Latex Paint?
Latex Paint?
Posted by stevedb227 on Friday, December 30, 2011 7:44 PM
Just curious is it possible to use commercial paint mixed say at Home Depot for Spraying on armor?   I was looking at paint swatches the other day and thought of the always controversial mixing of Dunkelgelb for German Armor.   I wondered for economy and ease of mixing if I had them create the color I want for Dunkelgelb in flat finish would the latex spray and stay on armor kits.   If anyone has experimented please let me know.
When you are up to your neck in alligators it is difficult to remember the original objective was to drain the swamp!
Posted by tigerman on Friday, December 30, 2011 8:10 PM
I asked a question about latex in another forum and never got a response. My feeling is it would need to be too diluted to spray and thus wouldn't adhere well.
 Eric
    January 2007
Posted by the doog on Friday, December 30, 2011 8:49 PM
I wouldn't try that. Latex paint is for walls, modeling paint is for models. I'd be concerned about its durability and resistance to weathering techniques.
    May 2008
Posted by Boba Fett on Friday, December 30, 2011 9:07 PM
I've tested latex. It's actually not bad stuff. It adhered very well for me. (In fact, they use Behr latex for painting replica WWI airplanes.) Remember, it's designed to go on walls which are used and abused daily. Models are pampered and protected. However, I'd be wary. If your application isn't perfect, it won't level well. I haven't tried spraying it, but I guess it would apply fairly well. If anything, you can flat-coat it to make sure future thinners and such don't destroy your finish.
    July 2004
Posted by wbill76 on Saturday, December 31, 2011 3:30 PM
I'd be very hesitant to spray it through my airbrush personally. The pigment particle size is larger in commercial paints versus model specific paints and that could cause an issue in terms of thinning and application. As Boba Fett mentions, all the variables have to be just so for it to work and tolerance levels are tight. If you give it a try, be sure to post up your results! Beer
Posted by stevedb227 on Sunday, January 1, 2012 12:50 AM
Many thanks for your comments.   I have an old Badger 150 doing nothing at the moment so I will let you know what happens.
Thanks again.
