Vietnam dirt color question that needs to be asked...
    October 2008
Posted by oddmanrush on Monday, November 21, 2011 2:37 PM
Hi guys,
I'm trying to finish up an Australian Centurion that would have fought in Vietnam. On most armor models we see, the color palette of dirt and mud is hardly given a second thought - shades of brown mostly - and no one seems to question it.
Vietnam, at least it seems to me, is a slightly different story. Whenever I see Vietnam armor, they are always given a generous coat of that orange-ish dusty mud. To me, its a bit as cliche as gun barrel blackening...but that may just be me.
So, is that really the only accepted color to use for ground color on a tank that was based in Vietnam? Is it something we "expect" to see and therefore any other option is, well, not an option? Or do you guys think a standard brown or tan or something is also acceptable? Just curious on you guys' opinions...
Jon
My Blog: The Combat Workshop
Posted by T26E4 on Monday, November 21, 2011 3:25 PM
It depends on where the vehicle saw action.  Indeed, the red colored dust was prevalent in the Mekong delta areas.  But the military was engaged on many fronts.  Find a picture -- and mimic.
As for cliched like muzzle tube blackening, at least red dust on Vietnam vehicles has basis in reality.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    October 2008
Posted by oddmanrush on Monday, November 21, 2011 3:33 PM
T26E4
Touche, haha!
Any how, thanks for the response. I guess part of what I'm asking is if you see a model from the Vietnam era that does not sport a weathered scheme of orange dust...does it seem less "Vietnamish" to you? I think there are a lot of things in modeling (blackening of the barrel for instance Sad) that people expect to see and the model may be detracted from should that detail be missing. Do you all think this is true of Vietnam War vehicles?
Jon
Posted by T26E4 on Monday, November 21, 2011 3:37 PM
I think that myth persists because of laziness.  I love looking at period photos.  I certainly have seen many many simple earth tones -- w/o the red earth -- on Vietnam war vehicles/soldiers.  Just print out a photo and place it next to your M41 or M113 at your next contest and declare "No red dust!!"
Roy Chow
Join AMPS!
    July 2004
Posted by stikpusher on Monday, November 21, 2011 3:52 PM
And perhaps because not all items are Vietnam specific if one does not see or can not read the bumper codes. A basic M113 or M151 could be mistake for being in Germany, Korea, or Dominican Republic in basic Dark OD and browner tone dust/mud. But the reddish stuff has come to be identified with Vietnam.  It adds context due to the popular perception. Yes other tone muds exist in Vietnam just like everywhere else (at Ft Polk we had various mud tones in different areas including that red stuff), but it is the reddish tones that burned into the popular conscience.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2006
Posted by telsono on Monday, November 21, 2011 4:15 PM
I know this may be a bit over the edge and technical, but in my geology and soils classes in college they did talk about the red laterite soils which are the common soil type for tropical areas. So you can find these soils in tropical areas like Africa, India, South East Asia, the Malay Archipeligo and even the Caribbean. Laterite soils can be very deep, which helped the VC with their tunneling. If the VC had to tunnel through rock, they wouldn't have been able to create those tunnels that they made. These soils are commonly 15 to 25 feet deep, in some areas they reach even greater depths. Our temperate soils may only be 2 to 3 feet in depth before hitting bedrock, usually not past 6 feet. the red color comes from the iron oxides commonly found in them. The article below may be a bit technical for some.
laterite,  soil layer that is rich in iron oxide and derived from a wide variety of rocks weathering under strongly oxidizing and leaching conditions. It forms in tropical and subtropical regions where the climate is humid. Lateritic soils may contain clay minerals; but they tend to be silica-poor, for silica is leached out by waters passing through the soil. Typical laterite is porous and claylike. It contains the iron oxide minerals goethite, HFeO2; lepidocrocite, FeO(OH); and hematite, Fe2O3. It also contains titanium oxides and hydrated oxides of aluminum, the most common and abundant of which is gibbsite, Al2O3·3H2O. The aluminum-rich representative of laterite is bauxite.
Laterite is frequently pisolitic (pealike). Exposed surfaces are blackish-brown to reddish and commonly have a slaggy, or scoriaceous, lavalike appearance. Commonly lighter in colour (red, yellow, and brown) where freshly broken, it is generally soft when freshly quarried but hardens on exposure.
Laterite is not uniquely identified with any particular parent rock, geologic age, single method of formation, climate per se, or geographic location. It is a rock product that is a response to a set of physiochemical conditions, which include an iron-containing parent rock, a well-drained terrain, abundant moisture for hydrolysis during weathering, relatively high oxidation potential, and persistence of these conditions over thousands of years.
