMan85 on Tuesday, November 20, 2007 1:06 PM
She really is, she's 26 inch long.  And alot of filler!
Up Coming: ?
    February 2006
Posted by DantheMan85 on Thursday, December 13, 2007 9:35 PM
This is my finished project, took a while to put her together but her she is.  Canopy, camra window, were dipped in future so they have a nice shine.  I'm happy with the way it turned out.
Up Coming: ?
    November 2004
Posted by cdclukey on Friday, December 14, 2007 2:19 PM
AWESOME BUILD!
    February 2006
Posted by DantheMan85 on Tuesday, December 18, 2007 11:34 AM
Thanks cdclukey, I'm really happy with the way she turned out.
Up Coming: ?
