Trumpeter abrams
    December 2010
Trumpeter abrams
Posted by TheWildChild on Sunday, November 13, 2011 9:49 PM
has anybody built the trumpeter M1A1/A2 Abrams Tank 5'n 1 kit? i am going to build a "Super Abrams" widened and stretched, with a 195mm main gun. i need to know a few things from those that have either built this kit or similar trumpeter kits:
1: how good is the general parts quality? (i dont need an amazingly detailedkit as most details will have to be scratchbuilt to fit anyway)
2: are the rubber pad on the tracks the plain pads or the ones with the pattern on them?
i found this kit for pretty cheap online and seeing as i will need two to complete this build that was a big plus.
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
Posted by Rob Gronovius on Sunday, November 13, 2011 10:29 PM
Trumpeter's Abrams were pretty good at the time. It looked like they copied the better parts of the Tamiya and Dragon kits. Fit was OK, definitely not as good as Tamiya though. The forward face of one side of the turret was misshapen.
The kit comes with the newer style track w/out chevron detail. The kit included both vinyl and link & length tracks, but the tracks include a bump in the center of each track pad. Lots of removing from the inner surface.
    December 2010
Posted by TheWildChild on Sunday, November 13, 2011 10:39 PM
thanks rob. i plan on posting pics once i finally start on this project. i plan on adding two road wheels to the hull length, making it about 4 and 1/2 scale feet wider, making the turret wider and longer, and adding a 195mm main gun with a muzzle brake and two TUSK style .50 cal turrets over each hatch. the tracks on a normal Abrams have two pads side by side, mine will heed to have three, thats why i needed to make sure the tracks didnt have the chevrons. i actually drew up the plans for it for a CAD class for school. this will be my first project with a ton of scratchbuilding as well as a first kitbashing project. thanks for the info!
    July 2003
Posted by zokissima on Monday, November 14, 2011 11:42 AM
I built that kit years ago, and seem to recall that the tracks had the later pattern.
Also, fit and finish were ok; nothing to write home about, but definitely nothing to make you tear your hair out either.
