Dragon Bergepanzerwagen 9 FEB 2012 Update and ?
Posted by IBuild148 on Saturday, January 28, 2012 9:41 PM
This is a tank recovery vhicle. I will be building OOB and using Model Master Acryl Paint. I will update my progress.
I started with the wheels (cut, sanded and primed)
? Here:
I am not well versed in armor but the kit as 2 options here for the following wheels. A7/A11 or A34/35 and A2/A3 or A13/A14.
I have opted for the A7/A11 and the A2/A3's. Input?
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    July 2004
Posted by wbill76 on Sunday, January 29, 2012 11:31 AM
IB,
The choice presented for the idlers has to do with the "age" of the donor Pz IV hull for your Berge IV. The introduction of the cast idler (A7/11) is a later feature versus the tubular idler A34/35....so it's up to you on which one to use. Both types wee seen on Pz IV Ausf H hulls with all-steel return rollers...which is what the choice is that's being offered to you on A2/3 and A13/14. Those types of rollers were used interchangeably so you can pick whichever type you like and run with it. HTH! Beer
Posted by Bish on Sunday, January 29, 2012 12:43 PM
I have this on my to buy list, so will deffinatly be keen to see how it comes together.
And is that an Italeri Panzerwerfer 42 i spy there.
Posted by IBuild148 on Sunday, January 29, 2012 7:45 PM
Thanks Bill for the insight. It is always a plus when a resident "guru" answers. I will go with the A7/11 idlers. One more? Should I then paint the A2/3 rollers steel followed by Dunkelgelb?
Hey Bish.Will do my best to update. Yes that is a Panzerwerfer. I am debating on leaving it Dunkelgelb or doing a "squiggly" Olivgrün scheme.
IBuildOne48
Scalefinishes.com
    July 2004
Posted by wbill76 on Monday, January 30, 2012 1:22 PM
Glad to be of help! On the return rollers, they would have been primed with red oxide primer before getting a DY coat like all the other components. The contact surfaces with the tracks would wear down to bare metal pretty fast though so bear (no pun intended!) that in mind when you get to the final paint/weathering stages. Wink
Posted by IBuild148 on Monday, January 30, 2012 9:49 PM
I figured that is what you would say Bill. Well I am off to the garage to paint all those wheels.
IBuildOne48
Scalefinishes.com
Posted by IBuild148 on Thursday, February 9, 2012 12:16 PM
Following is a small update on this project. Road wheels painted.
The question I have is on the instruction sheet here. What are Parts 25 called and purpose?
They have a hinge and it looks like that in real life these could be open from within side the tank for some reason. If this is true I was thinking of drilling a hole and inserting a pin so they would open and close for a small added touch.
IBuildOne48
Scalefinishes.com
    July 2004
Posted by wbill76 on Thursday, February 9, 2012 1:42 PM
Those are the fuel tank port covers. The Pz IV had the fuel tanks mounted on that side of the vehicle and the covers were armored and protected the spouts of the tanks. Definitely made the gunner's seat a "hot" one if the tank took a round there.  Beer
