Leopard camo progress pics..
    July 2003
Posted by lizardqing on Tuesday, November 11, 2003 7:08 PM
Ok I finally got up the courage to try out my first camo scheme Shock [:O]. I thought I would get some opinions before I went on with the next color. I probally went backwards with the black and brown, but I have never been one to do things the right way. I used silly putty to mark out the patterns and masked with tape then went to spraying.Thanks for all the tips on doing camo by the way. Let me know what you think. Looking to haveing this one done within the next couple of weeks.Thanks.
    July 2003
Posted by Dwight Ta-ala on Tuesday, November 11, 2003 7:13 PM
Looking good so far, Chris. Should come out great with the addition of the black patterns and the weathering. Looks like the Tamiya kit is better that the Italeri, IMHO. Silly putty really works great. How I wish I could find that material here.
Keep us posted.
Posted by Anonymous on Tuesday, November 11, 2003 7:25 PM
Not too bad at all Chris, much better than my first attempt at camo anywayTongue [:P].
Glad to see the Blu-tack / Silly putty idea worked out for you too.
Is it the photos, or is the base green showing through the Brown in a few places? The brown is a strong colour and is painted solid on the real thing; Therefore the lighter base coat shouldn't show through on the model.
Did you use Tamiya acryllic 'Nato Brown?' I have used that colour twice, and both times ended up with a patchy finish where I filled in between the demarcation lines..... no matter how much I stirred the paint before and during spraying. I bought both lots of paint from the same store and thought that it might have been a bad batch. Did you have this problem too?
Looks pretty darn good so far.
I have yet to try the Silly Putty method but may have to try it out after seeing your results.
    July 2003
Posted by lizardqing on Tuesday, November 11, 2003 7:58 PM
Peter- Actually thats the black coloring, brown has'nt made it on it yet. Like I said I thought I may have gotten backwards with the color order. I used Model Master enamels and so far it is just flat black and medium green. Don't really have access to any specific colors like the nato ones. The base could be showing through here and there. There is some touching up I need to do like the underside of the turret next to the barrel where I forgot to continue it under it.
Dwight- It is a great kit. I have had no fit problems what so ever and the detail is amazing. This is the best kit I have done especially for the money, only spent $8 for it and have seen it for $55 since then.
Posted by Spamicus on Tuesday, November 11, 2003 8:03 PM
It's coming along really well Chris. I must confess, your color sure looks brown on my monitor, but it's looking okay so far. Keep after it.
Steve
    May 2003
Posted by Build22 on Tuesday, November 11, 2003 10:29 PM
Looking good, Lizard
Jim [IMG]
    July 2003
Posted by lizardqing on Tuesday, November 11, 2003 11:03 PM
Ok I went ahead and threw the brown on it and I must say that I am proud of the resultsBig Smile [:D] ! For my first camo I think I did pretty well. Thanks for all the suggestions from y'all, if it had not been for the group here I would have probally skipped the camo so I would'nt mess the kit up.
