How to Hold AFVs When Airbrushing?
    December 2011
Posted by Chrisk-k on Friday, January 27, 2012 2:16 PM
I wonder how experienced modelers hold AFVs when airbrushing (I got back from a long hiatus).
Obviously, I hold with my left hand. When recently painting my 1st model in 20 years, I smudged it because I ran out of areas to grab and accidentally touched (still) wet areas. Later, I put another model on a brick and airbrushed. It was difficult to paint lower parts of the chassis, though.
Is there a trick I should be aware of? Thanks in advance!
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    July 2004
Posted by stikpusher on Friday, January 27, 2012 2:25 PM
Paint the undersides first, before any handling. Do this from all four sides: left, right, front, and rear to insure full coverage. Then once that area is covered to your satisfaction put the kit on its tracks/wheels on a sheet of paper large enough to hold your kit and catch most overspray. You can rotate the paper with your kit upon it to spray each side and the top in turn while minimizing any further handling.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by wjbwjb29 on Friday, January 27, 2012 2:25 PM
Whats an AFV
Bil
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    July 2004
Posted by stikpusher on Friday, January 27, 2012 2:31 PM
wjbwjb29
Whats an AFV
Bil
Armored Fighting Vehicle
       - Plankton
LSM
    December 2011
Posted by Chrisk-k on Friday, January 27, 2012 2:32 PM
AFV = Armored fighting vehicles
    January 2007
Posted by the doog on Saturday, January 28, 2012 9:27 AM
Get yourself some of those cheap blue rubber or white disposable gloves from an auto parts store. Put one on your "other" hand. (the one not holding the AB).
Spread your fingers inside of the turret race hole, and airbrush without fear of getting paint on your hands. With some careful rotating and shifting-of-fingers, you can get the whole piece painted.
Alternately, make a cheap jig like car modelers use--you can twist a wire clothes hanger into some suitable position and run one end of it through, say, the sprocket attachment hole, or some similar hole.
You can also mount, for instance, a gun carriage or similar piece on a larger piece of sprue, perhaps even an old sprue piece that you cut apart. Use gap-filling super glue to attach the sprue end to an innocuous place on the bottom of the gun carriage or whatever piece you've got. You can always just snap it off later; the attachment point won't be visible. I use this method a lot for small pieces; I have a small box that I keep 3-4" lengths of cut sprue in, and attach parts to them for painting, then recycle them.
These are just some of the methods I use.
Posted by Spamicus on Saturday, January 28, 2012 9:39 AM
I do it basically the same as Doog has described, but I bought a cheap lazy Susan at a dollar store and sit the model on it. That allows me to rotate it without touching it.
Steve
    July 2006
Posted by constructor on Saturday, January 28, 2012 1:46 PM
Frst thing I do before painting is to wash my hands. This will prevent body oil from my hands getting to the AFV. I do not paint  (if it is a vehicle with turret) with the turret on. I use the opening of the chassis where the turret should go to put in my fingers to hold the chassis.
Posted by tigerman on Saturday, January 28, 2012 2:00 PM
Spamicus
Exactly how I do it!
 Eric
    April 2005
Posted by JohanT on Saturday, January 28, 2012 2:19 PM
Hi Chrisk-k, welcome greetings :)
I am with Constructor on this one in adition I am also using a Lazy Susan (had no clue that was the English name for it) with plastic foam and cheap Chinese chop sticks cut to length as required.
Very Best Regards
Johan
    April 2004
Posted by Jon_a_its on Saturday, January 28, 2012 2:22 PM
Yup
A Cheap lazy Suzan/cake decoration stand, err borrowed from my mum, with one of those neoprene/diving suit type mouse pads as a non-slip surface.
Also several wooden clothes pins to act as holders, I also use nitrile gloves.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August 2006
Posted by K-dawg on Tuesday, January 31, 2012 3:13 PM
When working on armor I typically mount mine on a handle. I have a couple that i have used for many years.
One is a spice container filled with fishing weights. I mount the hull on this as early as possible and use it as a construction and paint stand throughout the build. Only a little spritz of paint is needed to cover the bare circle on the bottom once done. This one is generally for out of the box builds where a lot of PE work is not expected.
The other one is an old GPS mount made by RAM industries that I modified so that I can screw one of the base plates to the bottom of the model. All i had to do was take one of the round pivot bases and cut it into a rectangle. This is the base I use when i'm going to be doing a lot of Photo Etch work or scratchbuilding. One twist of the knob and i can tilt the model any direction. It will rotate to the side past 90 degrees as well as front and back of course. It's wonderful to hold the model at odd angles while working on it. I also use it as a paint stand. It is especially useful while muddying and painting the under carriage.
Kenneth Childres, Central Arkansas Scale Modelers
    December 2011
Posted by Chrisk-k on Tuesday, January 31, 2012 8:49 PM
A Lazy Susan plus a GPS mount look exactly like what I need!
    March 2006
Posted by Shellback on Tuesday, January 31, 2012 11:42 PM
I'm with K -Dawg . Also when you paint the turret you can use a piece of plastic pipe . Wrap the pipe with electrical tape until it fits snuggly inside of the opening in the turret and slip the turret over it .Yes
    July 2004
Posted by wbill76 on Wednesday, February 1, 2012 3:54 PM
I use a similar method as Carl (shellback) but use cardboard toilet paper or paper towel tubes instead...seems like most 1/35 scale turret rings will fit that diameter for some reason. Wink
