Now, you can ignore this if you like, but these are the differences between Dragon's kit and "823" :
A full set of S-mine launchers. Have Coming
The 12 welded cubes where the exhaust shields would be screwed in. Noted, and checked, thanks
Side fenders (in a straight line, not the original layout). Not sure of differences will check and modify at that stage, thanks
Rectangular plate stored behind the driver's hatch. Seen pics of other tigers with this, what for?
Adapter plate (between the exhaust) is aligned vertically. Noted will change, thanks
The hull front edges protrude further and the shackle holes are lower. Noted, thanks
The turret has the escape hatch in the side. Known, thanks
There are reinforcing rings on the holes in the glacis plate. ???
The folding mudguards at front and rear. Known, thanks
The Feifel air cleaners, pipes and duct. Known, thanks, coming
A spade is stored on the glacis plate. known, supplied in dragon kit as unused item
The left and right tracks are identical (Early style). I Assumed the AM tracks should be right, will double check thanks
The rear reflector is the cylinder type. ???
The antenna lug is not present on the right rear plate. Noted, thanks
A thin cable is stored on the left side. Known, thanks
The turret bin is the large wide style, NOT what you'll find in the Academy kit. It's included in Tamiya's Afrika kit. But due to the turret escape hatch, both ends of it have 'bites' taken out. This is contrary to my photo evidence (though I admit I may be wrong in interpretation I'm no expert)
David
