DML #6540 Flakpanzer IV Wirbelwind COMPLETE Pics p.17
    July 2004
Posted by wbill76 on Monday, August 15, 2011 12:50 PM
Thanks Eric, Nate, and Rob, appreciate the comments!
Mike, this one's setting a new world record for time to completion but it's the end result that matters most! Wink Am looking forward to the MBA program, best of luck with your daughter's departure from the nest!
Andy, thanks as well. The BITW GB is going to present an interesting challenge for me...I took a survey of my stash and have quite a few eligible kits to choose from, more than I had first thought! Going to have to weigh the decision carefully before making the final choice for sure.
    April 2009
Posted by deafpanzer on Monday, August 15, 2011 4:09 PM
wbill76
I figured BITW GB is a perfect opportunity for you to do one of your favorite camo schemes... grey & dark brown if I am correct.   Looking forward to see your WIPs as usual... Beer
Andy
    August 2006
Posted by ogrejohn on Monday, August 15, 2011 4:26 PM
That sure is looking sweet Bill! Do you mostly use the Model Kasten tracks? I haven't tried them yet and am getting ready to do my first set of Friuls.
    July 2004
Posted by wbill76 on Monday, August 15, 2011 5:14 PM
Andy, yep the two-tone 2/3 Panzer Gray 1/3 Dark Brown schemes are always fun!
John, thanks for the comments. Yes, I normally go for MK tracks when I decide to replace kit tracks. They are cheaper than Fruils and paint up just like static indy links but with the flexibility of being workable and have become my track of choice as a result. They do take time to assemble depending on the set in question but are worth it in the end IMHO.
    August 2006
Posted by ogrejohn on Monday, August 15, 2011 6:14 PM
Thanks Bill. I might have to give them a try if they are cheaper. My first set of Friuls are a winterketten set and they ran 30 bucks plus shipping of about 5 bucks.
Posted by jimz66 on Tuesday, August 16, 2011 10:42 AM
As always Bill your knocking this one dead. Its looking very good. Have you ever "timed" how much time you swallow up with the MK tracks?
Hope all is well...
Phantoms rule the skies!!!
    July 2004
Posted by wbill76 on Tuesday, August 16, 2011 1:44 PM
Thanks Jim! I've never clocked the time to assemble an MK set with precision but would estimate 4 hours or so depending on the set. I usually break up the assembly into small sessions here and there as it is a repetitive/tedious task to do in one shot as I'm sure you can imagine! Wink
Posted by jimz66 on Wednesday, August 17, 2011 8:55 PM
Thanks Bill thats what I figured....
    January 2007
Posted by the doog on Thursday, August 18, 2011 8:17 AM
tigerman
I just love that camo job Bill. Superb.
Good t see you back on the horse. Yes
DittoAgreed; the forum feels "normal" now that you're posting again, Bill. Big Smile
    July 2004
Posted by wbill76 on Thursday, August 18, 2011 9:25 AM
Thanks Karl, nice to hear from you as always! "Normal" is an interesting concept but have to agree, it does feel good to be back posting on a more regular basis again. Beer
    September 2006
Posted by NucMedTech on Thursday, August 18, 2011 7:44 PM
Lost track of this one Bill. It's coming along great though just as we've come to expect!
-StephenCowboy
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
    July 2004
Posted by wbill76 on Thursday, August 18, 2011 7:52 PM
Thanks Stephen! It's pretty close to the finish line, I hope to get a good solid push in this weekend that may just get it across and onto the shelf...we shall see! Wink
    July 2004
Posted by wbill76 on Sunday, August 21, 2011 3:47 PM
More progress to report this weekend. First up I applied an overall coat of Future acrylic floor polish by airbrush to seal in the paint work and serve as a protective barrier for the later weathering stages. I let this dry for an hour and the applied the decals. Markings for Wirbelwinds were generally minimal and mine is no exception. I chose to mark it as a vehicle with the LAH and applied the crosses to the hull sides and rear, using Walther's Solvaset and some gentle prodding with a toothpick to get them to conform to the irregular zim surfaces. Once the decals had set, a 2nd coat of Future was applied over them to protect and seal them in as well.
