Hi guys it's me again with another quick build to waste time. Actually this is a practice model to try out some mig pigments before committing to the JT. I normally would just go for it but I don't want to screw up the KT.
The model is the Dragon Pz III Ausf J built OOTB. Here is the result of two days work.
I started the turret today and just got done with the painting a short time ago. Only took about an hour to paint the turret.
Primered and ready for painting.
My usual dark brown base coat.
A thick dark brown wash using 502 Abteilung from MIG
Before the wash dryed I applied a dark rust pigment,again MIG products, with some light rust added in areas.
A heavy coat of Hairspray and salt added while the HS was still wet.
Now the actual paint color is applied using Tamiya Acrylics, I used white with a drop of Buff.
Here are tools of the trade, stiff bristle brushes and a pin used to remove the paint and salt.
Some more weathering using a light rust pigment and a light wash using the 502 Abteilung oil thinned some more.
And here is the end result. I won't add anything else since most of it will not be seen anyways. Hope you guys like this guy too.
Rob
