t-34/76 tamiya 35059 help
    January 2010
Posted by MikeDordan on Sunday, April 3, 2011 2:33 PM
I am wondering where I can find a pe set for this model.  I found them for every other Tamiya kit but am not sure if I can use these on this spicific kit.  I am mostly looking for the grills and basic detail but any help would be appreaciated.
    May 2009
Posted by F Matthews on Sunday, April 3, 2011 3:36 PM
There's an On The Mark set that is pretty good for the Tamiya kit.  I used that several times with old Tamiya T-34s with great results.  I probably have bits of those PE sets around somewhere.  The OTM sets are out of production, but you can often find them on eBay.
    July 2006
Posted by constructor on Sunday, April 3, 2011 4:27 PM
I have tried using Eduard PEs for models of other brands like a Tiger PE for a Dragon and used it on a Tamiya. Since technically they should have the same dimension. A few minor adjustments and I am able to get them to fit. Im sure you will be able to use an Eduard PE for a Dragon on a Tamiya.
Posted by tigerman on Sunday, April 3, 2011 7:11 PM
I'd go to Greatmodels or whomever is your favorite online site and do a search. You're bound to come up with something. I'd also stick to to a set that is recommended for your project, i.e. Tamiya.
 Eric