I let the Future cure for a full 24 hours before moving on to the weathering stages. First step was an overall application of MM enamel Raw Umber as a 90% thinner wash to the entire vehicle. After that air dried, I added dot filters using MM enamel Flat White, Raw Sienna, and Panzer Dunkelgelb. I worked in small sections at a time so that the paint dots wouldn't start to set and wore a paint breather mask throughout to avoid heavy exposure to the thinner fumes. The small dots were blended together using repeated strokes with a square tipped blender brush lightly dampened with thinner. After about 2 hours of work, the filters were done. As you might expect, the increased surface area of the zim portions made this a somewhat complicated task. I had to work those areas in smaller sections and apply the blending strokes in the direction of the zim "grain" in order to get the desired result.
This one is pretty close to the finish line...just need to apply a pin wash and give the suspension/tracks a dose of pigments and this one will be complete.
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Sunday, August 21, 2011 4:06 PM
                http://th693.photobucket.com/albums/vv300/rangerwife/th_lovely.gif
  "THAT"
        is just beautiful.
      http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
Sherman-Jumbo-1945
"I was so much older then, I'm younger than that now"
    July 2006
Posted by redleg12 on Sunday, August 21, 2011 5:48 PM
Professor.....a textbook weathering.....perfect
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    April 2009
Posted by deafpanzer on Sunday, August 21, 2011 6:28 PM
Always looking good! Yes  I dig the zimm... dark washes made them come out this time.  Now I am looking forward to do the same on my Pz IV soon...
Andy
    December 2008
Posted by psstoff995's lbro on Sunday, August 21, 2011 6:53 PM
Looks good as always, Bill! Can't wait to see her 100%
-Will young modeler Test fit master
Posted by jimz66 on Sunday, August 21, 2011 8:49 PM
Looks great as always Bill. Another masterpiece.....
Posted by tigerman on Sunday, August 21, 2011 10:18 PM
Right on Q.
 Eric
    August 2006
Posted by ogrejohn on Monday, August 22, 2011 3:41 AM
Those filters sure change the look of it. It looks great!
    July 2004
Posted by wbill76 on Monday, August 22, 2011 2:30 PM
DM, thanks for the smiley vote of approval as always!
BeerMike, Will, Jim, and Eric, thanks for the comments as well!
Andy, the zimmed surfaces always behave differently when it comes to washes and weathering. Glad you like it and look forward to seeing the results on your IV as well.
John, the filter/weathering process is always one where the greatest transformations occur IMHO. Glad you like the result. Beer
    August 2008
Posted by Pvt Mutt on Monday, August 22, 2011 3:58 PM
Shapein up now I would sayYes
Nice William
Tony lee
Shoot Low Boys They're Ridin Ponys
    July 2004
Posted by wbill76 on Tuesday, August 23, 2011 2:00 PM
Thanks Sir Tony! Beer
    January 2007
Posted by the doog on Tuesday, August 23, 2011 2:38 PM
Nice looking vehicle, Bill! A good finish all around so far. I imagine you're about ready to put this on the shelf by now? Big Smile!
What's next? Stick out tongue
    July 2004
Posted by wbill76 on Wednesday, August 24, 2011 11:57 AM
Karl,
Almost ready for the shelf, should get there this weekend if everything goes according to plan. Wink As for what's next, I've signed up for a GB (yes, no lie!) that Eric (tigerman) is running, Blitz In the West, and will be building a DML Pz IV-C "Super Kit" for that one as my next effort.
Posted by Bish on Wednesday, August 24, 2011 12:00 PM
That looks an awsome build, and love the paint scheme.
bill, didn't you take part in the 251 GB a couple of years ago.
    July 2004
Posted by wbill76 on Wednesday, August 24, 2011 5:47 PM
Bish,
Thanks for the comments as always! Wasn't me in the 251 GB...last GB I participated in was back in 2005 or so. A loooooong time back. Big Smile
Posted by Bish on Thursday, August 25, 2011 3:11 PM
Must be so used to seeing so many of your WiP's that i was sure some had been in GB's. Not sure why i thought you were in the 251 one.
    January 2007
Posted by the doog on Thursday, August 25, 2011 6:28 PM
Holy crap, Bill--you in a GB? Wow!
You better get yourself a carpal tunnel brace BEFORE you even start, lol.
    July 2004
Posted by wbill76 on Friday, August 26, 2011 1:33 PM
Karl,
Might not be a bad idea! Big Smile Timing is good for me to work on a GB and have a change of pace as a result but isn't something I expect will become a habit. Wink
