First model, a few questions
    October 2011
Posted by brood31877 on Saturday, December 17, 2011 12:35 PM
Starting this great hobby from scratch. Looking at my first model kit (did some models along time ago but nothing impressive) I was looking at this http://shop.hobbylobby.com/store/item.aspx?ItemId=187311 for just basic building out of the box, and to learn/practice weathering techniques. I figure for the price ($8.10 after 40% coupon)  that it would be a good starting point to learn from. Is this a good kit to start with? (I understand from seeing some reviews that the kit is old and not super accurate) Im also wondering about the following airbrush and compressor.
http://www.amazon.com/Badger-Air-Brush-Patriot-Gravity-Airbrush/dp/B002W84GTO
http://www.harborfreight.com/1-8-eighth-hp-40-psi-oilless-airbrush-compressor-93657.html
Any and all feedback is greatly appreciated.
Posted by ajlafleche on Saturday, December 17, 2011 2:33 PM
That kit is ancient, eldritch, antique vintage Tamiya, but it's a simple build. I did one in an afternoon without an instruction sheet. I'd say it's a good start.
Now as to weathering and other advanced skills, get the basics down first: level and good asembly, clean mold lines and seams, well applied simple paint scheme (that one will allow all desert yelllow or all gray) well applied decals without silvering. Button it up so you don't have to wory about an interior. In case I wasn't being clear, don't frustrate yourself with weathering on your first build. Just work on a good, clean build. Everything was clean for a few minutes in its lifetime.
I have one a level below that airbrush and I'm quite happy with it.
Can't comment on the complressor, however.
    July 2004
Posted by stikpusher on Saturday, December 17, 2011 2:35 PM
That is a perfict kit for a beginner.Low parts count, simple assembly, no pitfalls in construction. Many of the older AFV builders here started on kits like that. Dont worry about the kits accuracy and finesse, get the basics down on kits like this, then move up to the more involved accurate kits when you feel ready.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2005
Posted by JohanT on Sunday, December 18, 2011 5:22 AM
Wellcometo this forum brood31877.
The kit you are considering is a classic, this is actuallyTamiya's #9.
First time I built it must have been in 1976.
Last time was 3 years ago, unfortunately it got Stuck in Jebel Ali Free Zone when I left Dubai.
Here is a link if you want a smile: /forums/t/106628.aspx?PageIndex=1
Tamiya's #285 38(t) Hetzer is a highly recommended kit http://www.perthmilitarymodelling.com/reviews/vehicles/tamiya/tam35285.html
The  Badger looks like an excellent deal and will last you a lifetime, otherwise I just had an Iwata Neo sent from the states which I am happy to recommend to anyone as a starter Air Brush.
Can't comment on the Compressor since you guys are using a different frequency then we do, if anything I would probably suggest that a compressor with a tank gives you a steady airflow.
Again, wellcome to this forum - enjoy your stay :)
Very Best Regards
Johan
    December 2010
Posted by TheWildChild on Sunday, December 18, 2011 5:25 AM
generally speaking, you cant go wrong with tamiya. their kits are relly well engineered (at least their armor and aircraft are, havent built the tamiya toyota supra i have yet)  and go together smoothly.
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
    July 2006
Posted by redleg12 on Sunday, December 18, 2011 7:47 AM
I think the others have given you the advice need on the model. Tamiya is always a good place to start. As for the air brush, badger is a good place to start. It will give you the hang of an air brush, a good finish and without spending big $$$. Lastly as far as the compressor, I would look at Home Depot Or Lowes. A small "pancake" compressor is fine. You will need a few fittings which should also be available at the same place.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    November 2008
Posted by iraqiwildman on Sunday, December 18, 2011 8:06 AM
I have been using this compressor for almost 2 years without any problems for issues. I recommend it.
Tim Wilding
    January 2007
Posted by the doog on Monday, December 19, 2011 12:51 PM
I've been using Badger airbrushes for over 25 years of modeling, and haven't found anything that does more of what I want it to do for all my model airbrushing needs.
I've also used Badger compressors and find them to be great quality. That one you have bookmarked there looks just fine though.
Posted by tigerman on Monday, December 19, 2011 1:02 PM
redleg12
Rounds Complete!!
I was just at both stores and can't recall which one had a compressor for only $49. It wasn't the pancake kind, but like a gallon, maybe two-gallon with a regulator I believe.
 Eric
    October 2011
Posted by brood31877 on Monday, December 19, 2011 6:02 PM
My main concern is noise. if lowes or dpot has a quiet one that that will work. I ordered the model today and looking to get a start after the holidays, too crazy (I have a 2 yr old) to start now. I appreciate the responses, and I will post a WIP thread once i get going. Thank you for answering my questions.
    November 2011
Posted by 70gtvert on Tuesday, December 20, 2011 2:04 PM
If your going to harbor freight, go with one of their larger compressors that are still hand portable. I bought the one with what looks like a large tank but is only about a foot long. These things will pump up to 125 lbs and can also be throttled back to almost nothing. What is nice is I can use it to inflate car tires too, try that with that little guy you linked to. Good news is that these larger ones go on sale periodically for $39.99, which is what I paid for mine. You'll like it. It isn't that loud either.
Here is a link to it, they do drop the price from time to time. Now at $59.
http://www.harborfreight.com/1-3-hp-3-gallon-100-psi-oilless-air-compressor-97080.html