Laterite has been used as an iron ore and, in Cuba, as a source of nickel.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    July 2006
Posted by redleg12 on Tuesday, November 22, 2011 4:55 AM
Yes the reddish clay color is the "standard". There is always variation and as Roy stated look at some pictures. To the north in the mountians it was still red but more greyish red. Having a good reddish base pigment like MIG Vietnam Earth is a great place to start. Then mix in some tones
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    October 2007
Posted by Milairjunkie on Tuesday, November 22, 2011 5:15 AM
There was quite a heated & running debate about this exact subject a while back (within the last 2 years or so) that was quite interesting & informative - it got me reading & I'm an aircraft guy!
I think it started with a dio which possibly included some huts & such like, it may have been connected to our friend Model Maniac, but I'm not entirely certain. I would use the search function to find it, but haven't really found the patience for it since the last forum overhaul........
    June 2008
Posted by Hans von Hammer on Tuesday, November 22, 2011 5:51 AM
I had a Vietnam Vet Section Chief back in 78/79 that was a young Marine gunbunny in Vietnam, 68-69, and he remarked on several occasions that the red clay at Ft. Benning reminded him of the Central Highlands in 'Nam, specifically Khe Sanh...  There's also a fair amount of red clay in the Mekong Delta, acording a 9th ID friend of mine... I don't know where the Aussie units operated though.
This and the following photo were taken near Pleiku, South Vietnam, Republic of...
Road leading from Ops to the perimeter gate and "Indian Country":
 There's also The Red Clay Newsletter that's published by the KheSanh Veterans Association.
    September 2007
Red mud n' dust...
Posted by SuppressionFire on Tuesday, November 22, 2011 6:25 AM
Where I live this type of soil is common. Much like Vietnam, Nova Scotia is a ancient 'mud' delta of sorts.
Can mail you a sample yet a picture says a thousand words.
My picture is a construction site after a rain, obviously Han's pictures are during dry season. The soil when dry gets really dusty and clings to everything. This leaves a lot of options for weathering either dry red earth or dusty red soil.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    July 2004
Posted by stikpusher on Tuesday, November 22, 2011 3:05 PM
redleg12
Rounds Complete!!
this famous photo taken in the inland I Corps area is a great example of the other earth tones
       - Plankton
LSM
    October 2008
Posted by oddmanrush on Tuesday, November 22, 2011 3:33 PM
Thanks for the input and great references...and even the geology lesson! It took me a while to find a decent picture of an Australian Centurion in action in Vietnam....
That thing is dirty! Definitely isn't that red clay either. This may be the ticket I'm looking for. But at this point, I need to hijack my own thread and change the subject.....
What color is the base coat on that tank, under all the grime? Would you say that its close to OD? Definitely looks scuffed and faded on the upper surfaces....any insight?
Jon
    July 2004
Posted by stikpusher on Tuesday, November 22, 2011 4:19 PM
Yes it's supposed to be OD. When I started my M113FSV a couple years back I asked what color were Aussie AFVs in Vietnam. I was told by an Aussie member here (cant recall who at this point) that they started out in OD 34087 and later were switched to Medium Green 34102. Of course the tropical environment will give that sun/rain fade over the years.
       - Plankton
LSM
    October 2008
Posted by oddmanrush on Tuesday, November 22, 2011 4:24 PM
Thanks Stik, a big help.
Was there a difference in tactics between Aussie armor and American during the war? It seems most of the pics I see of US tanks are in support of fire bases on hilltops, not deep within the jungle as are most of the photos I see of Australian Centurions. The thick jungle doesn't seem a suitable fighting environment for a tank as large as that...
Jon
    July 2004
Posted by stikpusher on Tuesday, November 22, 2011 4:28 PM
I do recall reading of sigificant differences in all US and Aussie tactics in Vietnam. I would have to pull out my reading materials on the subject to be more specific though. I suppose that Aussie tactics would have a basis on their employment of armor in the SW Pacific in WWII in heavy jungle terrain such as New Guinea and Borneo.
       - Plankton
LSM
    November 2011
Posted by GeneK on Thursday, November 24, 2011 3:16 PM
Interesting questions. I am a Viet Nam vet, and yes the red dirt is common, but you also see a lot of variety in colors in different  areas.  As for tactics, there really weren’t many choices for armor. Support of fire bases was common, but so was the so called “search and destroy” mission. But then I was always looking down on it from a helicopter gunship J
Gene
